Question about Air Tools & Compressors
Adjusting air on husky hhd2nk air compressor
Keeps running over 125 pressure, won't shut down
5 Suggested Answers
  • 18 Answers
SOURCE: my husky air compressor is suppose to shut off at at 125psi
Pressure switch may be stuck. May need to adjust pressure switch.
Posted on Jul 10, 2010
heatman101
  • 43501 Answers
SOURCE: Husky Air Compressor wl660800AJ...my problem
Here are a few things that I would check first off...
Check that air comes out of the tube to the pressure switch..(make sure it is not clogged with dirt or debris)
Check that the compressor is still able to build adequate pressure... air filter may be clogged...
Check that the pressure switch contacts are not welded together....
Check that pressure switch is not malfunctioning and that it can open the contacts if tripped manually...
heatman101
Posted on Jul 11, 2011
mpcheeseman1
  • 1400 Answers
SOURCE: Husky Air Compressor wl660800AJ...my problem is
Hello
Replace the pressure shut off switch.First drain the tank and shut off all power.Remove switch and inspect for any debri or water in the tube to the switch.
Also check the settings.max i think is 150psi.So it should fill to say 145 and shut off.
Posted on Sep 26, 2011
  • 1388 Answers
SOURCE: Can I adjust the tank pressure on a Husky 1506
Before you change any parts, check that the pop valve is not faulty. Look closely at the pop valve to read set release pressure. If the valve is releasing before marked reading, replace valve instead to one slightly higher. The pressure may or may not be adjustable at the switch (need to replace the switch) depending on switch installed at the factory (parts list does not give enough information). If your switch has a remove-abel cap with adjustment screws/nuts, post again with model number of switch for info on adjustment. Good luck
Posted on Oct 06, 2011
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
Husky air compressor repair
Are you meaning that you cannot adjust the regulator to change the pressure output?
Jun 01, 2013 | Husky Factory Reconditioned Electric Air...
Motor cuts off before reaching 125 psi
Im guessing this is a recip (piston Compressor) Sounds like your pressure switch may have adjusted itself by vibration. Take the cover off the pressure switch, there should be 1 or 2 screws on the top, one adjusts the pressure, the other adjusts the differential pressure (There may just be one) turn the pressure screw in the direction of the +, you need to do trial and error on this, turn it 1/4 of a turn, then switch on, see what the pressure gets to, then switch off, drain some air off, then adjust as necessary until you get your required pressure. Hope that helps
Aug 31, 2012 | Husky Air Tools & Compressors
Compressor reaches 125 psi but does not shut down
Depending on how old your compressor is, usually inside the pressure regulator cover are instructions on how to adjust the turn-on and shut-off pressures. If not, it usually invloves turning a nut or screw to lessen the pressure on the spring that keeps the contacts closed. Try adjusting the pressure down. If it won't come down to a safe level you will be better off replacing the pressure switch. The number you give above is the Campbell-Hausfeld (they are Husky) part number for the pump and motor assembly so I don't know which CH pressure regulator you need. They are easy to find and easy to replace.
Jun 21, 2012 | Square D 9013FHG14J52M1X Air Compressor...
Poor air compression
I would guess from the info supplied that the pressure switch is shutting it down at 125. Most piston type compressor only pump a max. of 175 unless it is a special high pressure unit. Also it may be shutting down on high amps, high temp etc.However with all that said Piston units are positive displacement, meanning that it should pump until something gives. Start your unit, close the discharge air valve and see what it pumps up to. May have to adjust pressure switch to get over 125. If unit runs and runs and just will not go over 125, you probably have a valve going bad. Do you have a safety lifting. if so another indication of a bad valve.
Nov 27, 2011 | Ingersoll Air Tools & Compressors
Can I adjust the tank pressure on a Husky 1506 compressor. pop off keeps engageing, so I need to adjust so that compressor shut off automatically
Oct 06, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a husky brand air compressor with 7.5 h.p. compressors. when pressure builds to its maximum amount, compressor will not shut off it continues to run while pop off valve opens.
Ypur pressure switch ( the grey box), is not shutting the motor off. It is is either adjusted higher( too much pressure), or stuck. Unplug it and remove the cover, Then make sure the gold colored lever moves. This is what shuts the power to the motor off. You can plug it in and watch to see if the lever moves before the pop off blows. It depands on the tank rating as to what pressure yours should be set to. Around 125 psi is recomended.
Hope this helps.
Dec 31, 2010 | Air Tools & Compressors
My husky air compressor is suppose to shut off at at 125psi
May 27, 2010 | Air Tools & Compressors
HUSKY 26 Gallon Shuts Down After <75PSI!?
Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
Sep 08, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
The compressor relief valve keeps popping, compressor runs
What pressure is it popping off at? You might have to adjust the pressure switch to a lower setting.
Apr 01, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
59 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
