Question about Radio Communications
True Blue TB-91EX Bluetooth Headset
True Blue Bluetooth Headset
2 Suggested Answers
casouzaj
  • 1118 Answers
SOURCE: Palm Treo and Jabra bluetooth headset
Turn your headset off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise
Hop
Posted on May 17, 2010
My playstation is asking for a pass key for my true blue bluetooth TB-32-ML
The pass key should be in the manual that came with the bluetooth.
Oct 04, 2013 | Cell Phones
Tb50cr manual
According to the manual , you will know how to use it correctly.Good luck.
electronics wholesale
Dec 16, 2011 | True Blue TB-50CR Bluetooth Headset
I dont have the passkey for the truebluetb31ml
Most blue tooth manufactures use a 4 digit pin ,pairing code they are as follows 0000,1234.1111,or 9999 i hope this helps
Feb 22, 2011 | True Blue TB-31-ML Bluetooth Headset
I ahve a samsung eternity phone from at&t i am trying to get my bluetooth ear peice to work with this phone it is also a motorola.The previous owner of this phone has their information for their blue...
Most bluetooth headsets or earpieces need to be "paired" to the phone before the can be used this usually just means you need to put both devices into pairing mode search (scan) from the phone select your earpiece in the list and enter a security code to complete the initial connection (pair) after that the earpiece can just be turned on and off with normal use
Aug 24, 2017 | True Blue TB-50CR Bluetooth Headset
My lg vx1100 can not find my plantronics 232 explorer and I do not have the instructions anymore.....can anyone help?
The following are for TB-20EL model. But it works in general for plantronics as well. For step 3 make sure your headset is in pairing mode. When you hold the button 6-8 sec, it should turn either solid blue or blink.
for tb-20el:
1. ensure that your phone's bluetooth feature is on
2.Ensure that the headset is off(press and hold button on your headset (called multifuntcion button) for 2-4 sec, teh indicator light will flash red)
3. press and hold the multifunction button for 6-8 seconds until the indicator light alternately flashes blue and red
4. set your phone to find new device
5. Ente rpin '0000' (four zero) then press OK or yes
6. this should complete the pairing.
Mar 31, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Dont no my pass key for my ear piece
The default passkey for all the blue tooth headsets is "0000". Please try it out. If you need further clarifications, please write back to us. Please rate my solution as helpful! Have a great day
Mar 25, 2010 | True Blue TB-50CR Bluetooth Headset
Need passkey to connect my tb20el bluetooth to my phone
for tb-20el:
Apr 14, 2009 | Motorola Mobility H700 Wireless Headset
Connect trueblue bluetooth headset to Samsung Eternity cell phone
I had the same poroblem. I turned the phone off and then restarted it. That worked for me. Try to make a phone call and see if you can hear it on the Bluetooth.
Also... compliments of Best Buy Troubleshooting -
Bluetooth Troubleshooting: Phones & Headsets
Problem #1:
Headset and phone are turned on, but you don't hear anything in the headset, i.e., there is no dial tone.
Action #1: Make sure your phone is Bluetooth-capable. If it is not: A. Buy a new Bluetooth-capable phone. B. Purchase a Bluetooth adapter for your non-Bluetooth phone. The adapter will allow your phone to interact with a Bluetooth headset.
Problem #2:
It's a Bluetooth-capable phone and Bluetooth headset, both are turned on, but you still don't hear anything.
Action #2: Make sure your phone, headset, and, if necessary, adapter are fully charged before attempting to synch the Bluetooth connection between the two devices - in many cases a blinking blue light will indicate the headset is charged.
Problem #3:
Everything is charged, but still not working.
Action #3:Before two Bluetooth-enabled devices can communicate with each other, they need to be initially synched up to each other - also referred to as linking or pairing.
A. Find "Communications" or "Connections" on your phone's menu screen and explore within to locate "New" or "Bluetooth."
B. Push the main button on the headset until the light shines solid blue and is NOT blinking. C. Select Bluetooth on phone menu. Within Bluetooth you may need to select and highlight "Devices" or "Find Devices" (depending on where you are, there may be other Bluetooth devices available).
D. While the headset light is solid blue, open the Bluetooth link (or Find Devices) on your phone's menu screen and scroll through until you locate the headset you wish to synch up to. Your phone will automatically begin searching for Bluetooth devices within 30 feet of itself.
E. After a short period of time, your menu screen should say "connected" or "devices paired". Make sure you click or select the device name to finalize the connection. If you have successfully paired the two devices, you will hear a dial tone in the headset. Congratulations! You've joined the Bluetooth world.
Note: After a couple of minutes showing solid blue, the light on the headset will start blinking; you want to pair up the phone and headset while the light is still unblinking. This is important. If the light starts blinking before you can complete the connection, you will need to turn the headset off and on and start over.
Problem #4:
You've followed all the instructions in this guide, and your Bluetooth connection is still not functioning properly.
Action #4: Take out your manual and carefully reread the section on synching up Bluetooth devices. If you still can't get things properly connected, we suggest you call the manufacturer regarding this issue.
Motorola: 1-877-MOTO-BLU for troubleshooting, or www.hellomoto.com
Jabra: 1-800-327-2230 from 8 a.m. to 8 p.m. EST for technical support; or www.jabra.com
I hope this helps.
Dec 19, 2008 | True Blue TB-50CR Bluetooth Headset
Radio Communications Logo
943 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
