Question about Microwave Ovens
I have a proline grill chef microwave GT77 but have lost the manual on how to use it. Where can I get another manual from
3 Suggested Answers
michaelcanto
  • 76 Answers
SOURCE: Instruction Manual Needed
The only ref online is http://www.espares.co.uk/parts/microwaves/proline/micro-chef-st22/p/1095/1169/0/542092
Any microwave cooking guide should walk you thru the steps
Posted on Jul 28, 2009
  • 8909 Answers
SOURCE: i have a magic chef
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Dec 29, 2010
SOURCE: Proline M-2020 microwave manual needed
Do you still want this - I have a paper copy which I no longer need
Posted on Jun 28, 2011
Clicking noise when going
Sounds like a high voltage arcing. possible transformer or insulation failure causing an overload. Not a recommended consumer fix.
Feb 28, 2015 | Whirlpool Jet Chef 31 Litre 1000 Watt...
Mco 153s can not find how to access oven light for replacement there does not appear to be access from above under filter no door solid metal only
On page 20 of your owner's manual:
To replace oven light:
1. Disconnect power at main fuse or circuit breaker or pull plug.
2. Remove the top grill by taking out the 2 screws that hold it in place. (See Figures 3.)
3. Remove charcoal filter.
4. Pull out the Lamp cover. (See Figure 4.)
5. Replace the light bulb with a 30-watt bulb.
6. Replace light housing to original position
7. Replace charcoal filter.
8. Replace top grill and secure with screws.
9. Connect electrical power.
Aug 10, 2013 | Magic Chef Over The Range Microwave
Looking for manual for Magic Chef MC-1004 microwave
We don't have anything but you might try contacting Magic Chef for a manual
Jun 10, 2013 | Microwave Ovens
My magic chef microwave, model # iMCO160S,lost power, not during use. I have checked electrical connection and is OK. Do i need to change a Fuse ?
Fuses are a common failure part. If the fuse, you can purchase ceramic types from Electronix: http://www.electronix.com
Sep 03, 2011 | Magic Chef MCD1311ST Microwave Oven
Proline Micro Chef ST 22 User Manual
google mauritron who may have it
Feb 21, 2011 | Microwave Ovens
I have a magic chef that has microwave grill conventional oven every thing works except microwave don't heat
Hope that helps.
Dec 29, 2010 | Magic Chef MCD1311ST Microwave Oven
Jul 28, 2009 | Microwave Ovens
Mar 27, 2009 | Microwave Ovens
Microwave Ovens Logo
57 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
