Question about LG WM2701HV Washer
LG washer WM2701HV won't start
Washer os ded
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: I have a LG WM2701HV
How much soap are yall using? The washer is supposed to wash with less water. Too much soap causes problemas. Less than a year? Look for items in the filter.
Posted on Jun 09, 2011
inokumum
  • 10 Answers
SOURCE: My LG washer won't power up
Double check the cord to make sure all the wires are hooked up to the washer correctly, check your breaker/fuse box to make sure you don't have a tripped breaker or blown fuse, and check the outlet for power by plugging a known working item into it or using a circuit checker.
If the washer is getting power, try holding the power button down(if there is one) for 3-5 seconds.
If that doesn't help, here's a link to LG's customer support options: http://www.lg.com/us/support/contact-customer-service
Posted on Feb 09, 2012
The washer stops at 39 minutes on a regular wash cycle and the code OE is displayed
This fault code can mean that the pump is faulty as well as blocked, first of all check for a blockage and, if none is found then the likelihood is that the drain pump is faulty. Should you need it, the most common drain pump used on LG washers and washer dryers is this one.
On non-display panel models this fault code is denoted by the lights for 800, 500 and No Spin being lit or flashing.
  • Check pump filter is clear and there are no obstructions
  • Check the drain hose for obstruction
  • Check the drain hose is not kinked
  • Check the drain pump filter and clean if required
  • Check the air chamber and pressure sensor hose
  • Check drain pump, normal resistance is 152-175?
  • Check drain pump rotor
  • Check connections to water drain pump
Oct 09, 2015 | LG WM2701HV Washer
What is the button combination to put the LG washer in test mode?
i believe it is the power button along with the two center buttons on the right.
Mar 30, 2015 | LG WM2701HV Front Load Ultra Capacity...
My LG wm2701hv washer will only turn on if I disconnect for 20 seconds and reconnect. Once the load finishes I have to do the same thing all over again. Any ideas?
try holding in the power button for 10-15 seconds while unplugged, if that does not reset, try the same just after plugging back in. good luck.
Mar 30, 2015 | LG WM2701HV Washer
I have a LG WM2701HV it is a year old and sometimes the washer is not turing on and doesn't turn. I have checked the wall outlet and other electronics work in it and the breaker. Help!!
Hi Robert.
If the washer is occasionally not starting there may be an inlet problem or the door switch may be defective.
Most LG washers display error IE (inlet) or DE (door) if the problem is detected. In some case the washer simply does not start.
Check that there is pressure from the house.
If machine does not fill the inlet valve must be tested. The resistance across valve's terminals must be between 0.8 and 1.2 KOhms
The valve must get 120VAC in first part of the cycle. Testing must be done by a trained person.
If the problem is intermittent the problem is more likely the door switch.
The door switch assembly is held by two screw. The door lock must click once or twice when the start/pause button is pressed to start the cycle.
The door switch can be tested reading impedance across its contacts. The reading must change between infinity and zero when the door is opened and closed.
In some occasion overloading may result in the washer not starting. Check if the problem happens in coincidence with overloading.
Dec 28, 2011 | LG WM2701HV Washer
Lg WM2701hv hose squeals while filling
The only solution would be to replace the water valve. You will need a qualified technician to help you.
Good luck
Jun 10, 2011 | LG WM-2277HW Front Load Washer
I have a LG WM2701HV it is less than a year old and sometimes the washer turns on and other times it doesn't turn. I have checked the wall outlet and other electronics work in it and the breaker is...
Jun 09, 2011 | LG WM2701HV Washer
I have LG washer less then 1 yesr old and bleach is not dispensing from dispenser
You may have one of 3 issues. The dispenser valve is not working for the bleach dispenser, the control board is not feeding power to the dispenser valve or the dispenser drawer is not draining the bleach properly. You will need an authorized LG technician to help you with that.
Good luck
May 30, 2011 | LG WM2701HV Washer
Sears botched repair on my LG washer (Model WM2701HV). Replaced both boards but suddenly motor does not spin - only hums. Tech claims motor needs to be replaced but it was fine until they replaced the...
If a LG washer hums look into a part called a HALL SENSER it is a small part that go's in the motor at the rear of unit they are known to go and the humming is the give away ..If this helped please vote if you need more help please feel free to contact me..czerney@msn.com
Feb 02, 2011 | LG WM2701HV Washer
Wont finish the load
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jul 21, 2010 | LG WM2701HV Washer
LG WM2701HV Washer Logo
56 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
