Question about Car Audio & Video
Fade Control of Alpine 9813 does not work properly
Hi
The fade control of my head units (ALPINE 9813) does not work properly. Sometimes when I fade all to Rear speakers, I still heard the Front speakers sounds. But when I fade all to Front, the rear speakers is completely quieted. The problem cannot be reproduced every time I try to fade; it is inconsistent.
The installation of both head units, amplifier and speakers has been done by the pros. I am not doing this myself.
So I suspect it could result from the fact that both head units and amplifier have been kept in my garage for 6 months after since I sold my car.
Here is the details of my system
Head units: ALPINE 9813
Amp: ARC 4050CXL 4-CH 50W RMS
Speaker: DLS UP6i
Amp: ARC FD600.1 1-CH
Sub: DLS RW10
Thanks for all advices.
Benimur
  • 6966 Answers
SOURCE: Fade F to R not working on Sony CDXF7000
Hi, To my knowledge, this head unit (Sony CDXF7000) uses individual 52 watts amplifier (X 4) whose output to the speakers require that none of the speaker wires be grounded or crossed/shorted. Please check the speaker wiring with the use of an ohmmeter (or a multi tester) with all the speakers temporarily disconnected. Verify that none of the 8 wires reads 0 ohms to body/chassis ground or to any of the other wires. As you have checked the wires area: front left > + red & - white/black stripe; front right> + gray & - gray/black stripe; rear left > + green & - green/black stripe; rear right > + purple & - purple/black stripe. Rewire should it be necessary. If the wiring fully checks out, it may be that you have a fader component failure inside the unit (though honestly rare). You can also check if there is no bridging modifications done; converting your 4 amp-4 speakers original design to a bridged 4X52=2X100watt amp to 4 speakers paralleled to 2. Another area you can check/try is by varying the DSO settings - 1,2,3,off. Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Posted on Sep 30, 2007
SOURCE: Rear Speakers dont work -Audi 2004 A6 sline Symphony II
you may have a loose wire somewhere or the wires comming from the headunit could be broke or damaged
Posted on Mar 04, 2008
  • 3 Answers
SOURCE: weak rear left amp output?
hey whats up bud i got an ALPINE V-POWER MRP-M350 these amps are great go to a walmart od any music shop buy a set of R.C.A cables that plug into your amp than that Ys off to a single connection its a male cable that run a set from the back of your cd player heres the trick ONLY PLUG YOUR BLACK COLORED RCA INTO HEAD UNIT MAKE SURE YOU RAP THE RED ONE WITH TAPE OR GET A RUBBER CAP TO PUT OVER IT SO YOU DONT GET ANY STATIC FREQUENCIES COMING OUT OF THE RED ONE THAN RUN THAT SET TO YOUR AMPLIFIER AND AGAIN ONLY TIE INTO THE LEFT CHANNEL OF YOUR AMPLIFIER.... Hope you know wnat i mean by that Y adapter ther is 2 prongs that tie into amplifier than it splits into 1 were your rca cables will plug into just that one thats how you bridge these confusing amps.... TRUST ME BOTH SUBS WILL SLAM HARD I RUN 2 JL AUDIO OFF OF MINE NO PROBLEM.... WRITE BACK TO ME IF YOU HAVE ANY PROBLEMS OR WHEN YOU GET IT HOOKED UP MY EMAIL ADDRESS IS gordo8785@yahoo.com hope to hear from you soon...
Posted on Jan 10, 2009
  • 651 Answers
SOURCE: Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
blueextc3221
  • 15935 Answers
SOURCE: Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Cda 9813 alpine say ERROR
the problem is with the reader.
Feb 25, 2008 | Alpine CDA-9813 CD Player
Alpine cda-9813 no power
You check the radio fuse in the fuse panel?The wire connections are right? Check the Owners Manual for other details or troubleshooting: ALPINE CDA-9813
Hope helps.
Jan 29, 2010 | Alpine CDA-9813 CD Player
CDA-9813 No sound, will not eject CD
There is a very tiny dot located either on the actual face of the alpine head unit or on the front plate of the radio once the face has been removed. Once you find this dot(if on the actual face) you need to make sure unit has power turned on and witha tiny needle or pick you may push this reset buton in for about 2 seconds. The face will automaticaly fold down and the disk will eject itself. Once this is done do not place the same disk back into the unit. Hope this solves your problem
Jun 09, 2009 | Alpine CDA-9813 CD Player
KCA- 420i and an alpine 9854r Can't change the volume for Ipod
There is a small switch on the unit's housing, switch it to "Norm" position.
May 08, 2009 | Alpine CDA-9847 CD Player
Adjust
I have an Alpine CDA-9813 and to access bass, treble, fade, and balance, you need to press the volume button. This button is usually rotated to adjust the volume but on mine, if you press it in, first time accesses bass, second press accesses treble, 3rd press accesses balance(left to right), and 4th press accesses fading (forward to rear. Press it a 5th time and it either brings you back to volume or back to the main screen. I think it is volume tho. I would assume that the 9853 would work very similar, if not the same.
Mar 21, 2009 | Alpine CDA-9853 CD Player
ALPINE CDA 9813
make sure that the acc and ground are hooked up right. acc has to be 12v. if you hooked it up to any other wire it will work until you(turn it up) draw more power than the wire you have it connected to can produce. or you have speakers that are faulty or too big for the alpine head unit.
Sep 18, 2008 | Alpine CDA-9813 CD Player
Alpine cda-9815rb
I solved this problem by calling Alpine Electronics customer services.
Apr 21, 2008 | Audio Players & Recorders
No Sound
everybody here got took by alpine. get together form a class action suit.
Jan 07, 2008 | Alpine CDA-9813 CD Player
How to wire a stereo system
Connect the 2 gage to the battery thru at least s 50 amp fuse, then connect the capacitor in line before the amps. Then run the 2 gage to a connector/splitter block and run 4 gage leads to each amp. You also will need at least 4 gage ground leads from each amp to a body grounded bolt or screw. You need to run a quality set of speaker leads from the head unit to the amps. The speakers will need separate leads from the amp to each speaker.You will need to try some different combinations to get the sound and bass you want. You want to be able to fade from front to rear and control everything thru the head unit.
Use a hole saw to cut a 2 to 3 inch diameter hole in the side of the speaker box for a port to get a better punch from the sub.
Hope this helps some....
Nov 03, 2007 | Alpine CDA-7863 CD Player
Car Audio & Video Logo
156 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
