Question about Konica Minolta DiMAGE Z5 Digital Camera
Problem with Shutter/Lenz
When the camera is turned on it makes a noise as if it is having a difficult time setting up the lenz/shutter. This last a few seconds. Then I see dark semi circle on the corners of the display as I point and view through the small "window". After I take the picture, the picture also displays the dark semi-cirle. A few times I have tapped the camera with my palm and have noticed that the semi-circle moves to another corner or dissapears, only to re-appear when I turn it on again. HELP!
Gentle tap did not work for long. I am certain that whenever tap worked it was because the CCD sensor moved to centre. I noticed that I would aim at something and image woud show at angle down. Colour tint was at fault too. And... after deliberation I decided to open my Z5 as I was not happy to scrap a decent camera. Not yet at least. Culprit seem to be a spring that pushes the CCD assembly against a slide guide. It took 30minutes and numerous failed attempts before everything came right. You will need to peel off rubber hand grip on right hand side and just a small part on grip on left hand side to gain access to some screws. Do not remove trigger/macro/flash panel as it is not needed. Once opened, remove 4 screws that hold 5cm LCD display and disconnect all the plugs you can see (except the one on the top right side that is directed towards the batt bay). Gently pull LCD and first layer PC board. Disconnect all the remaining plugs (you must know). Remove flash unit. Lens and CCD is attached to the body by means of 3 big head screws. Taking all out makes your work easier. There are 3 springs holding CCD in place: 1st in upper right corner and it is a plain stretch spring. 2nd is upper right side, it is a circular spring that has 2 levers. 3rd one is same as 2nd but it is at bottom middle. In my case 3rd spring came off, I guess after camera was bumped or dropped. If you managed to repair your Z5 using this instruction (without damaging anything else inside the camera) than you can thank me on djenka018(at)hotmail.com No need for anything else. Djenka NOTE! NOTE! NOTE! NOTE! NOTE! NOTE! NOTE! NOTE! NOTE! Beware, I have 15 years in electronics repair. It was no simple task for me. There are many flat cables that tear easily (rendering your camera useless) and I found this repair on scale 1-10 to be at level 9 due to small and gentle components.
Posted on Aug 11, 2007
I do not think it is shutter to blame as with 'semi cicrcle' a "anti-shake" error is displayed (red hand). It is more to blame anti-shake as the noise that comes at power up is from it bouncing left-right or up-down. Will try getle tap at powerup on my Z5. TNX
I guess you already had your camera fixed, but I was having exactly the same problem with my z5. I solved it by gently tapping the camera against the palm of my hand while starting it up. No violence, just a gentle tap! A few bucks (250 or so) cheaper than having a tech guy do it... :)
Posted on May 08, 2007
    Novelist:
  • 107 Answers
This sounds like a stuck shutter. There is a delicate assembly inside your lens that will block the light right when you snap the picture allowing the image sensor to record what it saw at that very moment. This shutter is composed of two blades that come from either side of the field of view and overlap to completely block the light. It sounds like what has happened to your camera is that one of those blades has either come off its guide or has become stuck. The shutter assemblies in these cameras seem to be very delicate and sensitive to even minor impact. Due to the anti-shake features it will have to be returned to the manufacturer for service if you want to get it fixed. David Millier Advance Camera Repair
Posted on Feb 27, 2007
Lenz are still
You should take it to the photo shop to ask for repair service, I guess it works! Impact from shock(fall) can misplace the components in the camera and it can't resolve by only turning on and off the camera.
Apr 24, 2013 | Fuji Film FinePix JX500 14 Megapixel...
Forced shutter switch open now it wont close and the switch is loose. How do I fix this?
Please take the camera to a sony repair centre you might brake something els
Dec 19, 2011 | Sony Handycam Video Cameras
Blurry pictures, flash timing is off
do you use a lenz cleaner on the lenz of the camera
Dec 07, 2011 | Canon PowerShot A520 Digital Camera
The shutter release button is missing .What would it take to replace it? Many thanks , Donald Elliott
dear sir,
kindly take your camera to authorised olympus service centre and get it repaired,also plz dont operate ur camera without the button,it might affect ur lenz very badly....
thank you...take care
Oct 08, 2010 | Olympus FE-340 Digital Camera
Best settings to capture fireworks?
It's a little difficult with this camera since the slowest shutter speed is 3 secs. You need to have the timing right to get the best result:
Set mode dial to M, Select shutter speed with 4-way switch up and down : 3 secs. Now select Aperture: Hold down +/- button and select aperture with the same 4-way button, up and down. Choose F8, which is the smallest opening. You need to have the camera on a tripod when taking the picture. If the picture gets to dark, adjust the aperture. If it gets to light, you adjust the shutter speed, making the timing even more difficult.
Jul 05, 2010 | Fuji FinePix E550 Digital Camera
My camera samsung lenz keep saing CARD LOCKED when I turn it on
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Apr 16, 2010 | Samsung L100 Digital Camera
My canon powershot A470 digital camera has no display on screen only the menus are displayed.
i thinh taht s shutter prblem,
plz turn on ur camera and luk shutter through lenz,
(if d shter cant open during the snapng time...)
Aug 04, 2009 | Canon PowerShot A470 Digital Camera
My sony camera gives this message and lenz will not close.
    This message appears when the lens assembly start malffunctioning. Therefore, You have to replace the Lens Block Assy. For this plz contact any nearest Sony Service Centre nearby to u.
Thanks for using fixya!
Take care.
Mar 11, 2009 | Sony Cyber-Shot DSC-S90 Digital Camera
How do I clean the interior of the lenz for Powershot A640
Its a big job, If your petty handy, You have to start from the back of the camera, Remove rear cover,Then front cover, Next lcd Display unit, Hopefully your haven\'t put the battery\'s in the camera for a while because the flash has high voltage in it, if you have, You must discharge first, them take circuit board out,Then lens assy, Now the fun part, You have to take the lens apart from the back also, Like I said its a big job, Better when you get this far into the camera you just replace the lens, with a used one form a diff camera (same model )
Feb 25, 2009 | Canon PowerShot A640 Digital Camera
SAMSUNG DIGIMAX A 7
Sounds like a power issue. Make sure you use the recommended batteries. Also, some cameras have settings to where you need to change it in accordance to the type of batteries you are using. exp. alkaline, ni'mh, etc.
Dec 31, 2007 | Samsung Digimax S700 Digital Camera
Konica Minolta DiMAGE Z5 Digital Camera Logo
256 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
