Question about Zanussi ZCE7551X Electric Kitchen Range
Oven programmer won't control the oven
Since the main oven element blew, the electronic timer won't control the oven. The timer is working, but when you set the timer the oven just stays on. I reckon the surge current (which also took out the main fuse) fused the programmer relay contacts, or some electronic equivalent (triac scr etc) I am trying to remove the front of the control panel to access this, but I can't figure out how to disassemble it
  • 1462 Answers
SOURCE: Zannussi Gas cooker
make sure clock is set properly - refer to your instruction book. to test if clock is in fact faulty, access the clock and bypass it by shorting together the two wires to the clock relay
Posted on May 04, 2007
  • 1462 Answers
SOURCE: Display clock failure so no main oven
check you have power to clock and if not, check wiring back to find out why not. to get oven working, you can bypass the clock by joining the two wires to the clock relay. these clocks are remarkably expensive
Posted on May 07, 2007
  • 7 Answers
SOURCE: OVEN PROBLEM
have you tested the element with a test meter /
Posted on Jan 07, 2008
  • 2692 Answers
SOURCE: element
No . Very reasonable. Common item at appliance parts places and not difficult to replace. Have you tested it with a light or ohm meter to see if it is bad? You will have to disconnect it to do so.  If you need more infor , just ask.
Posted on Jan 03, 2009
SOURCE: Oven Not Working and Door Catch Broken
If you turn the oven on and set it to the highest temperature you will see a black coloured cover plate at the rear of the oven with holes in. Located beind this cover is the oven element. THis after a few minutes at most should be glowing red, the fan then circulates the heat so that the oven reaches the required temperature. IF this is not glowing then the element is blown. If your house fuses tripped this is also a fairly good sign that this is the element. Zanussin provide a spare element for £48.50 but take 7 - 10 days there is a man called element man on the web, he provides the same for £24.50 and delivered in a day. I have had two elements go on me in 6 years... hope this helps ....Jack
Posted on Jul 29, 2009
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Oven won't heat to temperature
Does it reach the temperature and then back down, or does it take too long to get to your set temperature? Either you have a faulty element or a bad communication error with the main control board.
Sep 03, 2012 | Frigidaire FGB24S5A Gas Single Oven
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
When using the oven the electicity tripped; after resetting the breaker the oven does not appear to get hot; however the grill works, the light works and the fan works what could be the problem?
Sounds like the oven element has gone. When these elements go they often short against the outside casing of the element which is earthed (or should be). This trips the main trip switch in the house. Having tripped and cooled down, the element is now broken inside & won't heat up. Usually 2 screws to remove, either inside oven or outside at back. Element usually taken out thro oven. Take it & cooker info to your dealer & ask for replacement. Shouldn't cost much.
Jun 13, 2011 | New World Ovens
Lower element in oven will not come on I replaced with new one and still won't come on
You need a multimeter to do some fault-finding. Also, check for a (usually hidden) square ceramic fuse mounted inside the thermal insulation of some ovens. They go open circuit with age.
The multimeter is used to perform fault-finding on the oven's controls, (inc the fuses) to determine voltage presence. Sometimes the fuse holders themselves corrode internally, causing problems.
May 07, 2011 | General Electric Stove/Oven/Range Chrome...
The power went out and then the elements and oven would not work but there was power to the clock?
This solution only really applies to oven elements only. I haven't experienced it with hotplate elements as they are not normally controlled by the timer. When you have an electronic timer and there is a blackout the timer normally reverts to auto. function when the power comes back on. You have to set it back to manual before the oven will work. Turn the oven element to ON and the set it to manual. The oven element indicator light will light and the oven will work.
Feb 06, 2011 | Stoves 23 in. Premier TC600I Electric...
The main oven, fan assisted, blew the fan element. I replaced the element but the oven will not heat up. I have replaced the timer assy. & the thermostat assy. but it still will not heat up. When the...
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
Aug 14, 2010 | Hotpoint Ovens
I have a frigidaire oven, my wife touched the oven element with an oven mitt and blew out the main 100 amp house breaker. the oven does not work anymore but the burners are fine. should i buy a new element...
THE ELEMENT SOUNDS LIKE IT IS SHORTED BIG TIME TO TRIP 100 AMP BREAKER. I CAN'T SEE WHY A ELEMENT BEING TOUCHED WOULD DO THAT. CHECK THE WIREING TO THE ELEMENT AND MAKE SURE NOTHING ELSE HAS SHORTED TO ALSO CAUSE THIS PROBLEM, PLEASE TURN THE POWER OFF FIRST. BUT THE ELEMENT CAN BE REPLACED AND NOT THE WHOLE STOVE
Aug 28, 2009 | Frigidaire Ovens
Zanussi ZCE7551X Electric Kitchen Range Logo
Top Zanussi Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
