Simpson washing machine fault 5o
Washing machine stopped and comes up with fault 5o
SOURCE: Simpson 175 HD washing machine
image_bubblequestion_04.gif Can you please identify the problem with my washing machine?It appears all the functions of my simpson 175 washing machine work normally except the agitator only moves briefly and harshly for between 1 and 2 seconds.
Simpson 175 HD (Dual Action Agitator) Washing Machine.
1517 5M40 A 28 June 1990
Posted on Aug 14, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
jtbjtb
  • 135 Answers
SOURCE: annoying beep
Open the control panel and locate the beeper. Pull off one wire and tape over it with electrical tape. Voila! Hope this helps!
Posted on Jan 01, 2009
  • 106 Answers
SOURCE: washing machine keeps stopping mid wash and coming
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Posted on Feb 27, 2009
  • 69 Answers
SOURCE: machine will not stop filling with water
Does machine stop filling if you discnnect from power? If it does, the problem lies with timer/control unit, or fault in pressure switch/ tube. Check pressure tube (thin rubber pipe that goes from water level selctor switch to side of outer bowl) for holes- replace if faulty. You can test pressure switch by remove pressure tube from outer bowl and blowing thru tube- you should hear the water level switch click when you blow, and then click again when you release pressure.   If it keeps filling even with power off, you have a faulty inlet valve. If you remove top panel (3 screws along top rear-power off first!!), you will see the inlet valves- one for hot, one for cold. The valve is the thing the inlet hoses screw onto. New valves availble from any good spare parts supplier, relatively inexpensive part. Good luck!!
Posted on Mar 13, 2010
Testimonial: "Exactly pipointed the problem which is now fixed Thank you"
Simpson esprit 450 washing machine. Sometimes it will do the final spin and othertimes not spin at all. The machine is 11yrs old.
Probably a timer problem but you need fault finding knowledge and a test meter to find the fault. There are a few other reasons to not spin. You haven't said if you have a test meter or fault finding skills.
Oct 20, 2017 | Simpson Washing Machines
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
Why is there an 'SF' code showing and continuous beeping from our Simpson encore 756
there are different sf codes for different faults. try googling the sf number fault to find problem.
May 25, 2014 | Washing Machines
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Hi I have a simpson eziset 605 washing machine and it has stopped spinning.. I have checked the belt and thats seems fine the washing machine just wont spin.. if anyone has any idea of what it could be...
Hi Carlee just read your posting.Now the Simpson Eziset machines come in top and front loader versions.Which type is yours?Please reply with this additional information and I will help you rectify this fault.
Oct 03, 2010 | Washing Machines
Simpson encore 605 wash machine 6kg. Washer pump
Hi mark just read your posting.Now what country do you live in.If you live in Australia then I can give you some phone numbers.Regarding your machine it does sound like the control board.Probably the power supply section of the board is faulting.Please reply with additional information and I can help you further.
Jun 19, 2010 | Washing Machines
Simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Mar 31, 2010 | Washing Machines
Simpson front loader washing machine repair person
I have Simpson EZI sensor 9.5kg and during the washing i have a EF message coming up.
Dec 21, 2009 | Washing Machines
Simpson 175 HD washing machine Programme keeps stopping Is it the timer or some other problem
Jul 12, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
