Question about Panasonic Lumix DMC-TZ3 Digital Camera
How to remove lens
Need instructions on how to remove and replace lens
    Problem Solver:
  • 6 Answers
Instructions to replace tail light
Lift the tailgate and you will find two screws at the top of the lens assembly, remove them. Pull on both sides of the lens directly out from the vehicle as there are two ridged prongs about middle of the lens. It will sound like something is breaking but it should come out with a little tugging. On the back of the now removed lens, turn the top plug a quarter turn and pull away from the back of the lens. Pull the bulb from the wired socket and replace. Install in reverse.
Jan 16, 2011 | 2000 Ford Explorer
I need to replace one of the gauges (cracked the glass) on my Makita MAC5200 compressor. Is there somewhere I can find the instructions for doing so?
Makita has used several types of gauges over the years and all had removable lens/glass held on by screw or threaded lens. Most simple repair would be to purchase gauge and just swap out glass/lens. Order from www.toolpartsdirect.com. Good luck
Jan 12, 2011 | Makita MAC5200 Electric Powered Air...
How do i change the license plate bulb on a 2004 tb ls
here is the instructions on how to replace license plate bulbs.
Remove the 2 screws that retain the license lamp lens to the liftgate.
  • Remove the license lamp lens from the liftgate.
  • Remove the bulb (1) from the socket.
    Oct 11, 2010 | 2004 Chevrolet TrailBlazer
    Change the lens of my Canon IXUS 860 IS
    remove the cover screews then discharge the flash capacitor take precautions of static electricity.Remove the screews of the mother board and the lens-body .detache the lens unit to replace with a new one.if u need note down the fixing positions etc.
    Apr 10, 2010 | Canon IXUS 860 IS Digital Camera
    I have a camera it's a canon S5 IS i let a friend borrow it he dropped it and now the lens won't go back in it says lens error restart camera i need help
    Lens error occurred due to external shock, Now lens is prevented from properly extending or retracting.
    1) Avoid applying pressure to the lens and surrounding area:
    • Do not touch Lens while shooting.
    • Make sure the camera is off before the camera is placed back in the case.
    or..
    2) Check batteries and make sure that they have sufficient charge, the batteries may need to be recharged or replaced. follow the instruction to resolve the problem.
    • Remove the battery and wait 30 Seconds & reinsert the battery, if your camera has a backup or date and time battery, remove this battery as well. Removal of the backup battery will cause a full reset of the camera and will clear any settings.
    If this will not solve the problem your device need service (repair)
    Rating the solution in highly appreciated....Good Luck
    Mar 05, 2010 | Canon PowerShot S5 IS Digital Camera
    Lens won't go back in
    If lens won't go back, Check batteries and make sure that they have sufficient charge, the batteries may need to be recharged or replaced. follow the instruction to resolve the problem.
    Feb 28, 2010 | Canon PowerShot A470 Digital Camera
    My canon 24-105 lens was dropped in water and I want to service it. (The Canon service centre says they can fix it but at a high cost.) is there an assembly diagram or instructions
    This is not a DIY repair. You need to have access to lens collimators and other specialist tools and also need to be able to remove and replace lens cement to have any chance of tackling this successfully.
    The cost is high not only because some parts might need to be replaced but because the lens needs to be stripped down almost totally to ensure that no moisture remains trapped inside. Some of the materials used in the lens construction tend to absorb water and will either need to be replaced or removed and dessicated before being replaced. When originally built, most of the lens was assembled by robots but it's far more difficult and precise for a skilled human to dismantle and correctly reassemble a lens which will already have seen some wear and tear.
    If every last drop of moisture is not removed then you can at the very least expect your lens to fog up regularly and to rapidly suffer the onset of lens fungus which will permanently damage the glass coatings. You'll also find that electronic parts will fail due to corrosion.
    Sorry to be so negative but I've repaired (and also failed to repair) enough lenses in my time to have a good idea of where the limits lie in lens repair.
    Your lens will cost around £800 to replace, so even if repairs cost half that then it's money well spent. Botched DIY repairs will leave the lens either worthless or completely uneconomic to repair.
    Aug 22, 2009 | Canon 24-105mm f/4L IS USM EF Lens
    How to replace the license plate blub
    open the trunk and remove the back panel in the trunk could be a couple of clips or a few screws holding the panel on one you remove the panel you should have easy access to the bulb just twist and remove. or on some avalons you need to pry the lens off the light to replace it then the lens will click back into place with a little push
    Mar 09, 2009 | 2000 Toyota Avalon
    Replacement lens for Motorola SLVR L7
    go to you tube Motorola L7 - Rear Lower Removal - Repair Tutorial
    its easy.
    Nov 18, 2007 | Motorola Mobility SLVR L7 Cellular Phone
    Panasonic Lumix DMC-TZ3 Digital Camera Logo
    37 people viewed this question
    Top Panasonic Cameras Experts
    Computer Links
    Are you a Panasonic Camera Expert? Answer questions, earn points and help others
