Question about Panasonic Heating & Cooling
Panasonic inverter a/c model r410a - remote control display blank
Remote control display is blank. is there a battery and if so how do you change it
  • 6 Answers
SOURCE: How to change panasonic inverter
Slide the cover all the way down until it stops. Then using gentle pressure push the low half of the cover down to lever the top edge over the two small lugs.
To put the cover back on after changing the batteries, apply the same technique to slide the cover back over the lugs.
Posted on May 09, 2011
hapndnvegas
  • 35 Answers
SOURCE: air conditioning unit remote control problem
when something is broke you can never break it worse so dig in and look for a stuck button or broken piece of plastic lodged in between the buttons or
you may want to go to: harmony web site and see if your model of a/c is supported these remotes are rather expensive us$129-$499 but much less than replacing the A/C and can control 225,000 devices made by 5000 different manufacturers just about any device under the sun. on the website under device choose home automation then climate control your brand then model number to see if your A/C is there. If you decide to go this route I would reccomend to check all the other devices you have also.
Posted on Apr 14, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: How do I change the battery in the remote control
slide the cover of the remote up higher. It is hiding the batteries.
Posted on Nov 26, 2009
  • 25 Answers
SOURCE: I have a panasonic r410a inverter and I can not
The remote most likely takes batteries. If this remote has a cover that slides down to access buttons underneath, try popping that cover off.
Posted on Dec 06, 2009
SOURCE: Changing the battter of the remote control
Slide the cover down as far as it will go. Now using your fingernail, gently lever the cover off from the base, it will click out without much force. This is a stupid and confusing design and should be changed.
Posted on Apr 09, 2010
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't work.so what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ...
www.thermospace.com/shinco/Inverter_Service_Manual.PDF Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
"SET 1" Displayed and remote not working.
You have a Panasonic, they have a feature, in case you have two or three Panasonic units you can program the remote either be used on one, two, three. So if the display lights set one that means the remote control would control set one. There are several ways to change a setting one is in the player menu, I believe you can change the remote. Check your manual, this is not a big deal.
Oct 18, 2014 | Panasonic Televison & Video
Handset display lights up but is blank
If the batteries in handset are old then replace it. Follow battery change instructions in this manual.
http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.pdf
Sep 12, 2014 | Panasonic Lands Phones
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
My Ac wont turn on becauser the timer light is blinking Panasonic inverter R410A
use the remote to retrieve error code,on the bottom of the remote you will see a CHECK bottom,use a pointed pin to press it for 5 seconds the display of the remote will change to two underscore, then scroll the arrow beside the time,r press until you hear beep sound, then jot down the error code..there's a error code you will see inside the panel of the indoor unit,for quitting press again for 5 seconds the Check bottom
Aug 22, 2010 | Panasonic CW-1006FU Air Conditioner
I have a panasonic r410a inverter and I can not get the remote to work at all, i dont see where any batteries could go? any ideas?
Dec 06, 2009 | Heating & Cooling
Heating & Cooling Logo
303 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
