Question about Nokia Mirafone OP201 Phone
How do you turn off ringer
I would like the phone to light up but not ring
  • Nokia Master
  • 1,800 Answers
U gonna find a switch on the side of the phone
pls to ring switch it to pulse or off
plz do rate this post as good as u can so i can help u out further!
Posted on Oct 28, 2008
How do I reenable the ringer on my ATT 993 phone. The phone does not ring
Make sure to look on the phone itself, and see if there might be a button on the unit, or base station, that turns the ringer on/off.
Feb 21, 2015 | AT&T High Quality ATT 993 2 LINE...
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
My phone is ringing but cannot hear the sound only blinging the light. So how can i return back the ring sound?
Only 3 things make it not ring, there's a switch for the ringer on the left side of the phone, it needs to be programmed to ring in the 40x's, or the ringer is defective. If it rings on the intercom (with the AUTO ANS) turned off, it must be programming.
Carl
Jan 24, 2011 | Panasonic KX-T7730 Corded Phone
Line 1 stopped ringing. The light lights up but does not make a sound. This is the 2nd unit we have had to do this
To program the ringing on the cordless handsets:
Press {MENU}.
2 Scroll to “Ringer setting” by
pressing {V} or {^}, then press .
3 Scroll to “Ringer volume” by pressing
L The current volume is displayed.
4 Press {V} or {^} to set the volume.
L Each time you press {V} or {^}, the
volume will alter and the chosen volume
will sound.
L To turn the ringer off, press {V}
repeatedly until “Ringer off?” is
displayed.
5 Press .
L Confirmation tone is heard.
Sep 13, 2010 | Panasonic KX-TG4500 Phone
The phone does not ring. How do you turn the ringer back on? The phone model is a hybrid system kx77020.
There's a ringer adjustment on the side of the phone. Does it ring in another jack? Does another phone ring in this jack? Panasonic system ringing is controlled by system programming, usually 408-410 or somewhere near there. If the phone works in another jack or another phone works in this jack, then you need to either turn on the ringer or turn on ringing at that port.
You may have to find the programming in the manual, or call your service tech.
Carl
Sep 03, 2010 | Panasonic KX-T7730 Corded Phone
Ringer rings on other desk now, not mine. LIght
Trying pressing that light and 1 key. Sounds like a night transfer key is on. This will work if you have a CTX system.
Nov 06, 2009 | Toshiba EKT 6010 S Corded Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
How to turn on the ringer
While the phone is not in use, press the up arrow until you get the ringer volume you want.
Jun 28, 2008 | Uniden Cordless Phone
Uniden Phone
goto the name and hit store it will restore the name and when going threw the store process it should show you old parameters
or goto phonebook find name and edit its preferences for that name phone ringers are set ringers so when you pick one for gereral use thats going to be the general use ringer but special ringers is what i descriped in first part
menu handset setup then ringers for a general ringer you can change to a more pleasing ringer but over all cant turn off
May 10, 2008 | Uniden Cordless Phone
Nokia Mirafone OP201 Phone Logo
Top Nokia Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Nokia Lands Phone Expert? Answer questions, earn points and help others
