Question about Eaton Powerware® 9120 UPS System
I have a powerware 9120-2000VA that displays utility fail. what components do i need to replace?
My Powerware 9120-2000VA encounters Utility Fail.
4 Suggested Answers
pravinbhavsa
  • 348 Answers
SOURCE: we re having problem with the 9120 powerwere
open the ups and check whether the battery faulty or not if faulty replace it, if ok then check mosfet or IGBT used in inverter section if faulty replace it problem wil be solved
Posted on Mar 10, 2010
  • 45 Answers
SOURCE: is the fuse in a powerware 9135 user replaceble
There are numerous fuses (rectifier, inverter, charger, battery) on the 9135 that are located internal to the unit and not readily accessible to the user. Generally a blown fuse is accompanied by another component failure which caused the fuse to blow in the first place. As a result, additional troubleshooting and testing is usually required to identify the root cause of the failure. This of course leads to soliciting the services of a technician who has access to the schematics, test equipment, and parts to initiate a repair. Without the schematics, it's like working in the dark. For complete support, please contact Eaton (Eaton bought Powerware so now it's the Eaton 9135):
Toll Free: 1 800 356 5737
E-mail: SinglePhaseTS@eaton.com
www.eaton.com/9135
Posted on Jan 06, 2011
  • 45 Answers
SOURCE: i have powerware 935515kva ups.The
I suggest you give Eaton a call:
Toll Free: 1 800 843 9433
International: +1 919 871 1800
E-mail: LargeUPSTS@Eaton.com
You can view the manual here in the docmentation tab: http://powerquality.eaton.com/products-services/backup-power-ups/9355.aspx?cx=3
Posted on May 16, 2011
It turn on and give utility failure fault , Out put off
Remove all load.
Turn off UPS.
Start UPS.
If fail remains, check the fuses and battery.
Apr 04, 2015 | Powerware 9120 UPS System
I got charger failure alarm on display.
Unless new and hardly used - check the internal batteries. They might be worn out and fail to hold a proper charge. This to be able to deliver power when AC mains cuts out.
Jul 04, 2011 | Powerware 9120 UPS System
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
Powerware 9120 6000i model indicates a charger failure. It is the first time that we opened this unit and we do not know the location of the charger circuit (we do not have a schematic diag). Could you...
The charger in powerware 9 series 9120 6000i ,the fan is of a quality that it fails and the heat sink does not get sufficient cooling ,it runs on 12 volt ,i replaced it with a cpu fan from a mainboard on a pc and it works perfectly now. make sure that the fan is running else the charger might go in protection or can fail due to the transistor on heat sink fails.
Feb 08, 2011 | Powerware 9120 UPS System
I have a Powerware 9330 100kVA UPS. The configured password is unknown by me. I want to reset the password and want to know the default password so I can configure the system. Can anyone help me with this...
Powerware was purchased by Eaton and they continue to provide support for all Powerware products. In the U.S. call Toll Free: 1 800 843 9433 (International: +1 919 871 1800) or
e-mail: LargeUPSTS@Eaton.com. They can help you out with the password. The 9330 manuals and documentation are located here: http://powerquality.eaton.com/Products-services/legacy/9330-info.asp
Oct 06, 2010 | Powerware 9330 40 (A40401110031112) UPS...
We re having problem with the 9120 powerwere UPS...no backup when the utility (commercial power ) is not available...the UPS shut down, and all LEDs went off.
Mar 09, 2010 | Eaton Powerware® 9120 UPS System
Powerware 9125 power problems
Most modern ups units will not start at all without the batt, so disconnect the extra packs beg, borrow some new or old good batt blocs same spec as the original internal ones, as this is just a test any set of batts that is just ok will do.
fit them to the ups unit and see if it will start. if it will then you will need to replace all the batt blocs in the whole system.
If it does not start then the ups is faulty.
If you are not happy fitting /working with batteries then get a tech to do this work for you, batteries are very dangerous, they are always live and need to be handled with care at all times.
Hope this helps, thanks for asking FixYa
Jul 28, 2009 | Eaton Powerware® 9125 UPS System
Utility Fail
mother board gone bad
Apr 09, 2009 | Powerware 9120 UPS System
Eaton Powerware® 9120 UPS System Logo
447 people viewed this question
Top Eaton Computers & Internet Experts
Lawrence Oravetz
Danny Kuhlmann
Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
