HP Pavillion 760n Warning immediatly back up your data
I cannot log onto windows. Computer froze so I shut down and cannot get back into windows
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    oops..that is not good..try it with F2 on launch to see if you can access setup..
    Problem Solver:
  • 18 Answers
Sounds like hard drive failure. If you have anything on the drive you cannot live without, leave it alone till you either install a new drive or can install it to another PC, then you can try to copy your data. The more you try to fix it the more likely it is you will lose data.
If you don't care about the data, try re-installing Windows using System Recovery. (Press F10 key repeatedly during startup)
Posted on Oct 28, 2008
    Scholar:
  • 195 Answers
Thats the problem, the computer was shut down improperly and lost all the pertinent info it needs to re boot. Next time the computer freezes up use Ctrl+Alt+Del to shut down. Insert your windows disk and restart your computer, thats your boot disk, you can either repair your windows or install a fresh windows. Good Luck.
    Genius:
  • 2,785 Answers
Plz check if you can get the bios screen. If yes then while booting press F8 key so that you can enter safe mode.if you can log in through safe mode then do a system restore to earlier date.If you cant log in through safe mode then you have to reinstall or repair your operating system
Hp pavillion dv6910us will not boot. Power, quickplay bar, touchpad, and dvd lights turn on only then immediatly shuts down no beep codes or fan sounds are heard.
The motherboard is the problem, common in HP, sub out the ram one stick at a time and try power on each time, remove main battery as a last resort. If none of these help the main board must be replaced.
Mar 23, 2012 | HP Computers & Internet
I have a hp pavillion 760n. The screen will randomly go black. The power is still on when it does this, but when you try to push the power button, it doesn't do anything. You can hold the power button down...
ohhhh that is OLD LEGACY gear. see yours here, RETIRED>?
https://support.hp.com/us-en/retired-products
x2 what message , pretend helper are blind as all are in text box.
does that Desktop monitor (no model stated) does its OSD screen work, (front of monitor) push menu key, see?
if yes monitor may be ok.
next is PC.
is the pC with 1 vga jack or 2?
if 2 try both jacks with your VGA cable. (wink wink)
more simple tests. ("do anything" to me means silent )
  1. monitor power on, OSD works. on demand (menu button)
  2. PC power on, fans run, do that hear them ever clean the beast in 10 years? or more>?
  3. does the Monitor show NO SIG or NO SYNC?
  4. does the CD eject work.?
  5. listen to that old hDD with ear, silient?
  6. no, no,no, then the PSU is bad.if its fan is dead it is dead .
  7. i can list 10 or more causes but wont. until above is answered. (like mobo modules shorted or shorted hdd /cd drive or shorted VGA card)etc, etc, its computer, not a toaster. -ergo complex.
  8. tell more get more.
  9. what OS? is this XP (the virus magnet)
Aug 04, 2017 | HP Pavilion 760n (P6320A) PC Desktop
My hp dv 8000 Pavillion laptop will turn on and then it immediatly shuts down after 5 seconds or so
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
and if this doesn't help
then try to take out the ram or memory chip from the computer and place it back.
Jan 12, 2010 | HP Pavilion dv8000 Notebook
I cant seem to log on
try starting in safe mode. hold down f8 when you turn on your computer until you get a menu with the option to boot in safe mode. once you successfully log on in safe mode, restart your computer and the problem should be cleared. if not, we can explore further options.
Aug 14, 2009 | HP Pavilion dv9000z Notebook
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Hp pavillion dv9000
boot in to safe mode and copy all your data from mydoc to other location.
press F8 after you power on your laptop go to safe mode...
Jul 19, 2008 | Acer TravelMate 2480 Notebook
HP Pavilion Laptop dead?
Try unplugging laptop and take the battery out. Put battery back in and plug back in. If that doesn't work It would recommend taking it to a professional. The good news is that your data on your hard drive should be okay.
Thanks
Todd
Laptop Guy
Apr 23, 2008 | HP Pavilion dv4000 Notebook
Computer won't boot with chime-ing
If it beeps in a pattern (example 2 long 3 short) then I would need to know the pattern. With that pattern I could try to determine when the faulty component is.
Jan 23, 2008 | HP Pavillion a818n Desktop PC (Refurb)...
Windows xp missing file and won't start up
Here's what I would do, because after reading around on that error message, it seems like you can't repair the problem.
I would find myself one of these: http://www.casecooler.com/3drto2dr.html
Take out your laptop's HD, hook it up to that convertor, slave it to a desktop, pull all your data that you don't want to lose to the desktop, put the laptop's HD back into the laptop, reformat/reinstall windows back onto the laptop, pull the HD back out of the laptop, hook it back up to that convertor, slave it back to the desktop, put your data back onto the laptop's HD, then put it back in the laptop.
That will leave you with a clean install that works on the laptop and you won't lose any data.
Nov 12, 2007 | Compaq Presario V4000 Notebook
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
