Question about Edirol UA-25 External Sound System
"digital in" led flashes instead of burning constantly
Hello there, I have a labtop with cubase installed on it and the Edirol UA-25 connected. The problem is that the "digital in" led flashes instead of burning constantly. The manual says that this isn't correct but doesn't give any solution. Can anybody please help me. With kind regards, Stephan.
Sorry, i'm new to the UA-25 as well, but from my understanding, if you are using a digital signal device and it is connected properly, that indicator should be steadily lit. IF you are NOT using a digital signal device and it's flashing, it's because you have the button pressed when you shouldn't have it pressed unless you want your sound to loop through the computer and come back to your headphones.
Posted on Mar 31, 2007
Ua25
Hello. Sometimes the USB voltage is not enougth. Try connect the usb cable into another USB port, preferring the rear panel connectors. The UA25 drivers must be installed previously.
Feb 07, 2013 | Edirol UA-25 External Sound System
Edirol ua-5 flashing power light flashing
Be aware that SCMS "prohibited" recordings will trip this flashing light, and will not output. You will have to make an analog copy.
Feb 25, 2012 | Edirol UA-25 External Sound System
For some reason I cannot select my UA-25 as the ASIO Device in 'Audio System Setup' in VST5. VST 5 always seems to select 'ASIO Multimedia Driver' as the ASIO Device, which has a latency of 750ms. The...
I am using a laptop for my music creation and I am thinking about using an External Sound Card connected with a USB cable or getting an Sound Card. My integrated sound card has a little bit too much latency. Will I have just as much or more latency with the External Sound Card because it is connected with the USB cable or would I be better off with the Sound Card?
Thanks for vinu plz plz plz plz plz plz plz plz help me sir.
Mar 06, 2011 | Edirol UA-25 External Sound System
Digital in out
The ada800 gives out 8 channels of ADAT, the edirol UA-25 are only stereo opticals and not compatible with the ADA8000 as it does not have any adat inputs or outputs.
Hope this helps
Jan 31, 2010 | Edirol UA-25 External Sound System
Edirol not able to record on Cubase essentials
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Jan 25, 2009 | Edirol UA-25 External Sound System
Edirol UA-25 not working on Mac OS X
I had the same problem. When I installed the Edirol software it prompted to 'reboot' and when it restarted all the lights on the Edirol came on.
Why don't you try it like that.
Hook up the Edirol Install the software Reboot
Best of luck Victoria
Nov 19, 2008 | Edirol UA-4FX External Sound System
Can get signal from UA-25 to computer... but no audio from computer to UA-25?
Here is one solution uninstall the default driver or roll back driver. Restart your computer. When you get into windows wait for everything to load and then plug in your audio device. If you have it plugged in when windows starts then it will install a driver. In automatic updates you can select to notify of updates, but lets you install the ones you want.
Thanks for using Fixya
SAM ANDERSON
Sep 29, 2008 | Edirol UA-25 External Sound System
No sound being picked up by Edirol
I discoverd the the digital in button had been pressed in. This was the mic was not picking up any sound.
Jul 09, 2008 | Edirol UA-25 External Sound System
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Edirol UA-25 External Sound System Logo
132 people viewed this question
Top Edirol Computers & Internet Experts
Ben Armstrong
Mark Ferris
Level 1 Expert
Steve Allison
Steve Allison
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
