Question about Minolta DIMAGE DIGITAL CAMERA MODEL Z 1 (724667) Drive
It will not turn on
When I press the on button, it will flash but it will not turn on or the screen stays black. Do I need to invest into another camera or can this problem be fixed
0 characters
1 Points
The Drive no longer works when plugged into a laptop. Placed a DVD in the slot (non-tray) and now it will not come out. The release button does not work and there is no pinhole to poke with a paperc
Don't know this drive in particular, but here are some ideas.
Try holding down the release button for a reeeeally long time (120 seconds, maybe?)
See if you can get the pre-boot diagnostics to eject it:
1) Boot up the machine
2) At the Dell Logo, Press the 'P' key and 'F12' at the same time. This will give you power-up options.
3) Arrow down to Diagnostics and Press Enter.
4) Wait for about a 10 minute test to finish. You will be prompted to interact with the video color test, just Press 'Y' to confirm you are looking at colors.
5) When prompted with 'No problems have been found...' Press 'N' to not continue with the memory test. 'Booting Diagnostic Utility Partition' will appear.
6) Press any key on the keyboard to continue.
7) When prompted to choose an option, arrow to 'Test System' and Press the Spacebar. The 'Main Menu - Service Tag ' will appear.
8) Arrow to 'Custom Test' and Press Spacebar to select the option. The 'Customize' interface will appear.
At this point you have two options which may work for you:
9a) Double-Click on the 'Keyboard' test.
10a) when prompted with 'This test checks the keyboard...' Press OK to continue.
11a) Using the keys on the keyboard, starting with 'Esc', Press on the keyboard each highlighted key, until you finally get to the Finesse Eject button. Your disk will automatically eject!
12a) Press ESC twice to exit the test, and then Click on the 'X' to close the testing interfaces that appear. Ultimately, your system will reboot.
9b) Select CD/DVD test
10b) After getting to the part of the test that tells you to eject the CD, click "OK" to continue, just click "OK", it will do it 3 times.
11b) Then it will say "IT'S GOING TO TEST THE EJECT FEATURE OF THE DRIVE" that's when it will eject out.
If none of that works, it's time to get physical.
1) Peek in the slot and see if you can see a release button inside. Here's a video that shows what to do if you can find a release button:
(the video says the button will be 12 mm from the left side of the opening, but that is model-specific, I think).
2) Peek in the slot and see if you can see a metal tab holding the disk in.
a) If so, see if you can move it.
b) If not, try sticking a piece of cardboard with double-side tape to see if you can stick it to the disk and pull it out.
Oct 01, 2014 | Dell External Drives
Remove bios password
There should be a factory procedure for this. Anybody that can help You need to know first the brand and exact model of your computer to search for the right procedure.
Dec 25, 2013 | HP External Drives
When i put my flash drive into the computer it will not open my information
if you are referring to a usb drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
Jun 24, 2012 | External Drives
How to use RecZone password vault to change from alphabetical to numberical
on the reczone password vault you can enter numbers. on the button with 1@/.:, if you press the button once you will see @ entered. press the button 2 times quickly to enter a /. press the button 3 times quickly to enter a . press the button 4 times quickly to enter a :. press the button 5 times quickly to enter the number 1. press the next button 4 times quickly to enter a number 2. press the next button 4 times quickly to enter a number 3. press the next button 4 times quickly to enter a number 4. press the next button 4 times quickly to enter a number 5. bottom row: press the first button 4 times quickly to enter a number 6, the next button 5 times quickly to get a number 7, the enxt button 4 times quickly to get the number 8, the next button 5 times quickly to get the number 9, and the last button on the bottom row press it 4 times quickly to enter a number 0. pressing caps lock does NOT switch it from alpha to numeric mode. caps lock only gets the letters entered in UPPERCASE.
Nov 30, 2011 | External Drives
How do I get my handheld palm Tungsten E2 to synchronize via my USB bluetooth 2.0 adapter to my new computer that has Windows7? Microsoft windows said that bluetooth would work with Windows7,64 Bit; but I...
a. Plug the USB sync cable into a
USB port on the back of your
b. Plug the cable into your
[ & ] OPTIONAL Press the power button to turn on your handheld if it is not
already on.
Continue with the onscreen instructions. Synchronize your handheld with your
computer by pressing the sync button on the USB sync cable.
Dec 01, 2010 | External Drives
I have a Toshiba USB flash dive with a plastic type of cover over the flash drive, how do I open it?
We just figured it out. Pull the end of the black plastic side and it slides out. It would be great if there were some instructions. Hope this helps!
Oct 14, 2010 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Lcm-19v7 westinghouse lcd monitor
Yes, The problem is bad caps on the power supply board. We are working on the repair guide and it should be up on our web site by tomorrow night ( 08/19/09 ) check it out at: We will have parts list and pictures showing what needs to be done.
I hope this helps, If so please rate our solution.
Corporate Computer
Aug 18, 2009 | External Drives
I need to know how can I boot from my usb flash thanks
You need to know if your motherboard can do this option.
Enter setup otion generaly when you turn your computer on press the DEL key and you are in the BIOS SETUP configuration. Go to the BOOT SEQUENCE and if it is possible choose USB option.Place this option on the first place with the UP or DOWN keys. For exemple fist boot drive : USB second boot drive HDD ,...
You must format your USB device as SYSTEM ! and have the system installed on it. You can find on the Web a light version of WINDOWS XP called LIGHT to put it on your USB device I think it is an USB flash drive, Is it?
If it is an external HDD you can install the entire system of Windows and boot by it bur select the right boot sequence in the BIOS setup.
Dec 17, 2008 | External Drives
Usb flash pen drive
Often it is due to electrostatic charges on usb. Unplug all USBs.Unplug PC from power cable for 10/15/ minutes. plug back computer to power outlet and restart. Plug back usb.
If it still does not work , flash memory may be faulty, test it on a different computer.
Mar 17, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Black screen cannot take picture minolta dimage a1
i have seen a recall notice on this camera - you can send it sony konica minolta for free repair.
search web for details.
Oct 22, 2007 | Minolta DIMAGE DIGITAL CAMERA MODEL Z 1...
External Drives Logo
Top Minolta External Drives Experts
Brian Sullivan
Brian Sullivan
Are you a Minolta External Drive Expert? Answer questions, earn points and help others
