Question about Refrigerators
Need to download manual for dometic 2582 refrigerator. refrigerator not cooling
  • 51 Answers
SOURCE: dometic refrigerator
The system is sealed very difficult to charge. Not to mention expensive. The same price to get a new coil. The boards that control the operations are hard to trouble shoot sometimes. Do you have 12 Volts DC going in to the control board. If yes does the control board inside show green lights that it is working. If so the lower control board on the out side needs to be looked at.
Posted on Sep 07, 2008
  • 531 Answers
SOURCE: Dometic refig ndr 1292 not cooling all the time
you may have a defrost problem
Posted on Apr 02, 2009
  • 9 Answers
SOURCE: dometic RM 2800
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
  • 110 Answers
SOURCE: dometic refrigerator does not cool?
You need to check the Condenser coils, these are copper coils of tubing usually located on the back of the unit near the ground. They need to be free of all dust and grease to work at maximumefficiencyand it is recommended to clean them every 6 to 10 months. If those coils are already clean, the next thing to do is check the evaporator fan(The fan inside the unit). See if it's running. If it's not, check the coils behind it. If the coils are frozen up then you probably have to change out the fan motor.If they aren't frozen up then there may be a refrigerant leak or a bad compressor*. In order to legally reclaim, recharge, or test refrigerants you need a special certification2_bing.gif from the EPA. If you need to do so I recommend you call in a certified technician.
If the lights, fans, and compressor aren't working at all, check your fuse/breaker box to see if anything is tripped or blown.
If the lights are on but nothing is working, The thermostat may be having problems.
*To replace the compressor you need to reclaim and recharge the refrigerants from the system.
Posted on Apr 03, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Dometic DM2862
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Aug 10, 2010
Our new Dometic DM2852 will not stop running. Help!
Old solution from a forum but it get sense.
Citation: "It seems like there could be several possibilities:
1. Refrigerator is struggling to keep cool - maybe because of high outside temp, maybe bad seals, maybe other issues. Fan runs all the time because the back of the frig is hot.
2. Refrigerator is cooling ok, but fan runs all the time because there's poor ventilation on the back - maybe vents are blocked in some way.
3. Refrigerator is cooling ok, but fan runs all the time because it has a defective or improperly adjusted ventilation thermostat (that controls the fan).
4. Refrigerator is cooling ok, but fan runs all the time because Dometic did not include a thermostatic control on this model.
I'd suggest checking the manual or calling Dometic to ask about #4. If there is a thermostat controlling the fan, it may be covered under the Dometic warranty (which might be longer than 1 year)."
Feb 06, 2018 | Refrigerators
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Fourwinds hurricane rv
We are Arcticold refrigeration, we manufacture brand new replacement cooling units for Dometic & Norcold RV fridges. Our cooling units all come standard with install instruction, installation hardware, and a lifetime warranty. Feel free to give us a call to free 1-888-782-6665 I can send you the install instructions by email if you would like to take a look at them. In most cases it takes approximately 2 hours to change the cooling unit. I will also need the model number of Refrigerator you have. Visit ArctiCold Refrigeration We keep it cold for some info. Below is a example of one model of cooling unit we build. It is a Dometic RM2852 shown in the picture. 39ede16a-9d21-4648-ad1c-33f0d0c45ff3.jpg 599bd524-a61c-4c24-afa2-1a1a9c84d92c.jpg
Mar 02, 2014 | Dometic Refrigerators
I have a Dometic rm3801 it was working fine on 120v and abruptly quit cooling all lights come on compressor and cooling fan don't run. I aam unable to try it on lpg. Fridge is level and cooling fins are...
If the rear cooling coils are warm and the refrigerator is level and there is still no cooling, then you more then likely will need to replace your cooling unit. It takes a couple of hours to do but you dont need any specialized tools. Check out ArctiCold Refrigeration We keep it cold Your unit can be found on ebay at under half the price of a new fridge. Link Below 11d6ec30-092e-426d-853a-24315c5d73c1.jpg Dometic RM3801 Brand New Manufactured Cooling Units LIFETIME WARRANTY...
Sep 25, 2013 | Dometic Refrigerators
I changed cooling units and now i dont have any power going to the refrigerator dometic 2652
I would check the lower circuit board it has a few fuses,main fuse. And you should download and print the Diagnostic service manual.
Roy
Jul 29, 2010 | Dometic RM2652 Refrigerator
Need instructions on how to light a rv Dometic refrigerator-
Go to this link and download 2600 PDF, last few pages are operation.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Operation--Installation-Manuals/
Jun 08, 2010 | Dometic RM2620 Refrigerator
Refrigerator not working on gas
There is some reason maybe not explained here. But I will help you if you want. Below is a simple test. The manual I need you to make sure if you have the RM2652 or another model to get the correct manual. That model has digital controls and that is controlled by a control board for switching from AC to DC to Propane. If the board will not switch then we need to look for that problem. Dometic, good refrigerate and great support group. Now here is a link to that model number problem solving PDF. With the manual we can work together to solve this. Thanks, Sea Breeze http://www.dometic.com/FileOrganizer/1-international/Operation%20&%20Installation%20Manuals/Refrigerators%20-%20Caravan%20-%20Motohomes-%20RV/English%20and%20Multilingual/RM2652-RM2852.pdf
Jun 16, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
