Question about Fuji FinePix S5200 / S5600 Digital Camera
Wont turn on
Have not used for 12 month and put all new batt in still nothing
  • 164 Answers
Double check for the batteries to be in the right order, if it's a rechargeable battery, let it charge completely before you use the camera.
One more thing, check battery compartment, the old battery might have had it's chemicals spilled inside, or the contacts might be dirty. If that's the case, clean it and try again.
Posted on Feb 24, 2012
Have had a fujifilm finepix s2590 for about 6 monthes" --i had taken my batteries out alittle over 2 weeks ago and forgot idid and when i put some in earlier it wont turn on at all. i was told it was...
If you have a power adapter for it try to see if it will power up using that. If it does install fresh batts and see if that will work. I use rechargeable batts with mine and have allowed them to fully discharged at times for up to a month. I pop in fresh batts and it always fire up for me.
Oct 02, 2017 | Fuji Rod Repair Kit
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Battery problem
Remove stain from batt. location , spray it WD40 inside batt. compartment then use NiMH batt. enelop white color
Jun 17, 2009 | Canon PowerShot A570 IS Digital Camera
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
Both cordless drill batteries dead.
Your battery could say its good by just testing voltage,but when a load is put on it , its a different story. My dewalt batt. did the same thing I opened up the batt. case and there was 12 "C" sized batteries inside linked together with little metal strips. I bought 12 rechargeable "C" batts. and carefully drilled where the metal strips are soldered, changed out batt. and re solder. It's been over a year now and still drilling . Also you should do this one batt. at a time so you don't put one in the wrong order .
Mar 17, 2009 | Craftsman Drills
91 datona wont start
That relay you are talking about is your starter solenoid.  If your car is a manual, put it in neutral with teh ebrake on.  Turn the key to the on position.  Take a screwdriver and jump the 2 bigger posts.  If your starter engages, then your solenoid is shot.  They are pretty cheap and easy to fix.  Keep the Dodge's alive!!  PLease rate!
Mar 11, 2009 | 1991 Dodge Daytona
Wont start
check all wires running from the batt to the starter motor. if the wires are tight and fitting quite well, its the starter itself. remove it and test for voltage and motor function at your local auto parts shop.
Feb 04, 2009 | 1996 Ford Taurus
Wont turn on
Well have you tried putting brand new fresh batt's in the unit? If they are rechargeable they may have simply discharged or if "normal" batt's they may just have gone flat.
Jul 14, 2007 | Uniden TR620 (14 Channels) 2-Way Radio
Fuji FinePix S5200 / S5600 Digital Camera Logo
37 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
