Question about Tower Airmate Ionic Fan with Remote Control, Oscillation, Ionizer with Build-in Ion Generator, Three...
Imarflex ioizer IF-732Rfan if u turn on the unit not working
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode http://www.manualslib.com/manual/793900/Panasonic-Kx-Tg1061c.html?page=25
do not think night mode would cause your problem.
check dialing mode #120
TONE ?
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
Tip
Instead of resetting rear speakers each time.....
I have found a similar problem with the rear speakers on this unit (needing to be reset each time the unit was turned off), but found a quicker way around it.....with both the main unit off and the rear receiver off: turn on the rear speaker receiver, then the main unit. If the blue light on the rear receiver does not come on, turn off the main unit, and turn it back on again. This has worked for me ~50 times or so and has worked repeatedly. It's faster than going through the reset phase each time. Also when turning off the system, turn off the main unit first, and then the rear receiver. Sometimes I also simply leave the rear receiver on since it pulls only 4 Watts. Hope this helps any users.....(it also works on my boyfriends older generation model).
on Dec 28, 2008 | Samsung HT-WX70 Theater System
Ask com lg ac window unit control panel stopped working
Hi Gina, Try turning off the unit at the electrical panel. turn off switch, wait 15 min. turn switch back to on position. Turn on AC unit. Hope this helps.
Oct 21, 2013 | Heating & Cooling
Unit will not turn off
Sounds as if the control board took a power surge.
Jul 24, 2017 | Amcor CF14000 Portable Air Conditioner
Why is Mr Slim MS-SGF24VC outdoor unit working when indoor unit off
Possibly a bad control board in the outdoor unit. Pull the disconnect outside to stop machine, wait 10 seconds and out back in. White mist was likely frost built up on indoor coil due to condenser running without the fan.
Jun 11, 2017 | Heating & Cooling
Turning signals work when they want too
Since the unit reuires power from the hand control - cluster switch - the voltage on the turn signal unit must be checked so that it is confirmed that the switch works.
If so the fault can be the unit failing to work which must be double checked before it is replaced.
Also check the fuse box for loose conection in the circuit.
Nov 22, 2011 | 1996 Chrysler Town & Country
My blinkers dont work. fuse is good. hazards work. what might the problem be
locate the hazard flasher unit under the dash by turning on flasher and feel flasher unit clicking. the turn flasher unit looks ths same and is close to the signal flash unit and may be interchangable. switch the 2 units and see if the turn flashers work now and replace faulty flash unit
Feb 12, 2011 | 1999 GMC Suburban
My graco monitor has one red light and a row of green, instead of all green, and it is not making any sound anymore
Try pairing the parent and nursery units again. First, turn off all of the units. Place the broken parent unit within 5 feet of the nursery unit. Turn on the parent unit. Turn on the nursery unit. Within a few seconds, the top 4 green LEDs should shut off. Then you'll hear a few beeps and the connection LED should turn from red to green. If this doesn't work, power off and try again using the AC adapters instead of battery power. I did it without plugging in the parent unit but the battery died as soon as the units paired up again. It's working fine from the docking station though.
Dec 15, 2010 | Graco Imonitor Digital Baby Monitor
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Heater works after being off a while
If the unit is remote control try to unplug the supply of the unit(or off and on again circuit breaker) and operate the unit again. If it wont work then call a qualified technician to check the unit, maybe there is a problem with the unit control.
Dec 21, 2007 | Weather King 12AJA4801AH Air Conditioner
Tower Airmate Ionic Fan with Remote Control, Oscillation, Ionizer with Build-in Ion Generator, Three... Logo
53 people viewed this question
Top Tower Dryers Experts
Henry  Thomas
Henry Thomas
Jay Finke
Jay Finke
Are you a Tower Dryer Expert? Answer questions, earn points and help others
