Question about Samsung Reclaim Cell Phone
Wont charge Every time I try to charge my phone it always say charging halted and I don't know what to do...
  • shamika washington Feb 24, 2012
    Id brought a new charger....this is the 3rd charger i'd brought and still the same problem
  • 380 Answers
YOU SHOULD REPLACE UR CHARGER
DONT BUY A USED ONE
Posted on Feb 24, 2012
5 Suggested Answers
SOURCE: wont charge
its probably your charging port i had one that went bad and wouldnt charge too.
Posted on Nov 14, 2008
sfender713
  • 397 Answers
SOURCE: My Samsung Reclaim phone will
Try replacing the battery- it sounds as if the battery has completely shorted out. If that does not work the issue is w/ the phone's charging system
Posted on Jan 09, 2011
Bajanguru
  • 7752 Answers
SOURCE: Samsung schu u740 charging problem
try another battery and if that does not work then take it to a mobile service center to have it fix.
Posted on Jun 04, 2008
  • 252 Answers
SOURCE: when i try to charge my phone it says charging
well my wife had this phone and it did the same thing and i worked for sprint as a tech and we had to replace them because it was software related this was a few years ago but if they cannnot fix it at a service and repair center you will have to file insurance claim or however your account is set up to get it replaced
hope it helps a little please be kind enough to leave me agood review if this helps
Posted on May 09, 2011
My acer tablet a110 wont charge over 50 percent
The battery pack is exhausted replace it.
Apr 05, 2017 | Cell Phones
My phone wont charge when i plug it into the charger
maybe the problem is on your charger. try to change it with a new charger.
if still happen, you can make a jumper to your USB port (if you don't know how to make it, take it to any service centre and ask them to make the jumper)
if still happen call your phone manufacturer.
Nov 15, 2012 | ZTE n860 warp unlocked gsm phone
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
Replaced key and reset cam and crank timing on briggs & stratton, still wont start
i you don't have a blade on it they will not run either
Jun 02, 2012 | Garden
Not starting up
hello there!
so you're phone won't charge up...you should buy a new battery...your old battery is not functioning well...
tip:
don't use the phone while charging. let it be fully charge before using it again. and don't let it to overcharge too. this will reduce the life span of the battery.
Thank you for choosing fixya and kindly rate this post.
Dec 30, 2011 | Sony Ericsson Cell Phones
I don't have a manual for my small Black & Decker Smart Charger. I'm trying to charge the battery on my '07 Honda Rebel 250cc. It has settings for 2/6/12 volt batteries. How do I hook it...
You just need to set black & decker charger to 12V . Don't make mistake while connecting + / - leads. + lead usually come with Red color cable. You can use the AVO tester to justify the lead cable. The charging time is normally about 10 -12 hours (or just just check the status on your charger display). If your charger does not has trickle charge facility, you have to disconnect your charger after 12 hours continuous use.
Also, you can find the guidance about your charger here :
www.blackanddecker.com/power-tools/VEC1087CBD.aspx
Regards
Sep 22, 2011 | Honda CB 250 Motorcycles
Please my bb 8310 has a problem, always showing a message saying BATTERY DRAINED SHUTTING DOWN HANDHELD, please can you help me? i don't know if it's a software or hardware problem...please help
has the phone been charged for a sufficient period of time? if it has, try removing the battery to ensure the contacts are clean with no obstructions. then replace battery and try again
Aug 15, 2011 | Cell Phones
NC10 battery not charging. The charging light flashes as normal but battery wont charge, tried another battery with same result.
Allow 1hour to charge it, if did not charge check the input & output of the charger if its properly insert, if not again off your notebook & charge it, always check if it is charging,
Note: Charging test try on, off, & unuse it allow to full charge the battery before using..avoid low bat your battery when using.
Jun 03, 2011 | Samsung NC10-14GW Notebook
My samsung metro pcs phone wont hold a charge and I have a hard time getting the charger to work. No matter what charger I use I cant get it to work. If I get lucky the charger will work. What do I do?
there i no need troubling yourself further, the problem with your phone is the charging port, the charging port of your phone is bad that is why, your phone battery cannot hold charge.
Change the charging port of your phone and your phone will charge and hold charge.
Regards.
Apr 26, 2010 | Cell Phones
Samsung Reclaim  Cell Phone Logo
90 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
