Question about GE Profile GCG1700LII 15" Built-In Trash Compactor with 1.4 Cu. Ft. Capacity, Fully Integrated Door ...
Motor Seized GE 15" Trash Compacter
I have a problem with my GE trash compacter the motor hums when turned on but does not start. I had a repair man come in to service it and he said the motor would have to be replace at a cost of $500. This unit was installed less than a year ago however because it was purchased before that the warranty is expired. I am very dismayed that the product is that poorly made and the support is as bad. After buying 5 of the GE Monogram products I will never buy GE again. Can the motor be repaired or do I have to replace?
    Top Expert:
  • GE Master
  • 41,797 Answers
The usual "repair" of appliance motors is replacement. If you browse this site, you will find numerous other cases similar to yours where an expensive appliance has failed early.
Posted on May 11, 2017
docjohn174
  • 943 Answers
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Posted on Oct 15, 2008
  • 22 Answers
SOURCE: GE refrigerator is the worst product I have even
Well, i have to jump right in here and agree with you. I have been working on appliances since 1971 and GE is the most frustrating, highest priced replacement parts ( for the most part ) of all brands. Of all the brands, Whirlpool and Maytag have been the longest lasting, best priced and easiest to work on. I truly feel sorry for you....really.
Posted on May 12, 2009
SOURCE: GE monogram fridge: Poor Cooling after cleaning
Temporary solution.
Open the top hook. leave it open overnight.
Check in the morning if the temperatures comes back to normal. It works for me!
Posted on Jun 11, 2009
  • 555 Answers
SOURCE: GCG1700 willnot compact.When activated it just
There is a motor jam. The mechanism needs to be cleared, perhaps a bone or any other hard material is jamming the mechanism. Do a visual inspection and look for foreign objects (Perhaps a fork?) or something unusual.
Posted on Jan 06, 2010
Daniel S
  • 4323 Answers
SOURCE: GCG1580LSS trash compactor when I
Hi
The hum sound means that the motor is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 07, 2011
How to remove whirlpool trash compacter
Hi Larry, you can download the installation manual from the link below which should also have some instructions for removing the compactor. We hope this helps!
http://bit.ly/112Lu7q
Jan 02, 2014 | Whirlpool 800 Series Undercounter Trash...
Whirlpool Trash Compactor, Model No. GX900QPPS2 will not compact trash. It will only make a humming noise
drive gear broke on motor shaft,drive kit #882699should fix you.appilance parts pros.com is a good place to get it.
Oct 08, 2013 | Kitchen Appliances - Others
My ge profile 15" compactor stopped compacting. I
The "wheel" has a cracked center that you can not see unless you take the whole gear off.( I am assuming the "wheel" is off the motor and should be driving the chain that goes to the side gears ) There is a tension washer looking thing that holds it on and you can force it off with a flat screwdriver. Once off, I'm sure you'll see the center of the gear( hex shaped) is not engaging the hex gear shaft for being broken somewhere. An appliance repair store should have that part for less than $50. Sure beats the $85 the service people start with for just a service call.
Dec 11, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
My Jenn Aire Trash Compactor Model TC507B1 does not turn. When I turn the start knob to on position, the compactor makes humming sound, but it does not seem that the ram is moving. I have checked the...
Sounds like the motor that turns the reduction gears which ultimately pushes the ram could be seized up. If an object was jammed inside which was to much for the motor to handle it could cause it to draw too much current seize up the motor.
Jan 24, 2010 | Microwave Ovens
Jan 06, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Our compactor does not work. It makes a humming noise but will not function.
motor jamed . try removing basket . ( pull out and lift up ) ck for plastic of other things in or around drive and rollers .both sides and in back .. ****
Dec 07, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
GE trash compactor ZCG3100BVV-02 won't start. I out a new on/off switch and it still will not start
Most likely a ram position switch but could also be a bad motor. process of elimination will lead to the faulty component...Eric
Sep 12, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Jenn-aire compacter can't close
Hi marigf5,
I'm Harvey the Master Plumber.
Your problem is: you cannot get your compacter to close.
First, don't force it. Chances are something has fallen behind the drawer and is in the way. Just remove the drawer and clear it. If something is broken, you still have to remove the drawer to see and repair it. If you run into trouble you might consider utilizing the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | KitchenAid P Series Trash Compactor -...
GE Profile GCG1700LII 15" Built-In Trash Compactor with 1.4 Cu. Ft. Capacity, Fully Integrated Door ... Logo
47 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
