Font size too small in Sage Accounts 2012 on windows 7
I have spoken to Sage, they say they use MS San Serif and have said they test all their data on small screens. I have a 24" screen and have to change the dpi to 160 in order to read my data, all menus and headings are in a bigger font to start with, so these main set items have not got a problem. I have checked that I have MS San Serif installed. I can not keep changing my font dpi everytime I use Sage as it affects all other programmes which become too large to use. Have dowloaded latest drivers for screen and still no luck. Anyone got any suggestions?
SOURCE: error message with sage instant accounts
If you are unable to logon to Sage you can try deleting the Queue.dta file. All users MUST be logged out of Sage and Sage should not be running. Sage will recreate the queue.dta file when it is restarted. The Queue.dta file can be found in the ACCDATA folder for the Sage Company Data that is experiencing the problem.
Note that the "Username already in use" message from Sage can occur if Sage wasn't shut down tidily for that users session. If you are sure that the user is not actually logged in it's OK to allow Sage to clear the session and log in.
Posted on Apr 17, 2009
  • 3 Answers
SOURCE: font size in Sage Financial Suite
You cant, if you change the windows display font size this will make some of the fonts bigger in Sage but not all and may make some areas of the program unreadable
Posted on Jul 22, 2009
SOURCE: Sage Instant Accounts error Message Coming up during Installation
Was getting the same error for version 12. On the cd there is a support folder. In that there is an installs folder. I installed jet, mdac and the xml parser (probably not necessary) and the next install worked OK.
Posted on Apr 21, 2010
SOURCE: Instant Accounts 8.0 (013604ug): I am using Sage Instant Accounts version 8 and am ...
Hi.
We had same problem. Our solution:
1. Empty both the 'accdata' and the 'criteria' folders.
2. Start Sage.
3. Restore a previous backup.
This worked for us. Hope it helps you.
Posted on Jun 04, 2010
SOURCE: I want to put Sage instant accounts on the same
Hi.
We got round this by installing each program on a separate partition. Use the 'Custom Install' option when you install the second program. You only need to change the first letter from 'C' to whatever the new drive letter is. Leave the rest the same.
Change text size in sage
if it is an issue with view the screens, you can decrease the size of your windows desktop. if it is fonts in reports you can edit the report and change fonts in ther
Mar 31, 2009 | Sage Instant Accounts 8.0 (013604ug)
Tip
Common Projection TV Problems and Fixes
In this article we will will outline some of the most common projection TV problems, fixes, pros and cons, and average lifespan.
Average Lifespan: 7-20 YearsPros: Large screen size and excellent picture quality. Some model support HD. Very reliable when they are cared for.
Cons: Heavier and bulkier than the newer plasma or LCD sets so if you live in a cardboard box it may take up a bit more room.
Common Problems/Fixes
Common Problem #1 - Convergence: One the most common problems that you will run into eventually is a convergence failure. This is when the TV colors do not align anymore and the TV will look 3D, warped or distorted. This is a very common problem and a fairly simple DIY fix. Parts to repair this can be found over the internet from sites such as www.TvRepairKits.com . Below are a few photos of a typical convergence problem and a link to a video on YouTube with more details.
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Notice how the image looks 3D...this is a classic example of a convergence failure...it may also look warped or have a wave look. But the wave will not fluctuate.
Common Problem #2 - Dull or Dark Video
The second most common problem we see on projection TV sets is whats known as the dull video issue. This is commonly caused by discolored cooling fluid in the lenses. Over many years - usually around 5-7 years - the fluid will discolor and cause the video to wash out or look dull. Changing the CRT fluid out every 7-10 years will restore the image clarity back to factory new conditions. You will actually be amazed at how sharp and clear the video looks once a fluid repair has been done.
Here is a before and after photo notice how it looks washed out. In some cases the images will look like they have halos around them or the screen will have a reddish tint. Bottom line - if your projection TV has never had the lens fluid replaced the video is not as sharp as it can be. You can get fluid kits from the same sites mentioned above. Doing this repair yourself or through a shop will make the video look amazing.
After a fluid replacement
Common Problem #3 - Dead set with no videoIn these cases there can be more than one common issue depending on the TV brand and model. But to make things simple if the TV has no audio or video and its making a constant chirping sound the issue is caused by a short in the convergence. The fix is to do a convergence repair. If however its not chirping constantly it can be one of many issue from failed capacitors, diodes, flybacks, etc.
on Apr 25, 2012 | Televison & Video
Tip
How to Unlock a 16GB iPod Touch
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
on Dec 16, 2011 | Apple Computers & Internet
Tip
System Restore for Windows 7
1. Open the Start Menu.
A) Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A) Click on the Recovery icon.
B) Click on the Open System Restore button.
A 'System Restore' window will appear. Here you will have to check "Restore computer to an earlier time'
A) Click on the Next button
Now you will find a window with Dates, Description and Type,
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
on Nov 02, 2011 | Microsoft Computers & Internet
Tip
Flash From a Cameras on 3 Phase UPS
Possible interruption to customer load due to Photo Flashes. While testing a new service, we hope to be offering soon, the Dallas based engineering department has discovered that the use of a flash camera in or around the UPS may cause a fault in the unit that could result in the loss of power to the critical load. We have noticed two different scenarios: 1. While taking a picture of the inside of a running unit in the test lab, the flash affected the firmware,
resulting in a lock up. The unit did not transfer, it just shut off! 2. At an actual customer site, prior to doing a PM on a number of units, we wanted to test the new Thermal cam. Part of the test involves taking a digital photo. Upon turning the digital camera on while standing next to a UPS, the RF of the flash charge circuit was enough to interrupt the inverter drives. Fortunately, the unit did successfully transfer to bypass, but only after the loss of a few fuses.
on Oct 21, 2011 | Computers & Internet
Computers & Internet Logo
1,362 people viewed this question
David Payne
David Payne
