Question about FujiPlus FP-7688B 17" LCD Monitor
Fuji Plus 17" LCD
Have had monitor for over a year. Worked fine. Now the screen is black. The green light to indicate power goes on but no change on screen. When the PC is turned on the power light turns to red. Is the LCD monitor shot and needs to be replaces or is there a work around? Also need number to call company/tech support.
Thanks,
Mitchell
  • mrs_red Dec 15, 2008
    Does anyone have a schematic diagram for the FP-7688b?
3 Suggested Answers
SOURCE: LCD screen goes black repeatedly
Have you checked the light on your power supply? My monitor will go black and I noticed the light on my AC power supply was off. It was very hot so I unplugged it and let it cool down. When I plugged it back in my monitor worked fine until the power supply started to over heat again.
Posted on Jul 05, 2007
SOURCE: Dark screen
Please TRY to check what other drivers you installed meanwhile. For this start again with a simple Keuyboard and Mouse...and a different monitor....Reboot the PC, and than change/ad one by one, drivers and new hardware, with rebooting the system(OC0 in between the stepst...I had the same problem...I was willing to "dispose my new HP Pavillion 6130.This was happening after upgradind, an extra hard drive, a new webcam, a new wireless kewboard/Mouse....Now all is OK...
Just be calm and take yout time....
Reboot the
Posted on May 17, 2008
FP-768 (Silver, Black) (Black, Silver) 17 in. Flat Panel LCD Monitor: My screen goes haywire with all kinds of color cha...
The vertical lines/bar are sign of bad T-CON (LCD controller driver) board is bad, it is part of the LCD panel assembly, new screen will be needed, not worth it. You may try reseating the ribbon cable at the panel.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
May 16, 2010 | Fuji FP-768 17" Flat Panel LCD Monitor
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
IBM ThinkVision 17" Monitor displays for 1 second then black
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Jan 25, 2009 | IBM ThinkVision L170 17" LCD Monitor
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Dark screen
The problems it the inverter is burnt out... Need replace new inverter. contact me, I'll give you a good price. repair@3rd-rocks.com
Dec 06, 2007 | Fuji FP-988D 19" Flat Panel LCD Monitor
Oct 25, 2006 | Fuji FP-988D 19" Flat Panel LCD Monitor
Computers & Internet Logo
69 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
robert
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
