Question about Saws
Milwaukee Sawzall problem
My milwaukee sawzall, model # 6523-21 keeps spitting out sawblades. I can cut for about 10 seconds and then the blade comes out. I've replaced the quik loc component, but that hasnt fixed the issue. My problem is that I've had several of these saws and this seems to be an issue with all of them over time.
  • kilpat169 Oct 28, 2008
    No, actually we use good blades because we use the saw on a daily basis cutting up cars. We are a salvage yard and use the saw to cut quarter panels and other body parts. Maybe my guy isn't using the saw properly?? thanks for your input, though!
  • yadayada
    yadayada May 11, 2010
    I have this saw and never had a problem, are you using cheap blades?
Some blades do not actually insert far enough in the lock even though they look identical. You can file the widest part at the hole end. Not the small leg but the flat part before the little guide leg. Filing this will allow the blade to insert deeper and will allow the lock pin to engage the hole on the blade. You don't need to file much maybe 1/64 ish.
Posted on Apr 27, 2010
  • 50 Answers
Ive had it happen to many of mine also. it happens what i do is blow it out with an air compressor or a can of dust off while opening it and shutting the lock. then pour some liquid wrench into the lock. and work it in by opening and shutting it a few times. that should help. this is a common prblm with many different brands of sawzalls.
Posted on Dec 05, 2008
Milwaukee sawzall blade
Cut or snap the blade off at the end so you can get the holder apart. I have had to do this before. Usually you can just use a set of pliers and work the blade back and forth until it snaps off but I just use an air powered cut-off tool and cut them.
Aug 05, 2012 | Milwaukee tools Milwaukee 6509-22...
Milwakkee cordless lithium sawzall clicks but blade wont move
you have a gear problem, if this is a newer sawzall I would take it back for warranty repair. If you need a breakdown you can go to milwaukeetool.com and download one. They have a good warranty
Jan 27, 2012 | Milwaukee Tool Milwaukee 10 Amp...
Milwawkee sawzall rotated shaft
If this is an older sawzall there is a bushing in the back plate that aligns the spindle. There is a service fixture for proper alignment. If this is a newer one you have a problem also in the gearcase that would need to be looked at. You can go to milwaukeetool.com and with your model number and serial number download a schematic for this tool . Let me know if you need more assistance and if you do I would need the model and serial number also.
Jan 09, 2012 | Milwaukee Tool Milwaukee 10 Amp...
Cutting an opening in a steel door for a doggie door. Bought a Sawsall just for this. Any tips?
be sure to use eye protection and gloves to protect you from sharp edges.
first mark your lines on the door using a square, then drill holes large enough for the sawzall blade to fit through in all 4 corners. next use the sawzall to cut your straight lines which were alraedy marked and you now the opening you need. if necessary use a file or dremel tool to clean up and debur edges. hope this was helpful, if so please rate.
Feb 17, 2011 | Milwaukee Tool Milwaukee Super Sawzall...
Motor on my sawzall 6572 runs but blade does not move. Blade locked in tight. No reciprocating motion.
The gears are stripped internally in the saw...it will need to be repaired..
heatman101
Jul 27, 2010 | Milwaukee Tool Milwaukee 10 Amp...
Milwaukee blade holder replacement
piece of cake. the number you need is 14-46-1011 and the cost is usually between 15 and 20 dollars. it comes with detailed instructions and a exploded parts list for this. About 10 minutes tops. If I have answered your request would you please rate this response accordingly. and if you provide me with city state and zip I will try and find one locally for you if in U.S.
Sep 14, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
I have a Milwaukee sawzall 6509-22 with a quick loc cam. Blade went in fine, but now the saw wont release the blade to come out. How do I fix this problem. Note: locking cam is turning fine
K you used the saw after inserting blade?? If so couple ideas, hold collar open and put saw blade in a vise and try pulling back on saw, or you can remove the quik lok cam and release it that way, its not that hard, but I would try vise first. Let me know
Jul 29, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Cannot get blade to release from Sawzall Quik-Loc.
Will the collar on the Quik Lok Turn and if so how much? What you can do is spray some WD-40 on the mechanism to free up the collar, sometimes it gets gummed up from cutting. It should open and close with a snap, hope this helps
Nov 29, 2008 | Milwaukee Tool Milwaukee 10 Amp...
Saws Logo
640 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
