Question about Tower Airmate Ionic Fan with Remote Control, Oscillation, Ionizer with Build-in Ion Generator, Three...
If u turn on the unit automatically shut off.
Imarflex tower fan wwwwwwith ionizer
Lasko fan wont blow air
Sounds like the fan motor is the problem
Aug 31, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
New Lasko Tower Fan smells when we have it on the ionizer option? Is this smell toxic?
Ionizers generate ozone, that is the same smell that you would have near an electric motor or a copy machine. The smell is caused by electric sparks that occur during the ionization process. Essentially high voltage is applied to a grid, air passes over this grid and electrons jump off of it and into the air. They then attach to any particles that are present in the air and make those particles attractive to anything less charged than they are.
There is a limit to how much ozone an air ionizer is allowed to produce because ozone is a respiratory irritant and is not desirable to have in large amounts. Ozone also damages rubber. A commercial air purifier has to certify that it is in compliance with that law in order to be sold. The difference is that they can change characteristic based on how clean the grid is and how much humidity is present.
Jul 01, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
It turn on , revolve but no air comes out
I am having the same problem. Did you ever fix your fan?
Aug 29, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
How do I clean the blades on my lasko E20739 fan
Do you have the still have the e20739 lasko fan, i need the plastic blade on the unit
Jul 19, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
How does the "Ionizer" work on the Lasko 48" Wind Curve Tower Fan ? Shouldn't there be a HEPA filter to change or something to clean once in a while ??
I'm not exactly sure, but I think that an IONIZER has nothing more than metal blades inside that 'capture' dust/debris and contaminants from the air on the blades. There should be a handle to lift up on and remove the long blades.
You rinse the blades with warm soapy water, dry them and put them back in. Maybe I'm thinking of something else, but to me, that is what an ionizer is. Hope this helps at least some.
Best, Jennifer
Jul 08, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko ionizer 48" fan
Hi suedevito,
In case an electrical appliance does not do anything anymore, I always first check the fuse(s). There can be a fuse in the electrical plug (in case of UK-type of plug for example) and possibly also somewhere within the fan's housing. In case you do not know how to measure a fuse, just simply replace all the fuses in one go with a new fuse of the same (!) rating. I hope this will solve your problem.
Nov 08, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
I have lasko fan sudenly it stoped oscillating can u help me with this ? Lasko 48" Xtra Air Tower Fan with Air Ionizer.Model 4820
I have the same issue, i determined the oscillating motor has a bearing failure. I need to find a replacement motor.
Jul 17, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko tower fan with ionizer
Try a can of compressed air. It's impossible to get inside.
Apr 21, 2008 | Lasko 48" Xtra Air Tower Fan with Air...
Tower Airmate Ionic Fan with Remote Control, Oscillation, Ionizer with Build-in Ion Generator, Three... Logo
Top Tower Dryers Experts
Jay Finke
Jay Finke
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Tower Dryer Expert? Answer questions, earn points and help others
