Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
WAN lights not blinking have no internet
I have problem in connecting internet, usually if i open my PC's automatically i receive internet but this week i really frustrated because i cant connect in internet , i tried to reset it to get the factory defaults and reconfigure it but still not connecting in internet . i tried many things but still not working , i just notice that the lights in my router the "WAN" is not blinking but have lights and to my modem have lights but it's not blinking too. i did try too direct the modem in 1 of my PC and it works perfectly i can browse in internet, guys do you think that my ROUTER DI-604 is broke and if its not what is the cost of it's error . i really need the answer please
  • blead_baki_1
    blead_baki_1 Feb 24, 2012
    just dont bother to the my questions . i fix problem if you have same problem just send me a mail maybe i can help
Saurav14
  • 25 Answers
SOURCE: No response from the DI-604 D-Link Router
The cable must be of parrallel type......(not cross)... connecting router and the modem or PC...
Posted on Dec 28, 2007
  • 11 Answers
SOURCE: D-LINK DI-604 STATIC IP
Log into the router and go to the configuration page for your WAN port. Change the connection type to static ip.
Posted on May 01, 2008
amusedgeek
  • 787 Answers
SOURCE: How to enable WAN IP in a DI-604 Router for 3 computers
"I wanna make the 2nd pc a server but it isn't accessible through the WAN ip. "
Well that explains everything. If you want to get to 192.168.0.102 from the internet, you need to tell the router where to send packets. You do this by going to the ADVANCED section and configuring Virtual Servers. For example: If you are setting up the computer at 102 as a ftp server, ftp uses port 21. The name would be FTP, private IP would be 192.168.0.102, Protocol is TCP, and the Private and Public ports would normally both be 21. Don't forget to Enable the rule.
What this does is tell the router that when ever a request comes in on port 21, it should forward it to 192.168.0.102. To access the external side of the router you need to go to 70.55.84.233 (according to the image you posted)
Posted on Jan 03, 2009
  • 83 Answers
SOURCE: di-524 router problem
You do not need a password for cable. You need to make sure that your router is using DHCP. Whenever you connect something to your cable modem, you MUST turn off everything. Then turn on in this order:
1 Turn on cable modem and wait until the modem syncs with your ISP.
2. Turn on your modem and wait until the router and the modem sync up.
3. Turn on your PC
Your cable modem will remember the MAC address of the last device that was plugged into it, which is why you must turn off your modem to clear out the modems memory.
Posted on Jun 05, 2009
perpetually
  • 360 Answers
SOURCE: i have D-link cable router(DI 604)..i want to
http://www.antifart.com/2006/09/02/d-link-di-604-firmware-rev-e.html
Before using these files, make sure you have the E Revision of that router, you can check by looking on the sticker that contains all the model information like serial, model number.
Be careful while doing a firmware upgrade, very easy to brick your router. Bricking refers to making the router no more useful than an expensive paper weight.
Posted on Oct 20, 2009
My at&t Motorola 3360 has every light blinking but is still working. The Power and DSL are continuously blinking red and the ethernet, internet and activity are all blinking green.
Here's the thing...if the modem is unplugged, and you press the "Reset" button, or any button, nothing will happen because the modem is UNPLUGGED.
When you plug it in again, there is usually a few minutes or so during which time the lights will blink. Eventually, when the DSL connection is established, the blinking should decrease. But, there will always be some blinking going on to indicate that data is being transmitted.
If the "Ethernet" light is blinking, then a computer that is plugged into the router is transmitting/receiving data. If the "Wireless" light is blinking, then a computer that using a wireless connection to the router is transmitting/receiving data.
If a red light blinks, then that usually means the DSL connection has been broken. When that happens, for whatever reason, the modem will automatically begin its initialization routine and will continue to do so until connection has been established. During that time, LEAVE IT ALONE.
If you uplug the device, or if you press ANY button while the device is attempting to correct itself, you can cause permanent damage.
So, you are correct. It's not a problem. I'm sure you've heard the phrase "If it's not broken, then don't fix it." There's a lot of truth to that.
I hope this helps.
Randy
Dec 01, 2012 | Arris 3360 AT&T DSL Modem - -
Router keeps losing WAN conection, but led lamp is blinking...
maybe new aerial finds more wifi hot spots, mine started doing that when i changed router port forwarding. but if in doubt just press reset button for 10 secs - might need to se paper clip and look hard around router for a little hole to stick it in..
...lol
Jul 12, 2017 | ASUS RTN10 wireless router
I have Belkin N150 Rouer. My internet is Time warner. It has no connection between the modern and Belkin router. How can I set up Belkin N150 Router to solve this problem?
f the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
NOTE : IF YOUR INTERNET SERVICE PROVIDER IS CABLE FOLLOW THE BELOW STEPS
3.Under Internet WAN , SELECT the connection type as Dynamic.->NEXT
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 60 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
FOR PPPOE OR DSL CONNECTIONS
1.Under Internet WAN , SELECT the connection type as PPPOE ->NEXT
2.ENTER THE USERNAME & PASSWORD PROVIDED BY YOUR IN INTERNET SERVICE PROVIDER
3.CLICK ON APPLY CHANGES
For any advanced help, revert asap!
Thanks and regards,
MILAN
Jan 20, 2011 | Belkin Connect N150 Wireless Router...
I have a Belkin N wireless router, model F5D8236-4 v1. I am unable to connect to the internet using the router and I've even tried resetting the router with no luck. The "modem" light on the...
i have a belkin N wireless router model:F5D8236-4 v1 i have had it installed on my computer but it has since been wiped so there is no trace of me having it installed, since this i have moved home and ost the disk that came with it but i need to put the router back on due to my daughter having a laptop, how would i get the software for it if i have no disk?? please help!!!!!!!!!!!
Jan 07, 2011 | Belkin (F5D7231-4) Wireless Router
My laptop doesn't have any connection this am. Can you tell me how many light should be on the router or blinking. I have a Dir-601
The router's POWER lamp should be on, and steady.
The WAN lamp should be on, but blinking when the router is sending/receiving from the Internet.
The LAN lamp should be on, but blinking when the computer is sending/receiving from the router.
Disconnect the cable from the LAN port.
Turn the router off.
Turn the router on, and watch the lamps -- they all should light up, briefly, and then the WAN lamp should blink for a short time, as the router obtains a new IP-address from your ISP.
Connect the cable to the LAN port, and watch the LAN lamp blink for a short time, as the computer obtains a new IP-address from the router.
Oct 24, 2010 | Computers & Internet
Router won't broadcast
Use your computer's web-browser to connect to the web-server "inside" the router.
Check the 'WAN' settings -- they seem to be OK, since you have Internet access.
Check the 'Wireless' settings, or just rerun the Wireless Configuration Wizard, to rebuild your wireless network.
Apr 24, 2010 | Linksys Wireless-G WRT54G Router
Internet loss
Hello
Check to link to find out that how your router should be connected
http://onlinehelp.verizon.net/consumer/bin/images/Fios/DLinkCabling_Updated.gif
Then unplug all the cables , power off the router for few minutes and replug all the cables again and restart the computer :
Check the link below to configure the router:
http://support.dlink.com/emulators/WBR2310/index.htm
Jaspreet
Apr 12, 2009 | Computers & Internet
MSI wireless G RG60G fast bliking wan.
hello!
fast blinking wan light may indicates that it receiving or sending data. try the ff and see if this may work:
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
Apr 24, 2008 | MSI Wireless-G RG54G3 Router
No connection
Is your physical connection right???
the WAN port should be connected to your modem, and the LAN1 should be connected to your pc.....
if right, but still doesn't connect....
check if the lights of your router is working
the POWER should have a solid light,
the STATUS, WAN, LAN 0r WLAN should be blinking...
What kind of connection do you have?
is your modem automatically detects your password...?
or you manually type your password to connect to the internet...?
Jan 17, 2008 | D-Link DI-704P Router
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
411 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
