Question about LG Kitchen Ranges
Lg stovetop oven, burners stoped working
All burners stopped working at same time
fridgetech
  • 473 Answers
SOURCE: Oven Doesn't Work but stovetop burners do..
Most common problem is a bad oven ignitor.  If yours looks this way then it should be replaced.  This will most likely solve your problem.
Posted on Oct 21, 2007
SOURCE: Blinking oven and heating Lights
for no reason the cleaning light went on, even though the oven was not on. The oven light and heating light were alternating each blinking 5 times. The door locked up, too. It seemed to think it was in a cleaning cycle. Any way, problem solved by throwing off the main breaker and all is working fine since... except now, for no reason the oven fan, not the exhaust fan, stays on all the time!
Posted on Jan 03, 2008
jyackle5
  • 8197 Answers
SOURCE: kenmore range control panel not working
sounds like the control board blew on you replace it.
Posted on Dec 16, 2008
  • 1214 Answers
SOURCE: LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Posted on Jan 24, 2009
shinn8
  • 85 Answers
SOURCE: stovetop works but oven does not.
Most likely your problem is the glowplug aka oven igniter. Even though it comes on it must reach a certain temp for the gas to come on. Occaisionally the valve will be bad but 90% of the time it is the igniter. Part number is 74007498
Posted on May 29, 2009
I have a Kenmore 790.96224 electric range and the burners and oven do not work, but the clock is working. how do i fix?
Try replacing ONE stovetop burner and see if the new one works. If it does, replace more stovetop burners. If the new ones all work, replace the oven burners.
If that first replacement stovetop burner STILL doesn't work, don't replace any more. Instead, check (or have checked) the circuit breaker for the range. It may get power from a second source to power the clock.
Jul 26, 2014 | Kenmore 96222 / 96224 / 96229 Electric...
F19 error code on lg double oven
had F19 error code on lower oven, F9 on upper. Pulled stove out and turned the regulator switch ON. Worked instantly. I thought I had the regulator on because the stovetop worked. The stovetop regulator is separate from the main regulator!!
Jun 22, 2011 | LG LWD3081ST Electric Double Oven
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Kitchen aid sparking on all burners
one of the burner switches is shorted, take off plate that covers the switches and remove the wires one at a time on each switch then reattach wire before going on to next switch.continue until sparking stops,replace switch (easy fix)
Sep 08, 2009 | KitchenAid Kitchen Ranges
How to light oven with electric power off?
Sorry, but this oven will not work without electricity. Looks like stovetop suppers for a few days. Hope this helps!
Jan 28, 2009 | Ovens
Jan 24, 2009 | LG 30 in Kitchen Series Dual Convection...
DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven & broiler not working
Please follow this LINK for your manual
Jun 16, 2008 | Hotpoint RGB528 Gas Kitchen Range
Feb 12, 2007 | Thermador PG486GEBS Stainless Steel...
Kitchen Ranges Logo
13 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
