Question about HP Office Equipment & Supplies
Inserted new cartridges will not print says ink low
  • 2,785 Answers
Plz try by reinstalling the drivers
Posted on Oct 28, 2008
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
Low ink indicator
Turn the printer on.
Lift the lid that covers the print-head mechanism.
Wait for the print-head to slide to the position at which the ink-cartridge(s) can be removed.
Press down on the ink-cartridge, to "unlock" it from the print-head.
Gently remove it.
Insert a new/refilled ink-cartridge, and "lock" it into place.
Print a "test" page.
May 08, 2011 | HP Deskjet D4360 InkJet Printer
I refilled the ink cartridges on my canon mp250 copier because it stoped printing. The little info box said that the ink was running low now it still won't print . I 've re inserted the ink cartridges...
originally, when u have ink cartridges in Canon product run low u need to buy new ones, because it was designed like that. even u have refilled the old cartridge full, it will detected low ink because the old cartridge already detected for the beginning. this designed to make Canon buyer to buy new ones ink cartridge. but, there some trick to make your old cartridge detected as new one, all u need just to reset the setting for cartridge recognition. try to visit this site:
maybe this site can help your problem, regard riyan.
Mar 09, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How to load a MP130 cartridge?
  • 1 Turn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
  • 2 Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
  • 3 Pull out the used ink cartridge by pulling straight up from the print head,
  • 4, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
  • 5 Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
  • Nov 13, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
    Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
    • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
    • The protective tape is not removed from a new cartridge.
    • Contacts on the cartridge are not making proper contact with the print carriage.
    • The cartridge is remanufactured or refilled.
    • The cartridge is defective.
    Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
    "No Black Ink Cartridge" after a new cartridge has been inserted
    It sounds like the actual ink sensor has failed. You can check if it has a print head cleaning routine in the software on the computer. Most likely the actual ink sensor has died though, I've seen this many times. Call Brother to confirm, or maybe if it's still under any kind of warranty: 877-276-8437
    Aug 08, 2009 | Brother MFC 240C All-In-One InkJet Printer
    Low ink message
    just ignore the message and print
    if it doesn't print try to dip the lower part of cartridge in warm water, not hot, for five mins and dry it with tissue and try to print
    May 03, 2008 | HP Deskjet D1341 InkJet Printer
    Hi I have just inserted a new HP ink cartridge 94 into my HP PSC 2350, as the ink was running low. I was printing photos, which keept printing with a red line throughout the picture. After inserting the...
    Try opening the printer properties and cleaning the print heads (should probably be done each time a cartridge is changed), it uses some ink up but should clean the build up from running the previous cartridge dry and hopefully solve your printing problem.
    Good luck.
    Mar 29, 2008 | Computers & Internet
    Won't print
    I insert the new ink cartridge still it saying ing is low( its original)
    Mar 12, 2008 | Dell All-in-One Printer 810 with 2-Year...
    Incorrect ink level reading
    kiwipom, While ink cartridges look like plastic cups that only hold ink...they are not. The information the printer needs to think it has a "NEW" set of ink cartridges is on the cartridge itself. You must fakeout the printer to believe you are inserting "new lexmark" inks. Printer companies make money from the repeated sale of the ink, not the printer itself. I had an old epson that I would refill I would then have to place pieces of tape on the cartridge turn the printer on, remove the cartridge move the tape to another side of the cartridge turn on again etc. Anyway lexmark may need the same. When the new original cartridges show try them first to get the printer "thinking" correctly. Let me know what happens. Good Luck, Tim
    Feb 27, 2007 | Lexmark X7350 All-In-One InkJet Printer
    143 people viewed this question
    Ben Johnson
