My aircon compressor is not runing what is de problem
Aircon compressor is not runing
    Top Expert:
  • Heating & Co... Master
  • 76,649 Answers
Low refrigerant charge is likely cause.
Posted on Feb 24, 2012
I have a 2004 lancer Es when I turn the aircon on after 15 minutes of driving I cant change the gears the aircon works fine but renders the gears useless and have to turn it off to continue to drive
There is no relationship between the air conditioning system and the gear box in the vehicle.
The engine operates the aircon compressor via the serpentine belt from the crankshaft pulley and if the aircon is operating normally the aircom compressor will not be faulty either.
If you are having problems with the gearbox it has nothing to do with the aircon system. The issue will be with the gearbox itself.
Dec 27, 2015 | 2004 Mitsubishi Lancer
1994 mitsubishi lancer aircon problem..is it possible to change the mitsubishi aircon motor to nissans aircon motor?
best talk to an a/con technican as there is a size/capacity requirement for compressors. While it may be feasable to fit another compressor it needs matching tx valve condensor and evaporator to work properly. He should be able to tell you if it will work or not
Jan 27, 2013 | Cars & Trucks
Aircon relay wiring burnt, squeaking sound heard from the compressor. Help? thanks.
Have your compressor check. Squeaking sound is caused by a metal to metal contact. Your compressor bearing needs to be replace, to get it aligned. So that the metal to metal contact will be eliminated. Reload your compressor with refrigerant, before getting it activated. Replace the burnt wiring and the relay. Since a lot of work must be done, it is suggested that you take this to the car aircon service
center.
Nov 03, 2009 | 1994 Nissan Sentra 4-Door
When switched to on, the aircon does not function.
check for power at compressor clutch if power and earth there is ok new compressor required. no power there check relay and fuses swap air cond relay with another one that looks the same in under bonnet fuse and relay box
Jun 21, 2009 | 1989 Toyota Corolla 2 Door
When its hot the aircon is not getting cold
If not low on refrigerant, Things that could be wrong are expansion valve inopt, condensor fan not working or possible bad compressor.
Dec 07, 2008 | 1992 Nissan Sentra 4 Door
Aircon Compressor problem
Im not that familiar with cars, but if this is a new (90 or newer) then the RPM going so high is because the fast idle switch. It does this to compensate for the extra power being used by the compressor, which isn't coming on at first. Is the electric fan coming on for the condenser coil at the same time as the compressor? You should have 2 fans, one is for the radiator water, the other is for the A/C. There are temperature controlled sensors for these fans on some models. Its possible that may have something to do with it.
Mar 05, 2008 | Heating & Cooling
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
