Question about Sharp MX-2700N Color Copier
Sharp mx2301 fk1 error code - Sharp MX-2700N Color Copier
4 Suggested Answers
  • 54 Answers
SOURCE: I have a sharp copier MX2700N with an error code
fuser count has reached 200,000 copies. hit P*C* then 24, start, then 4 start. select Fuser Unit and Fuser Acum Day then execute at bottom then yes. Hit CA button. copier should reboot and clear code.
Posted on Apr 17, 2009
FixinFax
  • 3085 Answers
SOURCE: I HAVE A SHARP MX1800N AND THE CODE OF FK1 KEEPS
You have a bad FUSER unit....expensive!! It is not heating up.
Posted on Jun 14, 2010
  • 2072 Answers
SOURCE: code:fk1 sharp 2301 N
That is a maintanence code. Usually says that the fuser rolls are at a certain copy count.
Here is what to do.
Press in order on the consol. # * C * That will enter the machine into what is called SIM mode.
Then enter the number 24 then 4 for that code, then press execute. You may want to just do the clear all maintenance code too.
Posted on Apr 27, 2011
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
Will a maintenance required code FK1 prevent printing on a Sharp 3100N printer/copier?
Yes it will if SNMP is ticked in the Ports tab situated in the printer properties of the print driver. To check this open up Printers & Faxes on the PC, right click the sharp printer & select "printer properties" Click on the 3rd tab along(Ports) & on the lower left hand side you should see the SNMP box. If it is ticked then untick it, apply & OK. This should allow to print. If this box is ticked then when the copier displays any maintenance code it wiil allow copying but not printing.
Hope it helps.
Dave.
Sep 25, 2014 | Sharp Mx-3100n Color Copier Super...
What is sub code of fk1
FK1 refers to the maintenance life counter for the fuser unit.
The fuser rollers have a fixed life count & when that count is reached FK1 is displayed. If the rollers are worn they should be replaced but if they are ok you can reset the fuser maintenance counter in SIM 24-4 FUSER UNIT
Aug 08, 2014 | Sharp MX-2300N Color Copier
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Service code: FK1
Since you neglected to state the type of device, make or model, I am assuming everything and sending you what I guess!
http://search.aol.com/aol/search?&s_qt=sb&q=service+codes+fk1%2Cfk2%2Ctk1&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 21, 2013 | Audio Players & Recorders
Code:fk1 sharp 2301 N
Here is what to do.
Apr 26, 2011 | Sharp MX-2300N Color Copier
Can you tell me what code FK1 means?
Your fuser has gone past 200,000 sheets of usage and it's time for a rebuild. You could reset the counter with sim code 24 but eventually it will clog up with waste toner and your rollers will tear up. Sharp has rebuild kits for your or you could just buy a new one.
Jan 07, 2011 | Sharp MX-3501N All-In-One Printer
I have a sharp copier MX2700N with an error code of FK1. What do I need to do to fix it?
Apr 17, 2009 | Sharp MX-2700N Color Copier
Sharp MX-2700N Color Copier Logo
463 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
