Question about Symbol Cobra LS1902 Handheld
Opening up the scanner.
Does anyone have some pointers on how to open one of these scanners without breaking them? I have one that was dropped which now has a piece of plastic floating around inside. From time-to-time, the broken piece lands in front of the light making the gun inoperable. I attempted to open another prior to this one (same type of problem), but I accidently broke the casing when it "fell" on the wall. Any input would be appreciated.... John
Is there a power line to scanner
Posted on Aug 25, 2008
My labtop (acer5250) is slow and all this things are popping up programs opening by themselves it wont stop help please anyone
I am going to go out on a limb here and say if it's opening programs by itself that you did not set it to open you may have a virus? Have you checked with a virus scanner?
Jun 02, 2014 | Computers & Internet
Scanner stuck at 000.0000 keys don't work
You may benefit by performing a reset or initialization of the scanner. The manual describes the procedure at the bottom of page 38.
You may lose previously stored frequencies if you reset or initialize the radio.
RESET
1. Turn off the scanner, then turn
it on again.
2. Insert a pointed object, such
as a straightened paper clip,
into the reset opening on the
side of the scanner. Then
gently press the reset button
inside the opening.
Initialize
it on again.
2. Hold down TUNE/CLEAR.
3. While holding down TUNE/
CLEAR, insert a pointed object
(such as a straightened paper
clip) into the reset opening on
the side of the scanner, then
inside the opening. The
display should turn off.
4. When the display turns on
again, release TUNE/CLEAR.
I hope this helps & good luck!
Feb 04, 2013 | Radio Shack Pro-82 200 Channel...
Opening an older HP Scanjet 3300C case ??
I recently picked up a SJ 3300Cse and have the same issue.
On mine, on the top of the scanner near the hinges there are two small white rubber peices that are very well camoflaged. If you remove them you'll see the two screws to open the hinge side of the case.
Good Luck.
Jul 18, 2009 | HP Office Equipment & Supplies
Sharp AR M455N copier scanner will not scan to Windows 2000
Check the webpage under destinations and make sure the IP address is correct for this pc. can get to webpage by opening Network Scanner tool, hitting the scanner tab, then web setup button.
Also make sure the Network scanner service is running in the system tray (by the clock) and that it says the service is started by hovering over it with pointer.
Apr 16, 2009 | Sharp AR-M455N Copier
Smart Panel keeps opening by itself
check your Startup sub-folder from Start->Programs and remove the SmartPanel link.
Feb 07, 2009 | Apple Epson Perfection 1250 Flatbed...
Software can not find Scanner
ok connect your scanner in other usb port also check that all usb proper working.
then try to change cable.
may be your xp sp3 virsion not detect your scanner install proper driver for that.
Nov 18, 2008 | HP Scanjet 4200c Flatbed Scanner
Opening registry error
A registry is a very intricate set of software instructions. A cheap registry cleaner can do more harm than good believe me, I have seen registries destroyed by cheap junk! Stay away from free registry cleaners! Try this registry scanner and please let me know if it solved your problem...
Oct 05, 2008 | Epson Perfection 1660 Photo Flatbed...
Opening Canoscan case
screws on bottom ease the case off fix ribbon there under the rubber stops then once open your going to want to seal galss back down i recommend jb weld on edges to hold glass in if u dont secure glass when open a month down the road the glass will pop down i had my scanner 16 years since jb welding the glass down you only spot jb weld the glass though
May 05, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanner
I have installed Snow Leopard on my Mac and my Snapscan Touch AGFA will not work. This is the message I get on opening -
ScanWise can not find the current ColorSync System Profile. Please recalibrate your monitor or select another system profile with ColorSync Control Panel
Can anyone tell me how to fix it.
Jan 17, 2008 | Office Equipment & Supplies
Symbol Cobra LS1902 Handheld Logo
100 people viewed this question
Top Symbol Computers & Internet Experts
Vish Iyer
Vish Iyer
George Etukudo
George Etukudo
Norman Al-Anbar
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
