Where can I get the best Hp 484170-001 battery ?
I almost always buy from batteryfast.coml for all my laptop battery. Their selection is amazing.. Always a good expierence.
  • 27,725 Answers
Http://www.ebay.com.au/itm/Battery-HP-COMPAQ-482186-003-484170-001-484170-002-484171-001-485041-001-/230692617091?pt=Laptop_Batteries&hash=item35b659fb83
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
http://www.paypal.com/
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps you
Posted on Feb 25, 2012
Tip
Batteryfast.ca now becomes the outstanding destination in online laptop battery...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on May 11, 2010 | Computers & Internet
How to care my hp dv5 battery? buy the hp dv5 battery from http://www.batteryfast.com/hp/pavilion-dv5.htm
For long life battery:
-Don't play computer games, music or DVD movies - Multimedia activities drain laptop batteries.
-Disconnect all external device like PC Card modems, Firewire, USB devices and optical drives. Use the notebook touchpad instead of an external mouse.
-Adjust your screen brightness - Dimming your display saves battery power.
-Tweak Windows Power Options - Choose a Laptop power scheme that turns off the notebook monitor and hard disk after 10 minutes of inactivity.
-Decrease or mute the Laptop Speaker Volume.
-Programs that are run from a CD or DVD can be copied to and run from the hard drive, which typically consumes less power than an optical drive.
Mar 19, 2012 | Computers & Internet
How to care my Acer as07b31 Battery ?
Before you use the battery, charge for 24 hours, that will give maxium time that it will last.
Mar 18, 2012 | Computers & Internet
How to test my Dell vostro 1310 battery? buy the battery from http://www.batteryfast.com/dell/vostro-1310.htm
When I replace a laptop battery I charge it up to twenty four hours before use, because the end result is longer life and staying power. This will allow you to properly evaluate the battery under normal use.
Mar 06, 2012 | Computers & Internet
System error appears,camera cannot use.pls help me what to do.thanks!
batteryfast.ca now becomes the outstanding destination in online laptop battery field. We focus our minds on supplying high quality discount laptop replacement batteryfor you to save more money and get more surprise. Meanwhile, we havesuperior customer service here to ensure you shopping enjoyment fromplace order to shipment to after-sale. In our online shop you canselect a full range brand discount laptop battery which including Acer, Apple, Compaq, HP, Fujitsu, Dell, IBM, Sony, Toshiba and so on.
May 14, 2010 | Nikon Coolpix 880 Digital Camera
Toshiba Tecra 8000 doesn't see battery
I've precisly the same problem, but mu battery reaches 15% or so, but then the orange led goes of, and the laptop says there's no battery present. It is probably a problem with your BIOS, and in needs an update, but you'll need a Floppy drive to update the BIOS.
Grtz. Tom
Jan 18, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
