Question about SonicWALL TZ 170 Wireless (01SSC5903) Firewall
Patton SIP / VoIP problem behind TZ170W
Hello!
We have set up a Patton VoIP-gateway behind a SonicWall TZ170W (which has a public IP on the WAN-port).
We have forwarded UDP-ports:
5060, 16300->16700, 4864-5118 and 4865-5119 to the VoIP-gateway's IP-address.
By the ISP's recommendation, everything under VoIP-settings is disabled.
The firewall is setup to allow all traffic from LAN to everything.
When we pick up a phone here on the inside and dial out, everything works properly. However, when somebody calls in, we can hear them, but they cannot hear us.
What could be wrong?
  • Bj?rn Mathisen Oct 28, 2008
    CORRECTION:
    INGOING sound is the problem.
    People on the inside cannot hear the external callers when the calls come from the outside.
  • Bj?rn Mathisen Nov 10, 2008
    Enabling VoIP-settings in the interface, against the service provider's suggestions did the trick. How do I set this question as closed?
  • 74 Answers
Please look into the chapter 34 in the guide which you can download from the following link
http://www.sonicwall.com/us/support/230_2749.html
Posted on Mar 21, 2009
  • 3,267 Answers
How about a simpleton's laziest answer is------------ switching/enabling/allow/accept just what you yourself go against-------- exactly the opposite(like drinking alcohol or not wearing an Helmet whenever u go out on ur bike is injuriousdangerous or like stutary warning Z ! Do not try to open the cover yourself(&a yellow triangle with a cross) but we still do it, I mean, OK at the most i'll get a shock, cool so what, I won't be fried, right!!?
And do against these "danger/hazardous" your ISP recommendation Quote---By the ISP's recommendation, everything under VoIP-settings is disabled. The firewall is setup to allow all traffic from LAN to everything.----------unquote. So I can't differentiate/understand everything. BUT FIREWALL IS ALLOWED; is that not true for EVERYTHING so how about the interface, its function includes this as everythig but not everywhere its blocked so unless allowed to go out but door has topend to allow some in OR out. Crude but logical.....sodeep
Posted on Oct 27, 2009
Why Add SIP Trunking to Telephone System?
SIP trunking is cost effective, particularly when you are doing international calls, relative to general telephone technology. Enterprise Sip Trunk is Voice over Internet Protocol (VoIP) and streaming of media service is based on Session Initiation Protocol. By unifying these protocols Internet Telephony Service Providers (ITSP) deliver their services to those customers who are equipped with IP-PBX and facilities having unified communications. IP-PBX is SIP based private branch exchange. You can seamlessly stream voice, video, conferencing, etc. on this platform.
There are two domains of SIP trunking- private domain, public domain. Private domain is typically owned by a person or a firm through its server equipped with IP-PBX. Whereas public domains use PSTN. In private domain, the responsibility for everything is that of the firm or the individual, but in public the responsibility is that of the Internet service provider.
May 02, 2017 | Radio Communications
Tip
How to configure a Router?
How to determine the WAN configuration or Interntet configuration of a SOHO Router?
1. Connect the computer to the Modem via Ethernet cable. Make sure you are able to going online 2. After confirming you are online. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway
There are 4 possibilities of IP address you can get
i)Public IP address under PPP adapter. -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP ii) Public IP address under PPP adapter and Private IP address under Ethernet adapter -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP iii)Public IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Click Mac clone on the router's WAN configuration * Power-cycle modem and Router. iv)Just a Private IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Power-cycle Modem and router.
After determining the WAN mode, it is time to configure the Router
1. Connect the Modem to the WAN port of the router. Connect the computer to the LAN port 2. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway. The Default Gateway will the IP address of your router 5. Open a Web browser and type http://192.168.1.1(where this is the default IP of the router. This will be different from each manufacturer) on the address bar. 6. Go to WAN settings or Internet settings and select the options based on the above mentioned possibilities
on Aug 26, 2010 | Computers & Internet
I have polycom SoindPoint 301 and i would like to use as SIP to one of the VoIP providers. I dont have asterisk in my network and i would like to connect it directly to the VoIP provider. So there is no...
1st. Get the IP address of the phone. and type that into browser.
*- default user: Polycom / password: 456
*- Under menu SIP, type in your voip provider
*-Under menu LINES type in user info and "secret" should be your password.
Make sure your ports are open (SIP is usually 5060) you can change it in that same config screen.
Mar 28, 2011 | Polycom SOUNDPOINT IP 301 SIP
I have Nokia E72, how can I connect to VOIP service in our office?
go to Tools > Settings > Connection > SIP settings
Profile name: any
Service Profile: IETF
Default Access point: select your access point
Public user name: sip:your-voip-ext@voip-server.com
Use compression: No
Registration: select your preference
Use security: No
Proxy server: empty/no settings
Registrar server:
> Registrar server address: sip:voip-server.com
> Realm: asterisk
> Username: voip-ext-no.
> Password: voip-password
> Transport type: Auto
> Port: 5060
Then go back to Connection > Internet Tel.
create profile and select the SIP settings you just created.
May 06, 2010 | Nokia E72 Smartphone
I need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Jan 23, 2010 | SonicWALL TZ 170 SP Firewall
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Using just the VOIP part of a Belkin all in one router??
You will probably need to set it up differently, I do not know the belking router, but normally the VOIP functions only work on the wan port of these routers so you should make the connections as follows:
INET ---> (wan) DLINK (lan) -----> (wan) BELKIN (voip) --> Phone
|--------> Wired Computers
|--- ) ) ) Wi Fi computers
On the DLINK enable DHCP and set a fixed IP for the Belkin router, either by setting the belkin in an IP outside the DHCP pool or setting it from the DHCP server.
This configuration workd well with a DLINK and a Motorola (vonage) router I have.
Apr 23, 2008 | Computers & Internet
Sonicwall Pro 300 DMZ Problem
If you're within a network and try connecting to computers on it with the WAN public IP, it simply won't work - you must use the network IP. On an external Internet connection, it should connect fine to the public IP. If you have access to an external machine (remote desktop), or if you know of an FTP proxy, you can try it that way. I also believe http://www.webftp.co.uk/ a web based FTP client would act as somewhat of a proxy, you could try that with the public IP and see how you go.
Aug 09, 2007 | SonicWALL PRO 300 Firewall
SonicWALL TZ 170 Wireless (01SSC5903) Firewall Logo
726 people viewed this question
Top SonicWALL Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Alun Cox
J John
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
