Question about LG 37LC2D Television
"I have LG 37LC2D TV,when I turn the power on remote controlled or manually it immediately powers off. Is this an issue with the on/off switch inside the tv and how can remedy the problem?"
  • LG Master
  • 1,205 Answers
I have an LG as well.
My troublshooing says:
"Check the power control setting.The power supply may be interupted.
Check if the Auto sleep feature is actiated in the Time settings.
Refer to the " Sleep timer".
If there is no signal while the TV is on, the TV will turn off automatically after 15 miutes or so"
Posted on Feb 24, 2012
5 Suggested Answers
  • 59 Answers
SOURCE: my remote control doesn't work for lg tv model #
have you tried and see if the led is flashing wile looking through a camera on a mobile phone ? this will tell if the remote is faulty.
if its not flashing then open up remote and look for bad joints/connections etc.
the most common is around the led sender and the xtal unit.
Posted on Sep 07, 2009
  • 235 Answers
SOURCE: Remote not working on my LG 37LC2D
Try replacing batteries and reprogramming both remotes.
Posted on Jul 05, 2009
stradeteox
  • 88 Answers
SOURCE: I have an LG 37LC2D LCD TV that is locked.
Bad filters on the main board or a bad AUX REMOTE jack on the back of the unit (also part of the main board) are the cause of this problem.
Try plugging in any jack that will fit into the AUX REMOTE jack on the back and then pulling it back out. This may fix the problem or remove any dust that may have collected in the jack. If this jack has something plugged into it (or goes bad) the TV will no longer have remote control operation (because it thinks an external remote box is being used). If this does not work then the main board will need replaced.
Note, many repair techs will think the IR board is bad (the Infra-Red Receiver board) at the front of the TV, but this is usually not the case with this model.
Hope this helps, please rate my solution.
Posted on Jan 11, 2009
SOURCE: LG TV no longer responds to the remote control..
I think I like solution #01 (free) over solution #02 ( you have to pay). I have a LG 32 inch. There is no Headphone jack input in the back of the set but there is a remote input. I cleaned all inputs with air can: voila! My remotes now work! This Website saved me a few bucks. THANKS!
Posted on Apr 12, 2010
37LC2D LG PLASMA TV Solid red light is on no sound picture
The unit is stuck in standby. Have you tried turning it on manually on the set or changing the batteries in the remote. Does the light flash when you try to turn it on?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG 37LC2D Television
LG 37lc2d-UE will not turn on with remote. remote is fine. replaced one capacitor 6 months ago which resolved problem temporarily but it is happening again.
If the remote control is fine, and you're sure about it, check and replace the infrared sensor, inside the TV. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 27, 2014 | LG Televison & Video
I have an LG model 37lc2d the screen is black but has illumination and no sound at all and the green power light flashes 16 times upon powering up?
Things to check: Make sure your TV is set to the correct input.
I DK about the light flashing 16 times but that could be a stuck key on your remote control. If you can, urn off your remote and try turning on by hand and going through the "INPUT" choices to make sure you have it on the correct setting. BTW, if your TV is 5 years old, you'll make the money back in no tie if you get a new "Energy Star" TV. The new Energy Star TVs run on very little electricity compared to 5 years ago.
Jul 03, 2012 | LG 37LC2D Television
Tv powers up, runs for about 5 minutes then goes to black screen, cant do anything with remote, unplug for a while, turn on ,, same result ?
You may have dying power supply problem due to bad DC filter caps, poor solder joints in the power supply or the backlight inverter board
Jun 08, 2011 | LG 37LC2D Television
Lg lcd tv 37lc2d no headphones socket - how do i connect headphones?
You can purchase a cable to connect to the Audio Out ports on the back of the TV. It will have 2 RCA connectors on one side that plugs into the TV and a 1/4" stereo jack on the other end that you will connect your headphones to. You could even pickup a pair of wireless headphones... they will have a volume control on them! I hope this helps.
Mar 17, 2010 | LG 37LC2D Television
My remote control doesn't work for lg tv model # 37lc2d
Sep 07, 2009 | LG 37LC2D Television
Jul 05, 2009 | LG 37LC2D Television
Our LG TV, model number 37LC2D, won't turn on using the remote or when we try it manually. The fuse is good and the power cord seems to be okay. What can be done to fix this problem so we can turn on the...
sounds like power supply problem!!
i would recommend to replace power board
Part Number 6709900016B
and you can get it form here
https://www.encompassparts.com
Apr 19, 2009 | Televison & Video
LG 37LC2D TV Virgin Cable remote codes
I had the same problem with a LG42lf2500 I tried all codes that Virgin had listed none worked. I then started to program volume control stating at code 0001. 0007 worked for my LG TV LG42lf2500
Jan 08, 2008 | LG 37LC2D Television
Televison & Video Logo
447 people viewed this question
Computer Repairing
Computer Repairing
