Audiovox CDM8910BM Cellular Phone
Problem for Audiovox CDM8910BM
No response to be switched on
By mohy on Sep 01, 2006
I have AUDIOVOX CDM-8910 BM. While it was under car charge boosting the charging process terminated suddenly and a black screen came on. The cell phone is now does not respond to be switched and dose not carry on for the charging process using either car or home charger even with battery replacement. Is there any possibility to reset or repair this failure?
Regards
Solution #1
posted on Sep 04, 2006
Somewhat Helpful)
harley12
Rank: Master
Rating: 81%, 294 votes
Try this. Take the battery out. Wait 30 seconds. The phone memory should reset itself. Reinstall the battery. Turn on the phone before you plug it in. It should come on for just a couple of seconds. Then plug it in. See if that helps.
If not, behind the battery there should be a reset button. Try resetting the phone there. Make sure you have all your phone book down on hard copy. You will loose all your information by resetting the phone that way. But it does reset it completely.
Also make sure your phone has been updated. Either online or at your phone service by a tech.
Good luck.
Was this helpful?
Yes
No
Solution #2
posted on Apr 12, 2008
Somewhat Helpful)
mobile guru
Rank: Apprentice
Rating: 75%, 1 votes
this is the most bad sollution u stupid
Was this helpful?
Yes
No
Popular Solutions for Audiovox CDM8910BM Cellular
Questions and Unsolved Problems for Audiovox CDM8910BM Cellular
Do you recommend Audiovox CDM8910BM?
Answer
Answer
I cannot activate the ring tone. Whatever I do, only the vibrate mode stays on. On the main screen... (More)
Answer
am un nokia 2630 si dupa ce a functionat impecabil 1 an jumatate,acum,kiar si fara cartela se... (More)
Answer
Ireplaced the battery and now the screen says please wait restoring user data -(4) However the green... (More)
Answer
when my phone on and when im at home it gets no signal
Answer
When I turn on my phone, the display shows the voice prompt for voice dialing. How do I turn this... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Audiovox CDM8910BM Cellular...:
Top Cellular Phone Experts
Rank: Guru Guru
Solutions: 563
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Cellular Phone Experts
Top Cell Phone Repair
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
