Question about LG Audio Players & Recorders
Sometimes no response remote control - LG Audio Players & Recorders
  • willemsenr
    willemsenr Feb 24, 2012
    It is not the remote, the system does not respond to most of the remote (only volume up and down are working). Currently the only solution is to keep the power button on the HX551 pressed until the systen shuts down. Then ik can be started again and works normal until the next hangup.
Both remote controls for tv1 and tv2 exibit very slow response when trying to control the dish box. It sometimes takes up to 10 sec from when I hit a button on the remote control to have the action...
Tries Dish network box unplug,replug the box back like an hour later.By letting the box itself rebooting and upgrading it softwares,should solved this problems.If not than the box have problems.Trade in for a new box.
Dec 06, 2010 | DISH Network IR Remote Control
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
I have a sanyo tv and the remote is no longer functional, i dug out my old urc11a universal controller and would like to know what codes i need to set the controller to my tv.
Try pressing the 'set code' or 'code' button and keep pressing it until the light indicator lights. Press tv and after that you are suppose to enter the 3 or 4 digit code and press enter. However, if you don't know the code, try to repeatedly press the power on button of the remote until you get a response from the tv set. sometimes it would take a hundred times or more before you can get a response. Once you get a response, press enter. I have tried it many times in universal remote controls and it works.
Oct 03, 2010 | Televison & Video
My wireless remote control wont work on my D80
Set the D80's shooting mode to one of the two remote modes. Quick-response remote takes a picture as soon as you push the button on the remote. Delayed-response remote waits two seconds so you can hide the remote behind your back.
May 24, 2010 | Nikon ML-L3 Remote Control
Remote doesn't work
Return ur univeral remotes,try this website 1-800-Remotes Factory original to buy a original remote.
Dec 15, 2009 | RCA Universal Remote Control
Direct Tv remote, no response...
TRY CODE 11531 FOR DIRECTV. WORKS FINE WITH MINE
Nov 28, 2009 | Directv RC23 Remote Control
Suddenly stopped working, green light on remote works, but no response from car. No locks, trunk, or start.
Could be many things, loose ground or power wire on the 561, there is an inline power fuse on the red wire leading to the control unit that may be blown. It may just need to have the remotes reprogrammed to the control unit, sometimes the control unit just stops recognizing the remotes. If you have recently had the cars battery replaced, or jump started the car, check the fuse at the control unit first.
Aug 17, 2009 | Directed Dei Valet 561r Remote...
Remote doesnt seem to work on all the button can it be replaced
Did you check the battery of the remote?
Remote is jamp. Take the battery out and put it back. It will help sometime.
Did you notice the light in front of the TV response to remote control whenever you press? If yes, the remote works fine - problem comes from your TV.
Aug 12, 2009 | Televison & Video
LCD button sticks sometimes....very annoying.
I would bet it's the graphics your using. If your using a high resolution graphic as a button, the remote may have trouble due to memory limitations. You need to drop the resolution on the graphics if that is the case.
Let's eliminate the chance of a faulty remote by using one of the factory installed templates. If you still have the same response time problems contact me for some advanced troubleshooting.
Regards,
Vincent
Total Control Remotes
www.totalcontrolremotes.com
Programming Universal Remotes & Advanced Control Systems
Jan 15, 2009 | Universal Remote Control MX-3000 LCD...
Remote control
Try replacing the battery in the remote. CR2025 or equivalent.
Dec 26, 2007 | Philips 32PF5321 32 in. HD-Ready LCD...
23 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
