Question about Olympus EVOLT E-410 Digital Camera
Card error??? how do i fix the 'card error' ????????
  • khadija zaidi Feb 24, 2012
    ok so i just downloaded glary utilities...how do i get it to work?? as in the 'undelete ' thing.. also i hav a 4 gb mem card..n i dont think i can insert that in my laptop(toshiba)
  • 25 Answers
Depending on the size of the xD card, your camera may need a firmware update to be able to read xD cards larger than 256mb. If the card used to work but now doesn't, try formatting it as FAT16 or FAT32 while it's inserted into the camera. If you still get an error and you have a card reader on your PC, try formatting it from there as FAT16 or FAT32 file formats.
Posted on Feb 24, 2012
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
Write protect error
You neglected to specify the model of your Olympus camera, so I'm assuming it uses SD/SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 02, 2012 | Olympus Cameras
After inserting memory card the error 'this card cannot be used' has occured
The L105 works with SD cards. Make sure you're not using an SDHC card. You need to use SD cards, 2GB and smaller.
Oct 29, 2012 | Nikon Coolpix L105 12.1 Mp Digital Camera...
After inserting memory card in Nikon coolpix L105 the error 'this card cannot be used' has occured. what is the solution?
Oct 29, 2012 | Nikon Coolpix L105 12.1 Mp 720hd Video 15x...
My tascam dr 100 gives a 'writing failed' file error' message and stops recording
Try using a smaller memory card. This only happens to me when using a 4- or 8-gig card. 2-gig and below, No error.
Feb 24, 2012 | Tascam DR-1 MP3 Player
My micro sd wont read on my computer or phone & when i put it in the camera it says ''memory card error''
click start control panel administration tools computer management device manager look through
all of your devices if you see a yellow question or exclamtion mark or a red X
a new driver will need to be installed right click update driver
if you can see your usb drive and its not working scroll to ports(com&lpt)right click update driver
http://download.cnet.com/o2micro-flash-memory-card/3000-18492_4-163841.html
if this fails to fix the problem your sd card might be faulty
hope this helps
Nov 05, 2011 | Electronics - Others
It's showing as a system error & also getting hang.
Hi
The *#7370# is the equivalent of a hard reset on any SERIES 60 mobile. It will delete all software/settings etc., and restore all applications to as they where when the phone was bought.
You can get the SYSTEM ERROR problems from corrupted/edited/deleted/incompatible files that are in use, either in the fone or on an MM/SD card fitted. To see which is at fault, simply remove the card & turn on the fone again!
I get these errors often as I make software on these things (just starting).
If my solution is fix your problem give me the four thumb
Jun 27, 2011 | Nokia C6 Smartphone
Camera will not take pictures. Message on screen says: System Error Zoom I have not had any problems with zoom. How do I fix or clear this message. Thanks, Marsha
Please follow the steps:
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine.
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec... in not done the press both Menu & self time key for 2 - 4 sec.
After all of this if you not success then its a lens error.The lens stuck from the inside becasue the lens guide pin is damaged or out of guide line. In this case you have to replace or repair the camera lens.
Hope helps; keep us updated and remember to rate this answer.
Jun 16, 2011 | Cameras
16G Memory Gets "Memory card Error Please Check Memory Card"
You may try to format the memory card and then try again. If needed, you can use a camera photo recovery tool to recover photos from memory card.
Card Recovery Software Free Download
Apr 10, 2009 | Panasonic DMC-TZ5 Digital Camera
Olympus EVOLT E-410 Digital Camera Logo
103 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
