Question about Gateway 506GR PC Desktop
I replacement fan
I have a gateway 506GR, it is making loud noises. I know it is a fan issue, but I can not find a replacement fan that fits the small 4 pin connector. Can anyone help. Gateway support is not that helpful
Same problem.  I took the fan out and cleaned off the dust and the noise is gone.  I have also ordered a new fan from the following site:  http://www.cwc-group.com/fopv904dcbrf.html
Posted on Dec 27, 2008
  • 4 Answers
They sell some things that you can put on the fan so it can run quietly without making any noise.
Posted on Oct 28, 2008
Fan making loud humming noise
Take the fan, open it, use just one small motor oil drop into the fan axle.
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Jan 30, 2014 | Gateway Computers & Internet
Fan making noise
To find out which fan it is, open the side and listen.
If it's a case fan those can be bought at you local computer store for a few bucks.
If it's the CPU Fan, you might be able to replace just the fan, or you might have to install another CPU Heatsink and Fan.
Hope that helps!
Dec 15, 2010 | Gateway 506GR PC Desktop
Gateway 506GR Front Panel
did you replace the motherboard? if you did with a non gateway replacement there is a good chance you will have to re-wire the buttons.
if not, just look for an oddly shaped "gateway" plug that plugs into the receiving socket on the MB. If you dont own a multi meter and soldering iron now is a good time to invest. also get some wire strippers and cutters.
Aug 24, 2009 | Gateway 506GR PC Desktop
Gateway 506GR motherboard configuration
Item Description Item Description A Rear Panel I/O Ports M Front Chassis Fan Connector B Auxiliary 12-V ATX Connector N Serial ATA Interfaces C CPU Socket O Front Panel Header D CPU Fan Header P Front USB Connector E Memory Slots Q Front USB Connector F Standby Power Indicator LED R Front Panel IEEE-1394a Connectors G Floppy Disk Drive Connector S Speaker H ATX Power Connector T PCI Express x1 Connector I Parallel ATA IDE Interface U Front Panel Audio Connector J Battery V PCI Slots K Intrusion Switch Header W Rear Chassis Fan Connector L BIOS Configuration Jumper
Aug 21, 2009 | Gateway 506GR PC Desktop
PC Fan Issues
1 fan in and 1 fan out, usually out through the front.
Aug 27, 2008 | Gateway 506GR PC Desktop
Gateway desktop 506gr power issue narrowed down?
That was pretty unclear.  Is there a kind of burning symptom that suggests a short to you?  It seems to me that what happened is that either there was a power outage and your system thus shut down...all you'd have to to would be hit the computer's power button to turn it back on...or a fan somewhere died and therefore the system won't power up until you replace or repair that.  At least get a vacuum in there and brush out the dust so you can work.
What happened when you got a simplified system that 'worked'?  Was the power supply's fan spinning, at least?  What's the green light on, anyhow?
Jul 31, 2008 | Gateway 506GR PC Desktop
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
No signal, Gateway 506GR
Start by disconnecting the new DVD writer and verify all power supply connections are not shorted.
May 01, 2008 | Gateway 506GR PC Desktop
Gateway 506GR PC Desktop Logo
215 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
