Question about LG 24 in. LDS 5811 Built-in Dishwasher
DW does not fill
I have a just installed new lg dishwasher that does not fill. Water line is working and power is on. I can hear action in unit, but no water enters.
  • kirstenb Nov 04, 2008
    How wierd. I have the exact same problem that started on about the same day. The water line from the house going to the dishwasher works. It SEEMS that the rubber washer at the end of the line that goes into the dishwasher (an actual part of dishwasher) deteriorated and part of it got into the line, blocking the line.
  • 833 Answers
There are a couple of possibilites.  In some cases, the float which determines how much water is in the machine jams.  Generally, this float is located in the front on the right side.  If you find it, move it up and down to free it up.  If there is no float, you may have a diaphragm type sensor.  This is a tube located under the tub connecting to a 2 inch or so disc with two wires coming out of it.  If you find this, place a short across the two wires (power off when you do this!).  If the unit fills, disconnect the short and replace the sensor.  Caution: the unit will not know when it is full so stop the experiment immediately!!!
If your unit is brand new, I suggest you get the dealer or manufacturer in to have a look at it.
Posted on Nov 16, 2008
Replace dishwasher
Is your DW plumbed into the garbage disposal as many are? Or does it have the drain line running into a pvc opening in the sink drain line? Remove the drain line to see if water gushes out. If no or minimal water leaves your drain line from the DW, then the problem is internal in the DW. Most likely cause is a plugged screen at the inside bottom of your DW, or the pump is blocked. Best way to resolve is to get a wetvac and just suck all the water out of the inside before you remove the DW. Otherwise you will have water splashing out on your floor. If you can see the screen is plugged up after doing so, then pull the screen out and then turn the DW on. If operating normally it will go into the pump out mode first before adding any water. Turn off the water to the DW under the sink first to eliminate any concern about adding additional water into an already filled up DW. Good Luck!
Feb 16, 2017 | Dishwashers
Shortly after cycle starts, a whirring sound starts, is this a problem with the motor?
with LG dishwashers: after starting, 1st, DW pumps out any remaining water, 2nd, DW fill fresh water, 3rd, main wash motor starts, which is normally a whirring sound. (If you here grinding or rattling, then you have a problem.)
Feb 28, 2011 | LG LD-1420T1 Dishwasher
My plumber just installed a new water supply line for my dishwasher. Now the pump comes on but no water fills up in the machine. If I fill the bottom of the unit with water, it works just fine. Even though...
You don't know how many times I've heard and found the shutoff valve off or partly turned off. Water entering DW is from line pressure not pumping. Items to suspect (again) the water supply valve (would'nt be the first time a new valve is bad). The supply valve (3374621) at the Dw, the float safety switch (normally at front left side,)...remove lower rack, lift float housing up and down. You should hear a click both ways and the housing should be free. Is the Dw fill valve getting control signal from timer. Should be 120v for about 60 sec.
Ric
Mar 10, 2010 | Whirlpool 24 in. DU915QW Built-in...
The first cycle water is not hot - all other cycles are hot - the water in the sink next to the dishwasher is not???
Where does the dishwasher connect to hot water? If it is connected to cold it must be changed. From your description, the water is coming from a long way off and has to warm the pipes as it travels to the dw. The dw should have a heater to bring the water up to temp after filling before it runs, if this heater is not working, the first run will be cold and the next hot because you have drawn enough water through the pipes to bring hot water to the dw.
1. Change where the dw gets hw.
2. Run hw in the sink before allowing the dw to start (if connected to same line).
3. Fix the dw's water heater.
Three possible fixes. Good luck.
Aug 27, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Hi, I installed LG dishwasher, control board is working, water is coming from the water line but when hooked up to the dishwasher and dishwasher is on, there is no water coming into the dishwasher....
it should drain a bit of water out before it fills when it first starts. if that water doesn't drain out then you may have a drain pump fault. You can test this by dumping a few glasses of water into the machine then starting it up ( you should hear it drain that water out)
if that worked... then you have a fill solenoid fault or a line filter fault.You can check power to the fill solenoid or give it a couple of taps when its suppose to be filling to see if its just stuck. the inline filter could be plugged where you hook up the water supply to the machine (clean it or take it right out)
Aug 23, 2009 | LG Dishwashers
Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Jul 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Installed new dishwasher
definitely no delay in fill, i would recheck the water line make sure not kinked, also check wires leading to the valve for good contact to valve body
Nov 04, 2008 | Tappan MDB531RF Dishwasher
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Maytag Dishwasher
Newer Maytags should fill close or up to the heater not over. Sounds like your alright for now but I would get that water line fixed.
May 15, 2008 | Maytag 24 in. MDB8951AWS Stainless Steel...
Water problem
Many dishwashers will drain at the beginning of any cycle.
If the water does not fill after the pump-out cycle, then the problem is either the fill valve or the float switch. You should be able to hear the float switch click as you raise or lower it. The fill valve usually hums whenever it has power.
If the fill valve has power but doesn't open, (use a voltmeter) replace the fill valve. If there is no power at the float switch, nor at the fill valve after pumping out, then the clock / timer is at fault.
Mar 10, 2008 | Dishwashers
LG 24 in. LDS 5811 Built-in Dishwasher Logo
102 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
