Question about AT&T Cell Phones
Htc my screen is locked
When I turn phone on it is locked. I can receive calls
    Master:
  • AT&T Master
  • 443 Answers
There is an awesome app called LEO Privacy for Android that lets you design a personal lock screen for your phone. You should try the app and make your lock screen interesting. https://goo.gl/BCKwGq LEO Privacy Applock Boost Hide Android Apps on Google Play
Posted on Nov 21, 2016
  • 380 Answers
  1. From the Home screen, press the Menu key, and then tap Settings > Security.
  2. Tap Change screen lock.
  3. Enter your current screen lock to confirm that you want to change it.
  4. Choose a different screen lock type, and then enter your new pattern, PIN, or password. Alternatively, tap None if you want to remove your screen lock.
Posted on Feb 24, 2012
4 Suggested Answers
  • 102 Answers
SOURCE: I place a four diget code on my phone and locked for the screen and forgot the code
remove and reinsert the battery, press and hold the volume down then press and hold power, you should be in hboot mode, press power once, you should see factory reset among the options down, scroll to it and press power. Note: all data will be lost.
Posted on Nov 12, 2011
chirash333
  • 265 Answers
SOURCE: Phone freeze after a call received in blocked screen
okk. have u upgraded ur firmware to version 11.0.021. if not then plss do it. it is like a must for n97. u will have to format ur phone. try restarting but tht might not work. so format ur device *#7370#. thn restore u r phone. code is 12345
Posted on Aug 11, 2009
  • 5 Answers
SOURCE: I use Bluetooth headset with HTC 3G and when a
i used motorola CE0168
Posted on Mar 20, 2010
Screen will not turn on my htc after charging
first put in your simcard POWER ON your phone ...let the screen go off ...see if you are able to receive calls ..if yes then you need to change the flex cable or the LCD..if you are unable to receive calls then it means you need to put in a new software y upgrading
if your NOKIA PHONE SAYS INVALID SIM or PHONE RESTRICTED ..IT MEANS YOUR PHONE IS NETWORK LOCKED.IT WILL ONLY WORK WITH A PARTICULAR SIMCARD ONLY PROVIDED TO YU BY UR SERVICE PROVIDER......YOU NEED TO UNLOCK IT IN ORDER TO USE THAT PHONE WITH ANY OTHER PROVIDERS SIMCARD...WE CAN UNLOCK ALL NOKIA IPHONES SONYERICSSON MOTOROLA HTC BLACKBERRIES AND MANY MORE ..CONTACT US ON gsmspeedAThotmailDOTcom
Sep 12, 2012 | HTC Desire Cell Phone
The touch screen on my wildfire htc phone is far too sensitive - makes calls by accident ...
The only resolution or work around for that is by enabling a pin lock or a pattern lock for your phone
This can be accomplished by going to settings > location &security> setup screen lock
Please setup one and your phone wont dare to make that accidental call again .
Aug 08, 2011 | HTC Wildfire Cell Phone
My Motorola H17 is paired with my HTC MyTouch 3G Slide. I turn on the Bluetooth and make a call. After I hang up from the call, when someone calls me, I receive the announcement through the BT that there's...
I have an HTC Desire, I find that if I answer on the phone by touching the phone screen's answer button it answers in the phone :( But if I push the button on the bluetooth to answer it answers in the bluetooth - very annoying but appears to be an HTC issue not motorola's
Feb 10, 2011 | Motorola Mobility H710 Bluetooth Headset
Sprint htc touch pro 2 - will locking prevent accidental dialing or does it have something to do w/the backlight,,,every couple min. phone lights up and then the buttons are too easily accessed leading to...
locking your phone will help stop accidental dialling. if you don't lock your phone all you have to do is touch the screen and your ready to press buttons if you lock it then you have to unlock before you can press them, so in turn to acccidently call somebody it would have to unlock itself in your pocket.
Dec 14, 2010 | HTC Touch Pro Smartphone
HTC HERO SMART PHONE
To turn the phone off, you need to first get past the screen lock and get to the phone. Then you need to hold down the red end call button. Hold it down long enough to get a popup menu. The top option is "Power off". Select this and it will ask for a confirmation to shut off the phone.
Good luck.
Jan 18, 2010 | HTC Hero Smartphone
The belt holster turns the phone on and makes calls as well as drains the battery. case has a magnetic fastner?
The case doesn't have a magnet like the Blackberry, when you receive a text message the unit wakes up. I find this is when my TP2 starts opening internet and making calls etc! If you are having this problem a lot I would recommend using the screen lock. Have you also upgraded the ROM to Windows Mobile 6.5.1? This has a better slde-to-answer interface.
Dec 12, 2009 | HTC Touch Pro2 Smartphone
Htc touch diamiond keypad locked
u can unlock the key lock with long press of call end button like 4 sec see if ti works otherwise
u can try factory reset the device like this but all data will be wiped off pls active sync ur device and backup ur data then try this
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
if it doesnt help then u can upgrade ur ROM from www.HTC.com and it will also solve ur problem
pls rate me FIXYA
Mar 17, 2009 | HTC Touch Diamond Smartphone
I'd like to lock the keypad of my HTC S740.
To lock the keys so you don't accidently activate the phone whilst carrying it about.
Press and hold down the "end call" button ( phone handset down picture) until Unlock shows at bottom left screen
To unlock, press the top left button, above the "start call" button (phone handset up picture), then press the * button (bottom left).
You get a screen prompt to press * to unlock
Mar 06, 2009 | HTC S740 Smartphone
Cell Phones Logo
195 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
