I am not sure if we registered our pixmamp470 or not, but we have had it less than a year. the paper will not feed. i tried cleaning the rollers, but that did not help. Can you tell me what to try next, or where I can take it to be repaired? we live in scarsdale new york. thanks
    Genius:
  • 2,785 Answers
The best place to take will be the local vendor from where you have purchased the printer
Posted on Oct 28, 2008
Cannon MP 250 crayon stuck between rollers
Description
Cleaning the Paper Feed Roller - MP250 / MP270
Solution
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and remove any paper from the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Clean the Paper Feed Roller.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4. Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
If the problem is not resolved after cleaning the Paper Feed Roller, contact the service center.
NOTE:After the cleaning is completed, press the Stop / Reset button to return the LED to the copy standby mode.
Oct 28, 2017 | Office Equipment & Supplies
Paper feed won't pick up paper. tried to put single paper in but paper jam light goes on but no paper located. we think we need new rollers for the paper feed but not sure where to get them in...
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
May 12, 2011 | Lexmark E232 Laser Printer
We are having paper feed problems with this two year old printer, including paper jams, black roller marks on the paper, etc. Help!
1. clean the feed rollers
2. check if the feed rollers work
3 check if have a piece of destroyed papper in the road of the paper
4 clean the sensors (all cleans with ajax)
5 the feed rollers you can clean with the WD40
Nov 19, 2010 | Dell 5110cn Laser Printer
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Roller Cleaning is completed.
Sep 06, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Printer won't pick up the paper in the tray to print. Keep getting out of paper message
First check if the feed rollers are 'Slick" with paper dust, if they are ,clean then with 409 on a cloth rag, and scrub till u dont see the white paper dust on the rollers, let the rollers dry, then reset the printer, by turning it off. then turn it back on ,reinstall the paper and begin printing again.
Jul 15, 2009 | Office Equipment & Supplies
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Jan 29, 2009 | Epson Stylus CX3800 Printer
The paper feed wont stop
the paper picking rollers i think r weak try cleaning the rollers n try it again.
thank u
May 26, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Paper jams
The feedrollers are most likely worn out. Maybe not smoothe but just tacky.
You can try removing the paper tray. Then take some cleaner, alcohol or some liquid soapy cleaner, fantstic, or soemting like that, and clean the rubber rollers. Clean them 2 or 3 times with a cloth dampned with the cleaner.
since the jams are in the tray, I am sure those rollers are either dirty or smoothe.
If you need more info let me know and I will send you my E-mail address so you can order and replace them on your own if you don't have a maintenance agreement with someone.
Dec 22, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Paper feed problem, then error
SEPARATION ROLLER MAY NOT INGAGE CAUSING THE PAPER NOT TO FEED TO THE FEED ROLLERS THE PAPER DOES NT ADVANCETO THE REGISTION ROLLER THAT SET THE PAPER FO COPY CHECK TO SEE IF THEY ARE CLEAN OR WORN
Dec 07, 2007 | Konica Minolta magicolor 2400 Laser...
82 people viewed this question
k24674
jasbo
jasbo
