Question about Speed Queen SWT920 Washer
Have a model SW1T which is not responding to the token when inserted. the in use light remains on but the machine does not start.
We had a power surge from the supplier when the machine was operating. The machine was starting to fill with water when this took place resulting in the machine not starting up again once power was restored. The IN USE light remains on when there is power and if one inserts a token the machine will not restart. Maybe there is a safety mechanism which has been triggered. Your assistance will be appreciated.
3 Suggested Answers
  • 9 Answers
SOURCE: Machine starts to fill up
Sounds like faulty pressure switch
Posted on Apr 03, 2011
  • 19 Answers
SOURCE: My speedqueen top loader starts
There is a reset water level function on the front panel. To alter the water level each time you need to reset your water level . Ours used to do the same thing before my wife realized she was over filling it.
Posted on Jul 26, 2011
How do I fix a 4flash red light error
Based on the information you have provided for your model and the issue you are currently having with the red light flashing 4 times, we would like for you to try the steps available below:
  1. Unplug the television power cord from the electrical outlet.
  2. Disconnect all devices from the TV.
  3. Let the television remain without power for 2 minutes.
  4. Plug the power cord back into the electrical outlet.*
  5. Turn your television on.
* If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Copied from someone else's post. I agree with the steps this person posted.
If this does not work call the manufacturer. You could see how much it would be to fix vs. the cost of buying a new one.
Jul 29, 2016 | Sony BRAVIA Televison & Video
Keyboard won't respond after power surge
It's possible the keyboard was damaged with the loss of power. Do you have another usb slot to try? You can try updating your drivers sure but there is no guarantee that will help either. If you want to do that try using an automatic driver updater. It will quickly identify your hardware and locate the proper drive for each device.click and get a free scan. I recommend scanning your system at least once a month to make sure your driver stay up to date
Dec 09, 2012 | E-Machines eMachines Desktop PC
Flashing Lamp light, no picture KDG42WE655
The Lamp light of the TV blinks when the Lamp of the TV requires replacement. The model # of the user replaceable lamp block is XL-2100U. You can download the manual of the TV by clicking here. Refer to page # 16 of the manual for further information. Follow the steps below to perform a power reset first:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Let the television remain without power for 60 seconds.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 16, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
My AT is "surging" and seems to be cycling between
Check all connections. Most likely, something is not firmly in place. Unplug the machine.
1) Make sure the plate is inserted into the grooves, top and bottom.
2) Make sure the contact "fingers" press firmly onto both sides of the plate.
3) Make sure the plug is inserted FIRMLY into the back (MOST COMMON PROBLEM).
4) Make sure the back screen is inserted firmly, and that the safety switch is depressed by it.
5) Make sure that the outlet is not on a line with heavy power users, like a furnace or refrigerator.
Jan 19, 2011 | Ecoquest Breeze AT Living Air Purifier
My General Electric microwave shows RESET on the console but none of the buttons are responding even though i have plugged and unplugged it a couple of times
Good day Sir, here's troubleshooting tips.
Problem: Oven will not start
possible causes: power surge/plug not fully inserted/door not securely closed/start pad not pressed.
Jan 24, 2010 | General Electric Microwave Oven
Touch pad always lit up...
Yes, if the leds are all lit and no respnse, then your board in the top counsel is faulty. Have you haad any power surges recenlty.? Power surges sometimes mess up computer boards. But yeah, it sounds like its bad tho. There should be led light on unless you start pushing buttons. Have you hit the "off" selection. If nothing turns off the led lighting, it sounds like the board might be bad...hopefully this helps
Jul 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
The upper oven door is locked shut and will not release. All lights are off on the display panel and the oven does not respond when any setting are pushed. I have reset the circuit breaker several times...
im to assume that this happened while self cleaning, sonds as if you have had a high limit thermostat go bad adn has shut down oven function( depending on model there is also a fuse inline with the main control panel to protect it from the heat/ power surge, unit will need to be pulled out to acess fuse behind the unit
Jul 09, 2008 | Whirlpool RBD245PDS Electric Double Oven
Whirlpool Duet Sportwon't respond after power outage
IF YOUR MACHINE IS A WHIRLPOOL DUET TRY THIS ;
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Good luck
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Computer not starting up
Try Cleaning Ram Fingers with rubber and re inserting could be a bit of corrosion or moisture/fluff this often works
Feb 01, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Speed Queen SWT920 Washer Logo
47 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
