There should be a battery cover in the bottom possibly with a screw, open it and replace the batterys, I will have to check the manual to confirm this..
Comments:
Oct 28, 2008
Replacing the operating batteries
The Organizer detects two low battery levels which are warning
and fatal. When the batteries are in warning level, alert message
appears on the screen. In fatal level, the Organizer will turn off
automatically without indication.
If the alert message is shown, replace the batteries immediately.
1. Turn off the Organizer.
2. Set the battery replacement switch on the bottom of the
Organizer to REPLACE BATTERIES (a red dot will appear).
3. Slide off the operating batteries cover
Oct 28, 2008
4. Remove the old batteries by pulling the ribbon tab.
5. Insert the two new batteries on top of the ribbon tab, taking
care to position them correctly according to the plus (+)
and minus (-) terminals, as shown below.
6. Replace the cover.
7. Set the battery replacement switch to NORMAL
OPERATION.
8. Turn on the Organizer and set the clock
and heres a picture of the replacement switch
Oct 28, 2008
- have you turned the switch to normal operation? are the batterys inserted the correct way? Are the batterys new?
Oct 28, 2008
Setting the battery replacement switch to REPLACE
BATTERIES shuts off power to the unit. Check that the
battery replacement switch is set to NORMAL
OPERATION.
Have Sharp OZ-730 whose "2nd" and "Caps" keys stick. Makes it difficult to key...
(More)
Have Sharp OZ-730 whose "2nd" and "Caps" keys stick. Makes it difficult to key in password and sometimes entries as well. Can I lock the organizer, as if replacing betteries, then open the unit and clean the keys w/o doing damage or losing data?
I have an old Sharp Wizard OZ-290H with PC Sync. I don't ever remember any kind of cable with it...
(More)
I have an old Sharp Wizard OZ-290H with PC Sync. I don't ever remember any kind of cable with it that would have allowed me to ''sync'' it with my PC. Now that the screen is degrading (I have had it fixed once), I am worried that I will lose everything. So I was hoping to ''sync'' it with my PC. Any ideas on hose i can do this?
I can't back up my Sharp Wizard OZ-650 to my computer. I am using Rupplynx version 1.2. It starts to...
(More)
I can't back up my Sharp Wizard OZ-650 to my computer. I am using Rupplynx version 1.2. It starts to transfer and then after a few minutes I get an error message.
some of the stored information hard to read,white lines run up and thru the stored info is there...
(More)
some of the stored information hard to read,white lines run up and thru the stored info is there such a thing as upgrades for that model.
