Question about Dell OptiPlex GX280 PC Desktop
Dell PE 1600SC invalid memory configuration detected
When we installed 1gb DDR 266 ECC Reg. CL2.5, Computer screen display "invalid memory configuration detected"
from
Sikander Sattar
e-mail: pcpsatar@cyber.net.pk
I have a Dell Optiplex 330 pc. When i try to boot the cumputer doesnot enter to the boot system. But the error light indicates that "memory module detected but invalid configuration. How can I fix it.
  • yacobsbht Oct 28, 2008
    I have refered to the digonstic lights and thos lights indicate that:
    "Memory modules were detected but a memory failur has occured"
    Tpc is not displaying eny information on the screen. PLS help?
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmm..well..that unit has more than one slot..put a smaller, previous memory module back in, with the 1 Gig, and see how that works..for you.
    Problem Solver:
  • 18 Answers
You may need to install memory in matching pairs. If the new memory is a single 1Gb module and you didn't already have a similar one they may not work together. Try removing the original module(s) and see if it makes a difference.
Posted on Oct 28, 2008
I have 266 mhz 256MB RAM with intel D845 board. I want to upgrade it to 512mb or 1GB. Can you please tell me whether 333/400mhz will be suitable or where can I get it in hyderabad
hlo hyn you should get RAM 200/266 MHz of 512mb or 1Gb
below are the specifications your motherboard can support.
  • Two DIMM sockets supporting 2.5V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
for more info click this link http://www.intel.com/support/motherboards/desktop/d845gbv/sb/cs-012820.htm
Aug 18, 2011 | Intel D845GBV (BOXD845GBVL) Motherboard
Can I use DDR2 in an Acer Aspire T135?
The e RAM specifications for your Acer are -
Memory - DDR 266/333/400 expandable up to 2GB
Jun 11, 2011 | Acer Computers & Internet
I bought P3200 ddr 400 1gb memory and when i install it , it does not show up. any ideas why and if there is something i can do .
The Intel® Server Board S875WP1-E supports both ECC and Non ECC Unbuffered PC2100 (266 MHz), PC2700 (333 MHz), or PC3200 (400 MHz) compliant Double Data Rate (DDR) memory modules. Dual channel memory functionality requires two DIMM modules installed into DIMM sockets 1A & 1B, and then DIMM sockets 2A & 2B. The DIMM module size, speed and vendor must be the same.
You can install a single 128 MB memory module into DIMM socket 1A. The minimum supported memory size is 128 MB. The minimum main memory configuration is a single 128 MB memory module, and the maximum configurable memory size is 4GB. With only a single memory module installed, the system will only operate using a one memory channel.
Third party memory vendors may use the same module part number with different
DRAM vendors and die revisions. To insure proper system operation, verify that each DRAM
vendor and die revision has been separately tested and qualified. Please notify CMTL if there is a discrepancy.
Apr 10, 2011 | Intel Server Board S875WP1-E (S875WP1LX)...
Would this particular RAM work with my Dell Dimension 2400? http://cgi.ebay.com/KINGSTON-1GB-DDR-PC2700-ECC-REG-KVR333X72RC25-1G-RAM-/380226148054?pt=LH_DefaultDomain_0&hash=item58873e96d6
According to the Dell specification found here:
http://support.euro.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm#1105481
your PC does not support registered ECC RAM.
Most desktop PCs use unbuffered RAM. Registered ECC (Error Checking and Correcting) is a special type of RAM mostly used in servers.
Unbuffered RAM is faster than ECC RAM and is usually cheaper.
To find RAM that is compatible with your PC try the memory configuration tool at www.crucial.com
Please rate my answer is this was helpful.
Many thanks,
Chris
Mar 05, 2011 | Dell Dimension 2400 PC Desktop
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
No manual - want to install SNP J0202C/512 myself
This (4th)link should answer all your questions. If you enter your service tag number Dell can help more You can also get help from where you buy the memory it's not that hard..I like the first link to find out what memory to buy. I like the second link for pricing. Please rate me mysleuth
http://www.memory-up.com/default.aspx
http://dealnews.com/memory/
http://www.ask.com/web?q=how+to+install+ram&search=search&qsrc=0&o=0&l=dir
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?~ck=ln&c=us&cs=19&l=en&lnki=0&s=dhs&SystemID=DIM_PNT_P4_4550
Apr 08, 2009 | Dell Dimension 4550 PC Desktop
Sl-75frv memorys
Dear Sir,
You can install upto 3 GB RAM. i.e. 1GB PC3200 DIMM RAM in each slot.
Please go to BIOS settings & load the defaults. / check following. BIOS settings.
DIMM clock & timing is auto/ detected by SPD (Serial Presence Detect)
Possibly the 1GB RAM you are trying to install does not have SPD / is faulty. Try with a new / working 1 GB RAM.
Hope this helps you friend...
Jul 10, 2008 | Soltek SL-75FRV Motherboard
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Suspend to RAM
  • CAUTION:
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Thanks
Iqbal
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
may be ur pc not supporting 1gb so make it small means get less than 1gb than try.
Nov 27, 2007 | Intel AC450NX Server
Dell OptiPlex GX280 PC Desktop Logo
590 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
