Question about Toshiba E-studio 281c Copier
Toshiba e-Studio 281C ADF not working
Machine isnt registering any documents in the ADF & is copying or scanning from the glass only
  • Toshiba Master
  • 643 Answers
Make sure the ADF connector is plugged...
Posted on Jul 14, 2012
chad7houston
  • 62 Answers
SOURCE: Toshiba studio 281C problems
You should be able to print on both, but I wouldn't advise it at all. The envelopes are going to jam a LOT and you WILL eventualy get a label stuck inside the machine. Possible....yes. But I don't recommend it. :)
C
Posted on Oct 07, 2008
Bubbabear64
  • 2794 Answers
SOURCE: wrong count
It may need a firmware upgrade to fix the count. You will have to contact a Toshiba dealer in your area to get one.
Posted on Jan 28, 2009
Bubbabear64
  • 2794 Answers
SOURCE: wrong count
You find that answer out on copytechnet.com. There are authorized Toshiba reps available on there to answer your question.
I don't work on Toshiba unfortunately. If I did I would give you the answer.
Posted on Jan 29, 2009
  • 12 Answers
SOURCE: Scan Color document by Toshiba E-Studio 45
E-studio 45 or E4500 is a black and white copier. Hence, it can only scan original document to black and white only. There are some copiers which have the color scan capability but not this one.
Posted on Feb 03, 2010
  • 29 Answers
SOURCE: network initializing message for Toshiba
This is normal each do you turn on the copier for 1 until 5 minutes, next to this time do you have firmware problem.
Do you have a nice day
Posted on Mar 22, 2011
Toshiba e-studio 3510c
Check that the cable that comes out of the back of the feeder is plugged in completely. If not, turn off the machine and unplug the copier before plugging the adf connector in, then turn machine back on.
If that is not the problem, the sensor flag or sensor may be out of place. Where the paper goes in, there should be a black plastic flag hanging down that the paper will move when you insert it, If you can see it and it seems to move properly, then the sensor may be out of place or the sensor/feed medchanism is out of place and it is a little tricky to explain here. The sensor is above the flag, but under a metal plate and you may mess it up worse by trying to take it apart.
Nov 19, 2011 | Toshiba E-STUDIO 211C Copier
E-Studio 281c is it possible to scan a double-sided document on this machine? thank you.
Welcome to FixYa!
It cannot do double sided scanning but can do double sided copying.
Thank you for using FixYa!
Jas247
Mar 24, 2011 | Toshiba Office Equipment & Supplies
I have lines in printed material
If a print result of faxing, copying or scanning has uneven print density, or when copies and scans you make have vertical black lines, cleaning the platen glass may solve the problem.
  1. Turn off the power and disconnect the power cord.
  2. Prepare two clean, soft, and lint-free cloths.
    Note:
    Do not use tissue paper or paper towels as they may damage the machine.
  3. Open the document cover.
  4. Wipe the platen glass (D), the inner side of the document cover (white area) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) with a clean, soft, lint-free cloth moistened with water
    (A) ADF Glass
    (B) ADF White Reference Area
    (C) Document Cover White Reference Area
    (D) Platen Glass
    Note: If you have trouble wiping dirt, use diluted mild detergent (for dish washing).
    Caution:
    * Never use volatile liquids such as thinners, benzene, or alcohol; these can damage the machine.
    * The d
    ocument cover white reference is easily damaged, so wipe it gently.
  5. Carefully wipe away moisture from each part with another soft, dry lint-free cloth. Do not leave any residue, especially on the platen glass.
  6. Close the document cover.
  7. Reconnect the power cord and power the machine back on.
Oct 26, 2010 | Canon MP830 All-In-One Printer
After switch on the toshiba e-studio coming uo
please do the following..
  • Open the ADF cover.
  • If shipping tape is present on the blue document feed-guide assembly, remove the tape.
  • Using the blue handle, lift the ADF rollers.
  • Remove the document.
  • Lower the ADF rollers.
  • Press the two tabs on the document feed-guide assembly to secure the assembly into the proper position.
  • Close the ADF cover.
  • Fax, scan, or copy again.
  • Jan 20, 2010 | Toshiba e-Studio 232 Black and White...
    I have a toshiba e-studio 35. When copying through the feeder a line appears on the right side of the copy. Techs dont know how to fix it.
    "Normally" that is a simple problem. If it copies clean when you lay your original on the glass......but when using the Automatic Document Feeder (ADF) the copy has a black line then it is clearly something in the ADF scanner. Some machines use a strip of glass that is next to the large glass to scan originals when using the ADF. That strip of glass has to be clean top and bottom. Some models use a scanner in the actual ADF. Either way if it copies fine from the glass, the rest of the copier is eliminated from being the cause.
    Is your machine under maintenence contract? Then I would keep calling them until they FIX it!
    Oct 22, 2009 | Toshiba e-Studio 350 Copier
    Vertical line appears in scans using the ADF, but not with copies
    happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
    Aug 18, 2009 | Brother MFC 7840W Printer
    When scanning we are getting this error msg. Syntax error in parameters or arguments
    First try to print a test page and see how it looks. If it is fine goto the copier --- are you trying to scan through the ADF or off the glass? IF you are trying through the ADF try off the glass. If fine off the glass the ADF scan/ reading problem. Check to see if you can make a regual copy. If copy is fine but can not scan through ADF or off of glass, uninstall the scan drivers and download the latest drivers from the makers website, paying close attention to the proper drivers for device and your OS ( operating system). If with the lastest drivers the problem continues you have a scanner problem and need it repaired or replaced.
    Jan 02, 2009 | Toshiba e-STUDIO 282 Black and White...
    Black vertical lines on faxes sent using auto document feeder
    If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
    Nov 15, 2008 | HP Photosmart 375 InkJet Printer
    Toshiba E-studio 281c Copier Logo
    191 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
