Removing encryption key
To open a locked memory card, select Options > Unlock memory card. Enter the password.
If you cannot recall the password to unlock a locked
memory card, you may reformat the card, in which case
the card is unlocked and password removed.
Formatting a memory card destroys all data stored on
the card.
Encryption
Select Menu > Tools > Encryption.
Encrypt your device or memory card to prevent
outsiders from accessing your important information.
Encrypt device memory or memory card
To encrypt the device memory,
select phone memory.
To encrypt the memory card, select memory card from the following:
Encrypt without saving key
• memory card without saving the encryption key. If
you select this option, you cannot use the memory
card in other devices, and if you restore factory
settings, you cannot decrypt the memory card.
Encrypt and save key
• and save the key manually in the default folder. For
security, store the key to a safe place outside the
device. For example, you can send the key to your
computer. Enter a pass phrase for the key and a
name for the key file. The pass phrase should be long
and complex.
Encrypt with restored key - Encrypt the memory
• card with a key you have received. Select the key file,
and enter the pass phrase
how to remove memory card pass word
Add Details to Your Question
