Question about Honda Electrical Supplies
I have an Honda EX 5500 Generator. The 1 amp chargin system to battery is not working. Any solutions?
There is suppose to be a chargin coil, to charge battery while generator is running. My generator is not chargin the battery now.
  • 1383 Answers
SOURCE: honda generator em 1800
Honda generators are very reliable and are easy to adjust. The best way to check for proper output is to use a meter that can check cycles and voltage. Set meter to htz or freq and adjust the engine governor to 60 cycles. When the engine is turning 3600 rpm it is at max power and the generator may be producing ac voltage ranging from 115 to 125 at 60 cycles. When you draw power from the generator the engine governor will try to overcome the stress and maintain 3600 rpm. The engine must be well maintained to produce full power. Service oil, filter, plug and valve adjustment. Some engines have a spark arrester installed in the muffler that may become blocked with carbon. If engine is producing full power and voltage/amps is low then check brushes, capacitors, and/ or voltage regulator. Most problems occur when too much power is requested from rated generator. Example, trying to connect an 1800 watt air compressor to generator. The compressor may draw double the stated wattage upon starting and cycling. For longest generator life, It is best to use only 75% of rated output. On an 1800 watt generator use max wattage 1350. If you actually need to use 1800 watts then the best generator would be a 2500 watt. enjoy
Posted on Nov 30, 2008
spekgt
  • 60 Answers
SOURCE: My Honda ES6500 watt generator keeps blowing 15 amp fuse
Hi there .
In my opinion you should remove the starter and check the starter first . After you remove the starter get a good 12v battery and 2 wires and test the starter . Make sure to not invert polarity . After you touch the wires on the contactor (small solenoid on the side) see if the overrunnig (part with gears) comes out easy and with no obstruction . If the overrunning does not come out you could have a bad contactor (part # 31204-ZA0-003) or a bad starter (part # 31200-ZA0-701) .
Hope this help
Posted on Sep 02, 2009
protek480
  • 1714 Answers
SOURCE: The generator starts up then dies?
Check the oil pressure switch. It will shout you down like that if it doesn't sense oil pressure.
Posted on Oct 01, 2009
  • 905 Answers
SOURCE: I have a Coleman Powermate 5500 Generator. It is
This engine was not built with quiet in mind, it was built to be cheap. upgrading the exhaust is your best bet and likely the cheapest. Talk to a small engine shop about the possibility of using a muffler from an ATV.
Super Trap makes a fantastic muffler, if it will fit your application (most do). A link has been provided at the end. When you are looking at the various options, you will notice that a rating in db units. Reducing noise by 3db is half the original noise level.
if you can, go with the SuperTrapp. If still noisy (probably won't be), then add on the resonator as well. Downside to using aftermarket is that you will have an exhaust stack / system that sticks out the side of the generator. Upside is that you will be able to think quietly about how much the exhaust sticks out.
And no, I don't have any connection with Jack's, they are just the first hit that came up. Now that you know that something is available, you can do more research on it.
http://www.jackssmallengines.com/Quietmuf_index.html
Posted on Jun 12, 2010
ftw1952
  • 10319 Answers
SOURCE: Generator starts easy and runs fine but will power
replace that particular breaker.. It may have corrosion inside of it since they are idle most of the time and moister attacks the mettalic parts inside. If corroded the amps can not get through causing it to switch off
Posted on Nov 06, 2010
Resetting the pcm my alternator not chargin
I don't know what kind of testing you have done? Are there any codes for the charging system? I don't like taking negative battery cable loose trying to reset some system, if may cause more problems than you have, now.
In the diagram, the wire from generator to pcm has a duty cycle signal on it.
Nov 13, 2016 | Cars & Trucks
My FR691v-as07-R toro timecutter's battery discharges while running. Replaced the Battery, voltage Reg and Diode, still discharges.
It sounds like a job for a volt/ohm meter.
I am not familiar with the model but the basic principles are fairly consistent.
Either there is something causing the battery to discharge at a greater rate than the generator can recharge it or more likely the generator simply isn't working or isn't working efficiently.
In order to charge a battery the generator must provide a higher voltage than the battery or current will not flow. Assuming a 12 volt system the voltage of a fully charged and healthy battery is 13.2 volts. The generator must provide a higher voltage and typically would be around 14.5 volts for solid-state or electronic systems and 15.5 volts for electro-mechanical systems.
Scale the voltages up or down for 6 volt or 18 volt or 24 volt systems...
Isolate the battery from any battery-supplied accessories and then with the engine running fairly fast check the voltage across the battery. If only the battery voltage is present it indicates a generator problem.
As well as providing a higher-than-battery voltage the generator and all the associated wiring and connectors must be able to provide the current flow. In the case of problems it is best to go back to basics and carry out a visual check of all the wiring and connections and check the continuity and insulation of the generator windings and wiring, rectifier diodes, brush gear if there is any fitted and earth connections if it is an earth return type system. It is a good idea to use a wiring diagram for reference.
If the generator is a permanent magnet type there have been rare occurrences where a generator has become inefficient due to a loss of magnetism. I repeat this is a rare occurrence and the fault probably lies elsewhere and a systematic approach and reference to a wiring diagram will usually isolate the fault.
Jan 14, 2015 | Toro TimeCutter Zero Turn Lawn Mower...
Bike won't rev out
Could be electrical.Bikes that have generator systems need battery induced.Unlike an alternator system,like a car you can jump start and the alternator will run with good spark to fire fuel.Generator type need battery induced,so battery must have correct amperage.Can test battery with a volt or/amp test.See what you have with bike not running,then running need about 20% more volts then the 6 or 12 volt battery states (about 14 volts running on a 12 volt battery.Know your battery life span & know that a new battery that year.Plus generator must keep battery charged.I like to have a good spare and also go for a glass mat battery especially if bike is ridden season related. Good Luck!
May 17, 2014 | 2002 Honda CMX 250 Rebel
Onan 5500 marqui gen set stumbles on demand
Steve,
The microwave alone shouldn't cause a problem for the generator as even the most powerful models run about 1200 watts or about 10 amps. An air conditioner on the other hand, can draw considerably more power to run depending on BTU size; 15 amps and up is not uncommon (and even twice as much as that though only briefly when starting).
If these were the only things connected and on, the generator should be able to handle them - again depending on the BTU size of the AC unit. Generators state their capacity in Watts, but must of the devices we connect are in Amps. Calculating Watts in an AC circuit is complicated, but pretty close to the much easier Watts in a DC circuit for most residential settings. Here's how it's done:
Watts = volts x amps. Pretty simple stuff. Your generator is rated at 5500 watts. The microwave is say, 120 volts / 10 amps - which equals 1200 watts. The generator has 4300 capacity available now. Suppose your air conditioner is rated at 120 volts / 15 amps - which equals 1800 watts. 4300watts - 1800watts = 2400watts capacity is left. But, the starting current for the AC is as much as 25 amps for a few seconds (and once started drops back to 15 amps) - which means there's only 1200 watts capacity left. Add up the rest of the appliances you're running at the same time (TV set, Cable / Satellite box, stereo, toaster, lights, computer, etc.- you get the idea), and you can see how you might have exceeded the 5500 watts capacity of the generator for a few seconds. It's at these times that your hear / see the generator speed falter and sputter, lights dim, etc.. If this is happening a lot, you may need a larger or additional generator.
I hope this helps and good luck!
Dec 25, 2011 | Watts Onan Portable Generator - 5000 ,...
Hi there I'm stuck I don't know how to check the
Sorry but they either work or they dont.
If yours isn't working, replace it.
But before you replce it consider checking the other components, because ign mods are exspensive.
it sounds like you've been already checking the other stuff. heres what i'd check if your bike came to my shop.
1. battery fully charged, and can take a load. (weak batteries = weak ign power)
i have a bike that won't fire at all with weak battery. Make sure battery is good.
2. check for spark at plugs, make sure plugs are good. Pull plugs and turn motor over.
rest plug next to head and turn over, do not touch the plug while turning over
or you can be shocked.look for spark.
if you have spark , then you ign mod is working.
if no spark, then check #3
3. power to coils. check the power going into coils,
if power but no spark, then coil is bad.
if no power. check #4
4. power to coils comes from a ignition system ( points/ cdi /ign. module)
there is a stator and a rotor. and a signal generator. on your motor
the signal generator wire sends a signal to the cdi, every time the rotor rotates.
the ignition system (ign.mod) sends power to coil.
so if no signal to the cdi, then signal generator is bad
if signal going into cdi but not sending the power to the coils then the cdi/ ign. mod is bad.
Hope that helps
Best Regards
Big Al
Jun 28, 2011 | 1995 Honda VT 600 C Shadow
Can I use a 8 volt battery on a 6 volt tractor or will it trip the voltage regulator and blcck the generator?
YOU CAN USE AN 8 VOLT BATTERY, IT SHOULDN'T HURT ANYTHING. THE ONLY THING IS IT WON'T STAY FULLY CHARGED. THE GENERATOR IS DESIGNED FOR A 6 VOLT BATTERY NOT 8 VOLTS. WHAT I DO IS CHANGE THE SYSTEM TO 12 VOLTS. NOTHING WILL HAVE TO BE DONE TO THE STARTER, IF THE TRACTOR STARTS LIKE IT IS SUPPOSED TO. IT WILL JUST START FASTER. YOU WILL NEED NEW POINTS & CONDENSER & A RESISTOR FOR THE DISTRIBUTOR. ALSO A 12 VOLT BATTERY & A MID 1970'S INTERNALLY REGULATED ALTERNATOR, MOUNTED IN PLACE OF THE GENERATOR. THIS A LITTLE WORK BUT THE TRACTOR WILL START AMAZINGLY FAST. I HAVE DONE THIS SEVERAL TIMES & IT WORKS GREAT. IF THE FUEL GAUGE STILL WORKS YOU WILL NEED A SPECIAL RESISTOR FOR THAT. OF COURSE ANY LIGHTS WILL HAVE TO BE CHANGED TO 12 VOLT GOOD LUCK. DR. VOLT.
Jan 25, 2011 | Ford Expedition Cars & Trucks
I have a 5000 w maxa ER generator that has a battery assist added ( PM 0525312.17 ) Question...Is the battery a regular 12v car battery, or maybe a lawn tractor battery?? Once the generator is started...
Replace battery with your choice of 12v products considering physical size, amp range and warranty. Lawn tractor batteries seem to have the least life/duty cycle. There are two methods of charging the battery used by Coleman. One is to charge the battery with charger/alternator coils installed under flywheel of the engine and second is to charge with built-in circuit in generator itself. Examine your wiring diagram to discover which you have. Simple test with volt meter will show if system is charging. Test voltage at battery with engine off, then start engine and retest looking for slightly higher voltage indicating charge. The charging system is like a trickle charger and not like your auto with initially high amp charge then taper to minimum. If your run your generator for long periods of time and you feel that the battery is being overcharged, then rig a switch to stop charging after one hour or longer. Good holiday
Nov 27, 2010 | Coleman Powermate Powermate 5000W...
12000 watt powermate won't charge the battery
Some Coleman generators have rectifier /diode pack behind panel others have a diode inside generator cover however when diode fails it usually fries the winding. Your winding could be within the generator or under flywheel depending on model#. If your generator had a fuse to protect winding then test diode and replace as necessary. You may also just plug a small battery charger (1 or 2 amp ) into 115v plug to charge battery / power coil. Good luck and email if you have other questions.
Oct 27, 2009 | Coleman Electrical Supplies
System wont charge battery
I`m not sure if you know this but most Motorcycle Charging systems do not show output at idle, rev the engine to right about 2000 RPM then check the output, if you are still not reading about 13.5 volts, I would look in to the Rectifier as the problem as they tend to get warm and quit,
Jul 06, 2009 | 1986 Yamaha XJ 700 X Maxim
Honda EU2000i with a washing machine
Yes - it will be a fine machine to have and do well.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore Washing Machines
Electrical Supplies Logo
156 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
