Question about Intel D915GAG Intel 915G Socket 775 mATX Motherboard w/Video, Audio & LAN (D915GAGBO)
My rear usb ports work correctly.first 1 of 2 front usb ports stop working now both are not working. i have changed the window but did not work.
  • Intel Master
  • 27,725 Answers
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Posted on Feb 24, 2012
3 Suggested Answers
SOURCE: USB Problem
for front usb port to be working you must give the 4 pin power cord connection to the front usb header ....
and about the back usb i think dome capacitor is gone so it is not working just have check with the capacitor and if it need get changed with new capacitor ...
if you dont have idea about this matter just visit the technician ...
he will do it..
for the usb be to work it need some power so it is provided by the capacitors as the current goes through capacitors so if the capacitor is gone it will not work as there will be no power supply from the capacitor if it is dead ...
so you need to replace the capacitor ...
so if you dnt have idea just take your motherboard to technician he will have the check and replace the capacitor ...
any doubts reply me
i am always here to assist you
thank you
bye
Posted on Apr 16, 2008
bronk50
  • 27725 Answers
SOURCE: hi, i have a problem
here is a basic guide to usb devices
control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver as for the internet flash dongle
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured (whole pc shutdown)you might be able to uninstall then reinstall some of these files/software
hope this helps
Posted on Jan 02, 2011
The port to which the printer is connected is not supported. Check the port
I'm assuming you are using a USB connection, not a Ethernet connection.
Try a different USB port (preferably in the REAR of the computer, not the front). It's not unusual to have 1 or 2 poorly-performing (low power) ports on a PC; some printers don't like those.
If you have a really old computer, it may have ancient USB type "1" (slow) ports instead of the newer 2.0 or 3.0 USB type. Some printers don't like old USB 1 ports, but it is not supposed to matter.
If all else fails, try another USB cord, or a shorter one. Some printers don't work well with cords longer than 4 feet, and USB cords can go bad.
Or, try the printer on another computer. If the same USB cord works fine there, YOUR computer has the problem (probably a USB port or USB driver issue).
Are you having issues with other USB devices? If so, it may be a Windows driver issue.
Good luck. If no help, post your exact printer model # here, or try contacting Lexmark.com support
Dec 02, 2013 | Lexmark All-in-One Printer with PictBridge
All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Oct 27, 2009 | E-Machines eMachines Desktop PC
ALL uSB Ports stopped working
If new BIOS will not help, then
Motherboard needs service.
Dec 29, 2008 | HP Pavilion dv9000z Notebook
The 4 USB Ports in the rear stopped working. Can they easily be replaced?
hi there,
the rear USB port cannot be replaced, & glad that you still have a front USB connections into your MOBO..?
May i ask why did they suggest you to use the front USB panel..? Can you give us some info why this was happen..?
Thank you
May 27, 2008 | PC Chips M957G Motherboard
Smartdisk Firelite usbflb80 stopped working
My Smartdisk Firelite 80 gig Mini-Drive will not power up when plugged into the front or rear USB Ports (Windows XP Pro System). Last used successfully on 4-Apr-08 with no issues. Any suggestions?
Feb 22, 2008 | FireLite (USBFLB80) Hard Drive
Front Side USN dows not work in ASUS M2N MX SE
The front side port may be a "low power" USB port, it may be possible to "power" this if there is the capacity to connect a power cable to the front panel USB adapter, or there may be an aux power socket to plug into on the motherboard.
Nov 04, 2007 | ASUS M2N-MX Motherboard
Front side USB port is not working
On some computers the front usb ports are like a usb hub, they don't have enough power to power up a hard drive.
Intel D915GAG Intel 915G Socket 775 mATX Motherboard w/Video, Audio & LAN (D915GAGBO) Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
