Question about Canon NP 6050 Copier
Error code E004
I have an old Canon NP 2120 copier. The error shows 004, which indicate fuser problem. A while back, when a service man visited me to fix something else, he told me that the drum need to be changed. So I bought one from him to change it later when it would show problem.
Now, I think, I need to change the drum, but I forgot how to change it. He showed me how, but it was a long ago. Could you help me how to change the drum?
Thank you very much.
Below, I used NP6050 copier because I could not find my copier name, NP 2120.
  • 1 more comment
  • pkhkim Oct 28, 2008
    Thank you very much for your help. Before I received your reply, I figured out how to change the drum, and tried to change it. As you said it did not work.
    Is the fuser lamp or thermofuse something that I can change myself? Or, do I have to bring the copy machine to the shop?
    Thanks,
    pkhkim
  • pkhkim Oct 29, 2008
    I am not sure whether my previous reply went through, so I am posting it again.
    Thank you for your "If you are handy I can walk you through it" offer. I would like to go through it with you. How can I do it? Should I call you? My phone is 847-680-2459.
    Thank you.
    Kim
    Thank you very much. I was expecting it would be a long distance call, and I would be happy to call you to get your help. But, as you suggested, I will try to follow your suggestion. So, I will be looking forward to receiving your detailed replacement note. I really appreciate it very much.
    I thought you are in the place that I can purchase the parts, but I will try the places that you suggested.
    When I receive your instruction, I will study them and order the parts, and try to replace them.
    Thank you again,
    Kim
Thank you very much. Should I call you? My phone is 847-680-2458.
How can you walk me through it?
pkhkim
Posted on Oct 28, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
The error has nthing to do with the drum!!!!!!!!!!!!!!!!!
I can tell you how to change it,but it will still have the code.
You have either a blown fuser lamp or thermofuse, you should change that before the drum since you still won't be able to use it?
  • 2 more comments
  • CheckitRight
    CheckitRight Oct 28, 2008
  • CheckitRight
    CheckitRight Oct 29, 2008
    Hi Kim,
    I'm in Florida, it would be long distance, and probably take a few hours, I'll walk you through it over the net, I think I can give a pretty good and thorough explanation of how to do it.
    do you need a parts place to order it??
    try these :
    precisionroller.com
    feedroller.com
    parts.now.com
    i'll send a detailed replacement note.
    Also, you should definately think about replacing these parts it will make life easier and keep the machine running longer and trouble free. The 2020/2120 is a great copier when running and kept in shape.
    Consider changing :
    1- Oil roller
    2-Claws/scrapers
    3-upper and/or lower fuser rollers ( they should be shiny with no scratches or defects)
  • CheckitRight
    CheckitRight Oct 30, 2008
    Allthough I have not worked on one in a few years ( the last client I had w/a 2120 I replaced all the said parts and he hasn't had a problem in 2yrs!!! great for him but not so good for me, anyway he's happy)
    This is a long procedure, not too complicated just a lot of steps. I suggest you put everything you take off next to each other with their screws and parts.( HAVE A NOTEPAD AND WRITE SOME STEPS YOURSELF/there is a possibility a may have forgotten a screw or step)
    RECOMMENDED PARTS
    thermofuse, fuser lamp, upper and lower rollers, oil roller (always have a spare, replace when all blk or dry), scrapers and bushings (either a set or 2 if individual) look at bottom for pix.
    1-turn off power and let fuser cool down
    2-lift ADF or top cover
    3-open front door and left side door
    4-remove the Back panel (4 screws) set aside
    5-remove the glass holder bracket ( 2 screws / this holds the copy glass in place)
    6-If you have a sorter move away from copier and remove the sorter bracket that is attached to the copier ( 2 screws)
    7-remove the side panel it will include the top left of the copier along with the side
    (you may have to remove the side door panel)
    8-remove the green handle 1 screw / located inside the front left when you open the door
    8-remove the screws holding the fuser 1 on each side
    9-remove the connections 2- one big one and a smaller white tip one on the left
    10-take out fuser set on a table where you have room to work
    remove the oil roller assembly located on top of the fuser ( no screws just pull)
    11- check the fuse, 2 screws remove and do a continuity check, if bad replace
    11-check the lamp , this is a lamp that is the same lenght as the fuser and is Inside the top fuser
    12-it has a bracket on both ends to hold the lamp and each end has a connector
    I beleive the easiest one to remove is the one opposite the male plug, not sure if it's a plug in or screw anyway remove it and the backet holding the lamp and look at it
    if its bad you will know right away it will look burnt and smoky inside it, if not it will be clear
    if bad, detach the other side of lamp and pull out.
    If changing fuser rollers
    13-remove clip holding gear ( set aside/do not lose/ pop off w/ flat screw driver)
    14-remove bearings on each side held by a screws / pop out
    remove bushings NOTE THE DIRECTION OF THE BUSHINGS
    15-remove rollers and replace NOTE THE DIRECTION OF THE UPPER ROLLER
    16-time to reassemble
    17- put the bushings and bearings on/ for the bearings to fit you will need some pressure to make it go back in. DON'T FORGET THE SCREWS for the bearings.
    Scrapers/claws/ fingers replace ( causes jams if worn) requires patience, do one to
    get the feel, has to have the spring.on each ( they should already be there)
    From here just go backwards
    take a look at the steps and Identify the parts to see if you understand. Let me know and good luck
  • CheckitRight
    OOOps made a mistake the small connector for the fuser is on the RIGHT not the left
Error code E004
According to the copier error code this is the problem of abnormal fuser temp. First check the electric outlet, where you have plugged the copier and also check the dc controller. Then fix the heater & ac driver also.
Jun 17, 2011 | Canon NP 6050 Copier
Error e000004-0010 how to solve
I'm not a Canon Copier Tec but I know E04's on Canons generally means heat/fuser error - ie fuser, usally fuser lamp, thermister or thermal fuse. Have fuser replaced.
Have it looked at, due to it requiring electrical knowledge, ie test heater lamp(open), thermal fuse(open), thermister(check for toner built up on face) with the user removed from printer (fuser=hot bit that paper goes threw, just before where paper exits to go to sorter) or just replace assem.
There maybe a reset required, on some canon models after problem has been fixed.
So here is a link with explaination of the reset on a canon model simular to yours http://www.copytechnet.com/forums/canon/2673-error-code-e004-canon-np-6330-a.html
pls vote me to keep us alive
Nov 17, 2010 | Office Equipment & Supplies
I have an error in my machine canon np 6050 error
"E004" Abnormal fuser temp. (fixing heater, dc controller, ac driver)
http://rapidshare.com/files/161024133/NP6050sm.rar
That link above is for a service manual. Copy/Paste that address to address bar..
Apr 23, 2010 | Canon NP 6050 Copier
Canon NP 2120 Copier that is giving Error Code E004 on power up. Any solutions?
E004 CODE IS FOR FIXING UNIT TEMPERATURE IS NOT REACHED THE SPECIFIED RANGE. CHECK HEATER LAMP, THERMISTER, THERMOSTAT.
Dec 18, 2009 | Office Equipment & Supplies
Canon np6025 error code e004
This is a fuser problem. It will need to be replace or rebiult depending on what is wrong with it. It could be the fuser heat lamp, or thermistor.
Oct 29, 2009 | Canon NP 6551 Black and White Copier
This err number whit ist
hello there here is some information that may help you solve this problem ok?
best regards michael
  1. Printer Repair And Service Tools: Ir3200 error code e000677-0004 Canon Multi-Pass Fax C855 waste tank reset code ... Canon Error Code, E000, E001,E002,E003,E004,E005. Ir3200 error code e000677-0004 ...indoresetter.blogspot.com/2009/02/ir3200-error-code-e000677-0004.html - 82k - Cached
  2. C3200 Problem Solving at FixYa how do I reset this code? canon ir 3300. 1 Solution. after pressing *28 it come download mode ... e005 an error canon 6330. the quality of four colour is very ...www.fixya.com/tags/c3200 - 89k - Cached
  3. E004 Problem Solving at FixYa along with e001 and e005... HP Pavilion dv2000t PC... Problem Event Name: APPCRASH ... codes with this model np 7161 e004 iwant to know how to get in reset program...www.fixya.com/tags/e004 - 92k - Cached
  4. The Copier Network - Canon 6085 E5 ... what this code means or how to reset it any suggestions? ... E005 is fuser web out. clear web counter. techla. I replaced the web just coundn't reset the code. ...www.thecopiernetwork.com/printthread.cfm?Forum=87&Topic=18014 - Cached
Sep 14, 2009 | Office Equipment & Supplies
E004 probelm in 6050
e001 thermister 004 ssr or heat lamp broke or not connected oo5 is a web out code check the connector behind the front fuser drive gear pack large connetor plugs into frame
Jan 19, 2009 | Canon NP 6050 Copier
Won't print an incoming fax; displays error message 004
I think the error is point to a fuser (temp issue) problem.
You can check out this thread for some more info that might be helpful. - LINK
Nov 11, 2008 | Canon LaserCLASS Fax 710 Printer
IR 5570 Error code
Subject:E840 Indicated in response to damage on the Fixing Roller Trust StopDetails:<Problem>Damage to the Fixing Roller Thrust Stop leads to the indication of error code E840. At times, it can also indicatecode E001/E004.<Cause>The strength of the Fixing Roller Thrust Stop [1] is not adequate and over time, it tends to show damage, failingto prevent the Fixing Roller from moving to and from. Or, the damaged stop can fall to the Shutter DriveAssembly to cause the shutter to malfunction, also resulting in an error.
<Factory Measure>Modify the method used to shape the fixing roller thrust stop to increase its durability.
Servicing Work:If any of the foregoing symptoms is noted, or in the course of a service visit, replace the existing Fixing RollerThrust Stop with its new type.
Sep 24, 2008 | Canon imageRUNNER 5570 Copier
E000004-0010
canon NP 6330
error 800
Nov 15, 2007 | Canon imageRUNNER 5570 Copier
Canon NP 6050 Copier Logo
424 people viewed this question
old marine
old marine
