I have a samsung washing machine WA13G7Q1. There is alwasys black flacky debris on my washing after every wash. I clean the filter in the drum before every wash. Is there another filter i dont know about? Please help
  • Washing Mach... Master
  • 1,205 Answers
I do not knnow either, but what I know is that after having washed black socks in my machine, there will be black particles floating around and sticking to the next washload. Sowhat I dois to doas you do clean before washing, then I put some rags old towels or pillowcases and wash on 40 degrees Centigrade. Then I clean the machine again and am especially careful to clean the rubber rings around the door and the doore specially the lower part.
good luck
Kolbrun
Posted on Feb 24, 2012
  • 1314 Answers
SOURCE: Samsung b1445 washer
let me do a little research can you turn the drum by hand to make sure nothing is jamming it
Posted on Feb 16, 2008
SOURCE: i have a samsung J1043 7kg washing machine, apon
3E means the motor is running below or above the programming RPM's, this is a real problem. hold down the two left buttons while pressing the power button. this will present you with the testing system. Press the temp button and T1 will appear. press the start button on the machine will move through the phases in 3 second bursts. if your drum doesn;t move your motos shot. Good luck
Posted on Jan 31, 2010
SOURCE: washing machine stops and flashes 4E
1. WATER SUPPLY ERROR – Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Posted on Feb 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code ( IE ) on my samsung washing machine model wa13g7q1
1E - WATER PRESSURE SWITCH ERROR
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
SOURCE: My Samsung Washing Machine (Diamond Drum model) problem
You probably did not save the mode you want. See the information booklet provided on how to set the mode.
Posted on Oct 29, 2010
Wat area is the pump filter on my Samsung washer and dryer combo
How do I clean the debris filter in my front loading Samsung washing machine?. Open the filter cover(A) by using a coin or key.Take one end of the emergency draining tube (B) out.Open the emergency drain cap (C) by pulling it. Allow all the water to flow into a bowl. Note: hold the cap at the end of the emergency draining tube (B) and slowly pull it out. Note: you may need to drain several bowlfuls of water. . Prepare a dry cloth. Wash any dirt or other material from the debris filter. Make sure the drain pump propeller behind the debris filter is not blocked.Replace the debris filter cap tightly.Reinsert the emergency drain cap and the drain tube.ake sure to replace the debris filter and emergency drain cap after cleaning it. If they are not reinserted properly your washing machine may leak or otherwise malfunction.Close the filter cove
Sep 30, 2016 | Samsung Washing Machines
How can i remove drum over for samsung toploader washing machine. Clicking noise when drum is turning. Model nr wa13g7q1
bra braces or something between wash drum and heater element .unit.? remove the drum or
Set the machine on its side ?
Dec 16, 2015 | Samsung Washing Machines
Where to clean filters on Samsung 13kg top loader?
Sounds like you need to have your machine looked at by a professional. You should not be finding rubber pieces in the machine.
May 08, 2014 | Washing Machines
WA13G7Q1
Check Belt tension. The belt may be slipping
May 06, 2014 | Samsung Washing Machines
Samsung WF7700N6W1 washing machine not draining
Could be a sock or something between the 2 drums that moves over the outlet hole from the drum when upright and trying to drain but moves away when machine is on its side. Get a flashlight and look through the holes in the inner drum and you may find the culprit.
A coin may also be stuck in by the pump blade, not always easy to see but worth a look.
Dec 22, 2012 | Samsung Washing Machines
No water flowing into drum, water supply is fine, just humms
My Samsung washer was not filling with water after cleaning the debris filter. All I did to fix it was to dump a half gallon of water into the tumbler, then I ran the beginning of the rinse cycle and it worked. It seems like the pump needed to be primed.
Sep 16, 2010 | Samsung WF337AA Front Load Washer
I have a 5E error on the diplay of my washing machine with the clothes locked inside and with no solution whatsoever .... Help Please
If its a samsung model, which I am assuming it is as I have just had the same error code, it means you need to clean your debris filter.
If its a samsung washing machine...to clean the debris filter you need to open the panel which is located on the front of the washing machine on the bottom right (you will need a coin or a key to do this) When you do you will see a large black plastic screw on the left and a small white plastic screw on the right.
The 1st thing you need to do is pull out the white screw (this is the emergency drain hose) have a bowl or bucket ready (the hose doesnt reach that far) and pull of the white knob (i had to kind of twist and pull, a little harder than i thought)
After you have drained the water you can now clean the debris filter (the large black screw) Have some towels or another bowl or bucket ready underneath as more water will drain. When all gone you can twist off the black screw and remove anything blocking (I had a coin and a plastic wrapper and some tooth picks. No more error message.
Good Luck!
Jul 25, 2010 | Samsung Washing Machines
I have a Samsung WA13G7Q1 washing machice The
the quection is not complete, when the cold water inlet and hot water inlet both work then what is the problem....
Apr 27, 2010 | Samsung Washing Machines
Debris being released from washing machine
This is from the drum seal or bearing. Check/replace.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 11, 2009 | Washing Machines
clean the debris filter usually situated at the bottom of the washing maching you will need to open the panel, you should see a rubber tube with a bung in the end you need to take the bung out in order to drain the washer, once you have drained the washer you can clean the filter by unscrewing the large black round bung. hope this helps
Feb 13, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
285 people viewed this question
Top Washing Machines Experts
