Question about Water Heaters
Instalation wiring diagrams for ecosmart eco 27
Part number for standard heating element for eco smart 11.3kw?
Go to ecosmartus.com
Click products tab at top of page
Click on your model number
Click on replacement parts tab
Buy part from ecosmart
Or remove element from water heater and look to see if threads are standard water heater element threads... then look at volts and watts printed on end of each element... buy ordinary element if it will work.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Gene
Mar 18, 2015 | Element Water Heaters
What does ECO failure mean on my hot water heater?
I'm guessing about model. I Goggled Eco failure. For reheme this site and discussion may help. http://terrylove.com/forums/index.php?threads/ge-rheem-power-vent-eco-failure-code-gg50s06rvj.43646/
but since it's gas, and an expensive unit I'd call the installer or his service.
Mar 08, 2015 | Water Water Heaters
Same sears 66 gallon water heater keeps resetting button after replacing both upper and lower theremostats and elements
1) Live answer Jan 2013.
Read why ECO trips and scroll down and read ECO keeps tripping:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#ECO
Check that thermostats are sitting flat against tank.
Look and smell for signs of burning.
Check watt rating printed on end of new element matches watt rating that shows on label on side of tank
Make sure factory-installed installed insulation is put back over thermostat and element to avoid cool room temps from affecting thermostat.
Test wires.
http://waterheatertimer.org/How-to-test-water-heater-wires.html
Make sure tank is wired correctly.
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
2) Add comment and say what you discover
Jan 02, 2013 | Water Heaters
Water heater
Guessing that you have 240Volt residential non-simultaneous electric water heater? And that you have 30 amp breaker and 10 gauge wire. And that water heater is located within 100 feet of breaker box. And there are no leaks running hot water out of tank. And that you installed fully brand NEW elements of same wattage as old elements. And that fully brand new thermostats were installed, and wiring exactly duplicates wiring that was present before. And that factory-insulation was re-installed over elements and thermostats.
1) Guessing the 'hot water shut off' means the ECO red reset button located on upper thermostat keeps tripping and cutting off electric power to water heater?
2) If the ECO is tripping, then water is getting too hot, or there is shorted wire located near the upper thermostat, .
Typically replacing both thermostats and replacing elements will solve this problem .... assuming that new thermostats and elements are good, and wiring correct.
Double-Check your wiring on upper and lower thermostats.
Test wires for short.
Make sure factory-insulation is re-installed over thermostats so cool room temperature will not affect temperature reading.
Check that thermostats sit flat against steel tank.
Many short draws hot water can also cause stacking event that will trip circuit breaker.
3) Add comment and say what you find using checklist above.
Be careful to explain findings fully, using same words found on links above, so illuminated diagnosis can be made.
Dec 28, 2012 | Water Heaters
Automatic restart is not working. Seems to keep saying eco problem...I thinl...the code is four flashes followed by two flashes.
Gas control valve is not identified, so error code is not known.
ECO means energy cut off.
Energy cut off happens when gas control valve thermostat has gone bad, or when gas control senses runaway heating inside combustion chamber.
Newer heaters have resettable ECO for combustion overheat. This reset is typically located on combustion chamber door and is round and has two wires that connect back to gas control. Generally you have to clean combustion chamber and tubes and catch up on maintenance, then reset ECO, then fire up heater again to see if problem is resolved.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
Newer heater does not have reset for bad thermostat, and in that case you replace gas control valve thermostat.
Older heater does not have reset, and combustion chamber and parts are cleaned, and gas control valve thermostat is replaced.
Your manual is best place to start troubleshoot.
Open following link to help identify gas control valve:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Jul 10, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Atwood GC10A-3E and the gas is working fine but the electric is not. i checked the element and went ahead and replaced it since i had it out anyways. i then relized that one of the wires had been...
Sounds like the new thermostat and ECO you installed, You may have got them mixed up. The ECO will have a small reset push button in between the 2 spade connectors. The ECO should be second in line, as in power to it comes from the thermostat. Hot (black) line from switch goes to thermostat first, then from opposite spade on thermostat to spade on ECO, then out from ECO to element. Double check wiring or positioning of thermostat and ECO, and correct as needed, and make sure to push reset in center of ECO, then try again. Be sure both are touching up against tank well too.
The thermostat has a little lower temperature setting, and if it fails, ECO takes over and cuts out at a little higher temperature. That's why I suspect they got mixed up, otherwise thermostat (without reset) should have cut power at proper temperature, unless it's faulty, or not touching against tank properly.
Let me know how you make out and what you found.
Feb 10, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I awoke to no hot water, my heater is three yrs old and i just changed my upper and lower element and upper thermostat, still no hot water then i checked to see if i was getting power and i am, is there...
Your water heater has 2 elements so its 240Volts.
1) If breaker is delivering power on one leg of the 240Volt circuit, then water heater can appear to have electricity, but tank is receiving 120V. Both 120Volt legs are needed to complete the 240V circuit. Double check for 240Volts.
2) Review electric Load.
Water heater label shows wattage of tank.
If tank is 4500Watts for example, you installed 3500 or 4500 watt elements.
With 5500 Watt elements you need 30 amp breaker and orange-colored 10 gauge wire
With 4500 Watt elements you can get by on 20 amp breaker and 12 gauge wire up to 75 feet away.
3) Check ECO red reset button on upper thermostat. If reset is tripped, then ECO is reading high temperatures. Suspects at this point are defective upper thermostat, shorted wire or bad lower element.
4) Also note that insulation and cover must be re-installed over thermostat. Thermostat reads temperature through wall of tank. If outside air circulates around thermostat, that can cause a mis-read and cause tank to overheat and ECO trips.
If you don't want to test the heater, replace both thermostats for about $25. Return the upper thermostat for a refund. Then see of problem persists.
Here's what I would do.
1. Check breaker for 240
2. Check water heater for 240 across 1 and 3 screws on upper thermostat
3. Note wiring and breaker size.
4. Note label on side of tank.
5. Look at end of new element to see wattage printed on each element. Look for sings of high heat and burning. Tighten screws on elements.
6. Check ECO reset button. Look for high-heat and burning. Tighten screws on thermostat.
7. Test upper thermostat as follows:
http://waterheatertimer.org/images/Electric-diagram-water-800.jpg
Test left-side #1 screw to right-side middle #4 screw. Test should read 240V at all times. If not, then ECO is tripped, thermostat is bad, or electricity is OFF
8) Water heater is cold so upper element should be ON. Test upper thermostat.
Test right-side #3 screw to left-side bottom #2 screw and it should read 240V
Test right-side #3 screw to right-side bottom #4 screw and it should read 0 volts
8. If upper thermostat checks out. Test upper element for 240 across both screws. If upper element does not read 240 when water is cold, then element is bad or there is a shorted wire between element and upper thermostat.
How to test element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
9. Do a full troubleshoot on electric water heater
Dec 07, 2010 | General Electric GE SmartWater Household...
The red button keeps poping causing the hot water heater to shut off. I have to constantly reset it.
The red reset button or ECO or energy cut off turns off power to electric water heater.
The ECO responds to temperatures in excess of 150 degrees F.
Preliminary work:
You can use thermometer to check water temperature immediately after ECO trips.
Compare water temperature against the thermostat setting.
There are 4 things that can cause ECO to trip:
1) Bad thermostat is sticking and letting element continue heating water, or ECO is reading incorrect temperature.
2) Factory installed insulation and cover missing from tank, and thermostat is exposed to cooler air and misreads tank temperature.
3) Element shorted to ground in center of element. This completes 120V circuit to ground which will cause element to continuously heat the water.
4) Loose wire near ECO causing high-heat electrical event.
Solution:
Check for missing insulation.
Check screw terminals for signs of high heat and burning >> tighten screws.
Replace both thermostats using detailed instructions given on link below.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If the problem continues after replacing thermostats, more troubleshooting is needed:
For more self-help information about your electric water heater:
http://waterheatertimer.org/Do-it-yourself-water-heater-timer.html
For more help, add a comment and I will respond
Nov 04, 2010 | Water Heaters
Light flashing - lockout condition - ECO failure
The ECO is designed to shut off the water heater in case of the water heater overheating. This is to prevent the water heater from exploding. I assume that you have a newer style residental water heater or a commerical boiler. The ECO is a fuseable link that is built into the control and located at the thermostat probe. If the water heater overheats then this link will melt cutting the circuit on the millivolt system(residential) or 24volt system(commercial boiler). If you look under the water heater control(where the temp adjustment is) there are usuall two wires that go from the control to the water heater. These are the ECO wires. Verify the wires have not been cut or damaged. If these wires are cut or damaged then the ECO circuit will be incomplete and you will get the ECO lockout failure. Also make sure that the flame lock-out switch is not tripped. It will be located at the burner compartment cover and have two wires going to it. Most have a little button in the center. These are to sense high heat and one might have tripped closing the circuit. You can push this little button to re-set the switch. If you feel a little "click" then the switch was probably tripped. If it does not have any button then it might be "self resetting". To test that switch use a continuity tester and the circuit should be closed. If these switches are working then the fusable link for the ECO is probably bad from the water heater temp getting too high or was defective and failed. This will require you to remove the water heater control valve and replace the fusable link. If you do not have experience with this I suggest you call a licensed plumber to make the repairs. If this repair is improperly done it could void the warranty on the water heater and/or cause property/personal damage or injury. There is a possiblilty that your water heater thermostat had failed causing the ECO to trip. If that is the case then the ECO safety did it's job.
Jun 26, 2010 | General Electric Water Heaters
Water Heaters Logo
54 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
